4631|2
nios 11.0版本编译问题 [复制链接]
d:/alter/altera11.0/quartus/quartus/nios2eds/bin/gnu/h-i686-mingw32/bin/../lib/gcc/nios2-elf/4.1.2/../../../../nios2-elf/bin/ld.exe: uart.elf section `.text' will not fit in region `epcs_flash_controller'
d:/alter/altera11.0/quartus/quartus/nios2eds/bin/gnu/h-i686-mingw32/bin/../lib/gcc/nios2-elf/4.1.2/../../../../nios2-elf/bin/ld.exe: address 0x8e10 of uart.elf section `.rwdata' is not within region `epcs_flash_controller'
d:/alter/altera11.0/quartus/quartus/nios2eds/bin/gnu/h-i686-mingw32/bin/../lib/gcc/nios2-elf/4.1.2/../../../../nios2-elf/bin/ld.exe: address 0xacd0 of uart.elf section `.bss' is not within region `epcs_flash_controller'
d:/alter/altera11.0/quartus/quartus/nios2eds/bin/gnu/h-i686-mingw32/bin/../lib/gcc/nios2-elf/4.1.2/../../../../nios2-elf/bin/ld.exe: address 0xacd0 of uart.elf section `.epcs_flash_controller' is not within region `epcs_flash_controller'
d:/alter/altera11.0/quartus/quartus/nios2eds/bin/gnu/h-i686-mingw32/bin/../lib/gcc/nios2-elf/4.1.2/../../../../nios2-elf/bin/ld.exe: region `epcs_flash_controller' overflowed by 42192 bytes
collect2: ld returned 1 exit status
我在sopc builder中设置复位地址和异常地址是epcs,如果复位地址设为epcs,异常地址设为epcs也有这个问题,请问这是什么问题?
此帖出自FPGA/CPLD论坛
请问一下这个问题你是怎么解决的啊?  详情 回复 发表于 2013-10-28 14:27
6892
是不是地址冲突了啊
此帖出自FPGA/CPLD论坛
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
回复 楼主tianma123 的帖子
请问一下这个问题你是怎么解决的啊?
此帖出自FPGA/CPLD论坛
