11516|13
5968
BeagleBone 硬件性能测试(2) ---- 上电初体验 [复制链接]
玲珑MM好给力!说今天能拿到板子就一定能拿到,中午的时候快递公司就把BeagleBone送到了我的手上,上个点把玩一下吧。明天就要出门旅游了,哈哈
启动信息如下:
U-Boot SPL 2011.09-00000-gf63b270-dirty (Nov 14 2011 - 10:37:14)
Texas Instruments Revision detection unimplemented
No AC power, disabling frequency switch
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2011.09-00000-gf63b270-dirty (Nov 14 2011 - 10:37:14)
I2C:   ready
DRAM:  256 MiB
No daughter card present
NAND:  HW ECC Hamming Code selected
nand_get_flash_type: unknown NAND device: Manufacturer ID: 0x10, Chip ID: 0x10
No NAND device found!!!
0 MiB
MMC:   OMAP SD/MMC: 0
*** Warning - readenv() failed, using default environment
Net:   cpsw
Hit any key to stop autoboot:  0
SD/MMC found on device 0
reading uEnv.txt
33 bytes read
Loaded environment from uEnv.txt
Importing environment from mmc ...
reading uImage
3031456 bytes read
## Booting kernel from Legacy Image at 80007fc0 ...
   Image Name:   Angstrom/3.1/beaglebone
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3031392 Bytes = 2.9 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   XIP Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.067560] omap_l3_smx omap_l3_smx.0: couldn't find resource
[    0.244350] _omap_mux_get_by_name: Could not find signal leds-gpio
[    0.313839] omap2_set_init_voltage: unable to get clk dpll1_ck
[    0.319996] omap2_set_init_voltage: unable to set vdd_mpu_iva
[    0.326141] omap2_set_init_voltage: unable to get clk l3_ick
[    0.332141] omap2_set_init_voltage: unable to set vdd_core
systemd-fsck[61]: Angstrom-Cloud9-: clean, 27400/874496 files, 774461/3494137 blocks
[   14.579399] /usr/sbin/crond[91]: (CRON) INFO (Syslog will be used instead of sendmail.): No such file or directory
[   16.118728]
[   16.118738] CPSW phy found : id is : 0x7c0f1
[   16.125685] PHY 0:01 not found
.---O---.
|       |                  .-.           o o
|       |     | __  |  ---'| '--.|  .-'|     |     |
The Angstrom Distribution beaglebone ttyO0
Angstrom v2011.10-core - Kernel 3.1.0+
beaglebone login:
输入root,进入系统后也点个灯玩玩吧:
点亮usr1,不要点usr0哈,usr0已经被linux系统用作系统心跳了。
root@beaglebone:~# echo 1 > /sys/class/leds/beaglebone::usr1/brightness
关闭usr1
root@beaglebone:~# echo 0 > /sys/class/leds/beaglebone::usr1/brightness
使用交叉网线连接BeagleBone板子和PC机:
设置板子IP:
root@beaglebone:~# ifconfig eth0 192.168.1.100
root@beaglebone:~# ping 192.168.1.124
PING 192.168.1.124 (192.168.1.124) 56(84) bytes of data.
64 bytes from 192.168.1.124: icmp_req=1 ttl=64 time=2.20 ms
64 bytes from 192.168.1.124: icmp_req=2 ttl=64 time=0.394 ms
64 bytes from 192.168.1.124: icmp_req=3 ttl=64 time=0.267 ms
64 bytes from 192.168.1.124: icmp_req=4 ttl=64 time=0.369 ms
另外一张卡的启动信息,有些不一样耶,加入了启动的时间打印
U-Boot SPL 2011.09 (Nov 04 2011 - 21:43:12)
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2011.09 (Nov 04 2011 - 21:39:19)
I2C:   ready
DRAM:  256 MiB
WARNING: Caches not enabled
0 MiB
MMC:   OMAP SD/MMC: 0
Net:   cpsw
reading uEnv.txt
** Unable to read "uEnv.txt" from mmc 0:1 **
reading uImage
2870524 bytes read
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Arago/3.0+3.1-rc8-psp04.06.00.02
   Data Size:    2870460 Bytes = 2.7 MiB
   Loading Kernel Image ... OK
OK
Starting kernel ...
[    0.000000] Linux version 3.1.0-rc8 (jenkins@sdit-build01) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Sun Oct 30 06:40:25 CDT 2011
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: am335xevm
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] AM335X ES1.0 (neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait ip=dhcp
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 256MB = 256MB total
[    0.000000] Memory: 253928k/253928k available, 8216k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xffa00000 - 0xffe00000   (   4 MB)
[    0.000000]     vmalloc : 0xd0800000 - 0xf8000000   ( 632 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc051e000   (5208 kB)
[    0.000000]       .init : 0xc051e000 - 0xc0554000   ( 216 kB)
[    0.000000]       .data : 0xc0554000 - 0xc059e200   ( 297 kB)
[    0.000000]        .bss : 0xc059e224 - 0xc05ca200   ( 176 kB)
[    0.000000] NR_IRQS:396
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[    0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000242] Calibrating delay loop... 498.89 BogoMIPS (lpj=2494464)
[    0.058626] pid_max: default: 32768 minimum: 301
[    0.058790] Security Framework initialized
[    0.058869] Mount-cache hash table entries: 512
[    0.059322] CPU: Testing write buffer coherency: ok
[    0.064048] print_constraints: dummy:
[    0.064322] NET: Registered protocol family 16
[    0.064526] GPMC revision 6.0
[    0.065667] OMAP GPIO hardware version 0.1
[    0.066626] omap_l3_smx omap_l3_smx.0: couldn't find resource
[    0.066741] omap_mux_init: Add partition: #1: core, flags: 0
[    0.069308] platform omap_i2c.1: alias fck already exists
[    0.070031] platform omap2_mcspi.1: alias fck already exists
[    0.070147] platform omap2_mcspi.2: alias fck already exists
[    0.078962] bio: create slab <bio-0> at 0
[    0.079999] SCSI subsystem initialized
[    0.080924] usbcore: registered new interface driver usbfs
[    0.081070] usbcore: registered new interface driver hub
[    0.081234] usbcore: registered new device driver usb
[    0.081593] registerd cppi-dma Intr @ IRQ 17
[    0.081611] Cppi41 Init Done Qmgr-base(d083a000) dma-base(d0838000)
[    0.081625] Cppi41 Init Done
[    0.098701] omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
[    0.099578] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.100155] Bluetooth: Core ver 2.16
[    0.100244] NET: Registered protocol family 31
[    0.100260] Bluetooth: HCI device and connection manager initialized
[    0.100281] Bluetooth: HCI socket layer initialized
[    0.100296] Bluetooth: L2CAP socket layer initialized
[    0.100329] Bluetooth: SCO socket layer initialized
[    0.100530] Switching to clocksource gp timer
[    0.108703] Switched to NOHz mode on CPU #0
[    0.109486] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.109661] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[    0.110731] musb-hdrc musb-hdrc.0: USB OTG mode controller at d080a000 using DMA, IRQ 18
[    0.111000] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[    0.111954] musb-hdrc musb-hdrc.1: USB OTG mode controller at d080c800 using DMA, IRQ 19
[    0.112320] NET: Registered protocol family 2
[    0.112544] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.112906] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.113131] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.113267] TCP: Hash tables configured (established 8192 bind 8192)
[    0.113285] TCP reno registered
[    0.113302] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.113334] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.113572] NET: Registered protocol family 1
[    0.113923] RPC: Registered named UNIX socket transport module.
[    0.113940] RPC: Registered udp transport module.
[    0.113953] RPC: Registered tcp transport module.
[    0.113966] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.114236] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.114319] omap_init_opp_table: no hwmod or odev for iva, [8] cannot add OPPs.
[    0.125674] VFS: Disk quotas dquot_6.5.2
[    0.125759] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.126461] JFFS2 version 2.2. (NAND) (SUMMARY)  漏 2001-2006 Red Hat, Inc.
[    0.126844] msgmni has been set to 495
[    0.127767] io scheduler noop registered
[    0.127785] io scheduler deadline registered
[    0.127872] io scheduler cfq registered (default)
[    0.128531] Could not set LED4 to fully on
[    0.129716] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.131029] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    0.668125] console [ttyO0] enabled
[    0.672198] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    0.679876] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    0.687594] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[    0.695322] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[    0.703015] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[    0.717459] brd: module loaded
[    0.724507] loop: module loaded
[    0.727903] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[    0.790576] No daughter card found
[    0.794214] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[    0.809522] Board name: A335BONE
[    0.812939] Board version: 00A3
[    0.816250] The board is a AM335x Beaglebone.
[    0.821492] platform omap_hsmmc.0: alias fck already exists
[    0.828515] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.835442] omap2-nand driver initializing
[    0.839883] OneNAND driver initializing
[    0.890610] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[    0.897136] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[    0.904167] davinci_mdio.0: probed
[    0.907759] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver SMSC LAN8710/LAN8720
[    0.916719] usbcore: registered new interface driver cdc_ether
[    0.922958] usbcore: registered new interface driver cdc_subset
[    0.929248] Initializing USB Mass Storage driver...
[    0.934514] usbcore: registered new interface driver usb-storage
[    0.940861] USB Mass Storage support registered.
[    0.945791] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    0.951520] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    0.959462] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.966655] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.974278] usb usb1: Product: MUSB HDRC host driver
[    0.979513] usb usb1: Manufacturer: Linux 3.1.0-rc8 musb-hcd
[    0.985494] usb usb1: SerialNumber: musb-hdrc.1
[    0.990877] hub 1-0:1.0: USB hub found
[    0.994855] hub 1-0:1.0: 1 port detected
[    0.999683] mousedev: PS/2 mouse device common for all mice
[    1.006422] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
[    1.013200] omap_rtc: already running
[    1.017120] i2c /dev entries driver
[    1.021654] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    1.028067] Bluetooth: HCI UART driver ver 2.2
[    1.032791] Bluetooth: HCI H4 protocol initialized
[    1.037842] Bluetooth: HCILL protocol initialized
[    1.044494] usbcore: registered new interface driver usbhid
[    1.050378] usbhid: USB HID core driver
[    1.054901] usbcore: registered new interface driver snd-usb-audio
[    1.062333] ALSA device list:
[    1.065462]   No soundcards found.
[    1.069056] nf_conntrack version 0.5.0 (3967 buckets, 15868 max)
[    1.076031] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.081813] TCP cubic registered
[    1.085221] NET: Registered protocol family 17
[    1.090183] Bluetooth: RFCOMM TTY layer initialized
[    1.095385] Bluetooth: RFCOMM socket layer initialized
[    1.100824] Bluetooth: RFCOMM ver 1.11
[    1.104778] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.110376] Bluetooth: BNEP filters: protocol multicast
[    1.115898] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.122344] Registering the dns_resolver key type
[    1.127400] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    1.135517] ThumbEE CPU extension supported.
[    1.140884] omap2_set_init_voltage: unable to get clk dpll1_ck
[    1.147036] omap2_set_init_voltage: unable to set vdd_mpu_iva
[    1.153129] omap2_set_init_voltage: unable to get clk l3_ick
[    1.159097] omap2_set_init_voltage: unable to set vdd_core
[    1.166267] Detected MACID=40:5f:c2:76:95:e0
[    1.171784] omap_rtc omap_rtc: setting system clock to 2000-01-01 01:42:34 UTC (946690954)
[    1.183833]
[    1.183841] CPSW phy found : id is : 0x7c0f1
[    1.190662] PHY 0:01 not found
[    1.271668] mmc0: host does not support reading read-only switch. assuming write-enable.
[    1.282736] mmc0: new high speed SDHC card at address 1234
[    1.289089] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[    1.296308]  mmcblk0: p1 p2 p3
[    4.181137] PHY: 0:00 - Link is Up - 100/Full
[    4.210587] Sending DHCP requests ...... timed out!
[   79.502552] IP-Config: Reopening network devices...
[   79.510323]
[   79.510329] CPSW phy found : id is : 0x7c0f1
[   79.517223] PHY 0:01 not found
[   81.501298] PHY: 0:00 - Link is Up - 100/Full
[   81.520586] Sending DHCP requests ...... timed out!
[  168.812465] IP-Config: Auto-configuration of network failed.
[  168.825370] kjournald starting.  Commit interval 5 seconds
[  169.345186] EXT3-fs (mmcblk0p2): using internal journal
[  169.350740] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[  169.358046] VFS: Mounted root (ext3 filesystem) on device 179:2.
[  169.364833] Freeing init memory: 216K
INIT: version 2.86 booting
Please wait: booting...
Error opening /dev/fb0: No such device
Starting udev
[  169.952594] udevd (76): /proc/76/oom_adj is deprecated, please use /proc/76/oom_score_adj instead.
[  174.524983] kjournald starting.  Commit interval 5 seconds
[  175.116274] EXT3-fs (mmcblk0p3): using internal journal
[  175.121851] EXT3-fs (mmcblk0p3): mounted filesystem with ordered data mode
[  177.167713] alignment: ignoring faults is unsafe on this CPU.  Defaulting to fixup mode.
Remounting root file system...
Caching udev devnodes
ALSA: Restoring mixer settings...
/usr/sbin/alsactl: load_state:1625: No soundcards found...
Configuring network interfaces... [  184.827430]
[  184.827445] CPSW phy found : id is : 0x7c0f1
[  184.834384] PHY 0:01 not found
udhcpc (v1.13.2) started
Sending discover...
[  186.821334] PHY: 0:00 - Link is Up - 100/Full
Sending discover...
Sending discover...
No lease, forking to background
done.
Setting up IP spoofing protection: rp_filter.
Fri Nov  4 07:52:00 UTC 2011
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting Hardware abstraction layer hald
Creating Dropbear SSH server RSA host key.
Will output 1024 bit rsa secret key to '/etc/dropbear/dropbear_rsa_host_key'
Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgwCnlSedLCIvAEcPiZTFEeeKJ19shYIfTGIOtoeCPIBU8XArtaE9W7zuweLMzk/4WdAL9e9MF+NcJjbVAP2pytJHEETsomxWl0fziIeWQMa6RegvaJPgqLa4a1P1FSbmafUtbbjOmUU4MXMM6ZFqWfK8yMswNEt63Z3hscrbD37iuJYz root@am335x-evm
Fingerprint: md5 46:b2:f9:7f:87:60:e0:a0:e8:70:ca:5b:0c:b7:61:7d
Starting Dropbear SSH server: dropbear.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpd.
Starting Lighttpd Web Server: lighttpd.
2011-11-04 07:52:01: (log.c.166) server started
[  204.433527]  gadget: Mass Storage Function, version: 2009/09/11
[  204.439795]  gadget: Number of LUNs=2
[  204.443753]  lun0: LUN: removable file: /dev/mmcblk0p1
[  204.449178]  lun1: LUN: removable file: /dev/mmcblk0p3
[  204.454649]  gadget: Mass Storage Gadget, version: 2009/09/11
[  204.460737]  gadget: userspace failed to provide iSerialNumber
[  204.466915]  gadget: g_mass_storage ready
[  204.471207] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[  204.476891] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[  204.484874] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[  204.492056] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[  204.499673] usb usb2: Product: MUSB HDRC host driver
[  204.504923] usb usb2: Manufacturer: Linux 3.1.0-rc8 musb-hcd
[  204.510902] usb usb2: SerialNumber: musb-hdrc.0
[  204.516400] hub 2-0:1.0: USB hub found
[  204.520376] hub 2-0:1.0: 1 port detected
[  205.483441]  gadget: high speed config #1: Linux File-Backed Storage
NOTICE: This file system contains the followin GPLv3 packages:
        binutils-dev
        gdbserver
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
Starting Matrix GUI application.
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org am335x-evm ttyO0
Arago 2011.09 am335x-evm ttyO0
am335x-evm login:
[ 本帖最后由 chenzhufly 于 2012-4-19 15:33 编辑 ]
哦!它的程序是放在SD卡里的,那别人复制程序很方便 期待,期待哦! 真爽,51还没到就开始旅游了呀! 羡慕!  详情 回复 发表于 2012-4-19 16:47
个人签名生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙
做一个简单的人,踏实而务实,不沉溺幻想,不庸人自扰
5318
453
beaglebone
的程序空间有多大啊?
5968
5318
453
是外扩NAND 吗?
5968
这个明显是DDR2的大小啊
NAND在这个小板子上没有,是通过SD卡启动的
5318
453
DDR2  SDRAM里?
5968
呵呵,DDR2 和 SDRAM是两个东西,都是外部动态存储器
貌似AM335X现在不支持SDRAM
[ 本帖最后由 chenzhufly 于 2012-4-19 16:19 编辑 ]
5318
453
回复 7楼 chenzhufly 的帖子
求 分析解释,呵呵!
5968
google一下比我说的清楚,哈哈
SDRAM从发展到现在已经经历了四代,分别是:第一代SDR SDRAM,第二代DDR SDRAM,第三代DDR2 SDRAM,第四代DDR3 SDRAM.(显卡上的DDR已经发展到DDR5)
SDRAM
http://zh.wikipedia.org/wiki/SDRAM
DDR2
http://baike.baidu.com/view/1059123.htm
AM335X支持的存储器;
• 外部存储器接口 (EMIF)
– mDDR/DDR2/DDR3 控制器:
• mDDR: 200-MHz 时钟频率 (400-MHz 数据速
率)
• DDR2: 266-MHz 时钟频率 (532-MHz 数据速
率)
• DDR3: 303-MHz 时钟频率 (606-MHz 数据速
率)
• 16-位数据总线
• 1GB全部可寻址空间
• 支持1 x 16或者2 x 8存储器器件配置
• 支持快速唤醒保持
– 通用存储器控制器 (GPMC)
• 具有多达 7 芯片(NAND,NOR,复
用NOR,SRAM等)选择的灵活 8/16-位异步存
储器接口
• 使用 BCH 编码以支持 4-位,8-位,或者 16-
位 ECC
• 使用海明码(Hamming)以支持 1-位 ECC
[ 本帖最后由 chenzhufly 于 2012-4-19 16:23 编辑 ]
5318
453
那DDR2做内存用了!
5968
是的哦,呵呵
5318
453
那板子掉电后!,系统程序从那里运行
5968
SD卡啊
不要着急哈
我还没写硬件系统分析和启动模式分析呢,哈哈
马上就要出去旅游了,下星期再搞
[ 本帖最后由 chenzhufly 于 2012-4-19 16:41 编辑 ]
5318
453
期待,期待哦!
真爽,51还没到就开始旅游了呀!
羡慕!
有奖探索 | 和村田一起,深挖 GNSS 开发!
活动时间:即日起-5月11日
活动奖励:智能手环、螺丝刀套装、双肩包
