6568|11
使用定时器0来ad采样问题 [复制链接]
定时中断 ad采样问题
写了一个定时中断函数,将AD采样写在定时中断中,结果不能得到正确的AD值,定时时间为0.1ms,采用dsp2806,系统时钟为50MHz,外部引脚ADCIN已经连接到1.6V直流电压,为什么我的AD值却总是零呢?能够进入到定时器的中断里,就是AD=0,难道AD没启动吗?
请高手帮帮忙!!
void ADC_Init(void)
    AdcRegs.ADCTRL1.bit.RESET = 1;    //Reset ADC module
    asm(" RPT #20||NOP");
    AdcRegs.ADCTRL3.all = 0x00E2;     // Power up bandgap/reference/ADC circuits
    AdcRegs.ADCTRL1.bit.RESET = 0;
    AdcRegs.ADCTRL1.bit.SUSMOD = 1;   // 模式3
    AdcRegs.ADCTRL1.bit.ACQ_PS = 0x4; // SOC脉宽
    AdcRegs.ADCTRL1.bit.CPS = 1;      // ADCCLK=FCLK/2
    AdcRegs.ADCTRL1.bit.CONT_RUN =0;  // ???
    AdcRegs.ADCTRL1.bit.SEQ_OVRD = 0;
    AdcRegs.ADCTRL1.bit.SEQ_CASC = 1; // cascade mode
    AdcRegs.ADCMAXCONV.all = 0x07;
    AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x0; // Setup ADCINA0 as 1st SEQ1 conv
    AdcRegs.ADCCHSELSEQ1.bit.CONV01 = 0x0; // Setup ADCINB0 as 2nd SEQ1 conv
    AdcRegs.ADCCHSELSEQ1.bit.CONV02 = 0x8;
    AdcRegs.ADCCHSELSEQ1.bit.CONV03 = 0x8;
    AdcRegs.ADCCHSELSEQ2.bit.CONV04 = 0x1;
    AdcRegs.ADCCHSELSEQ2.bit.CONV05 = 0x1;
    AdcRegs.ADCCHSELSEQ2.bit.CONV06 = 0x9; // Setup ADCINA1 as 3st SEQ1 conv
    AdcRegs.ADCCHSELSEQ2.bit.CONV07 = 0x9; // Setup ADCINB1 as 4st SEQ1 conv
    AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1 = 0;  // disable SEQ1 interrupt (every EOS)
    AdcRegs.ADCTRL2.bit.EPWM_SOCA_SEQ1 = 0;// disable SOCA from ePWM to start SEQ1
    AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1;
    asm(" RPT #4||NOP");
    AdcRegs.ADCTRL2.bit.SOC_SEQ1 = 1;
interrupt void  TINT0_ISR(void)      // CPU-Timer 0     P=0.1ms
     i= AdcRegs.ADCRESULT0;
     result[0]=i>>4;
     i= AdcRegs.ADCRESULT1;
     result[1]=i>>4;
     i= AdcRegs.ADCRESULT2;
     result[2]=i>>4;
     i= AdcRegs.ADCRESULT3;
     result[3]=i>>4;
     i= AdcRegs.ADCRESULT4;
     result[4]=i>>4;
     i= AdcRegs.ADCRESULT5;
     result[5]=i>>4;
     i= AdcRegs.ADCRESULT6;
     result[6]=i>>4;
     i= AdcRegs.ADCRESULT7;
     result[7]=i>>4;
  i=result[0]+result[1]+result[2]+result[3];
     i=i>>2;
     g_uSample[g_uNum]=i;
  i=result[4]+result[5]+result[6]+result[7];
  i=i>>2;
  g_uSample1[g_uNum]=i;
  g_uNum++;
  if(g_uNum>255) g_uNum=0;
  AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1;    //Restart the ADC
  CpuTimer0Regs.TCR.bit.TIF=1;
    PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
       EINT;
void main(void)
    InitSysCtrl();
    Config_Gpio();
    ADC_Init();
    GPIO_Init();
    DINT;
    IER = 0x0000;
    IFR = 0x0000;
    InitPieCtrl();
    InitPieVectTable();
    InitCpuTimers();   //Initialize the Cpu Timers
    PieCtrlRegs.PIEIER1.bit.INTx7 = 1;   //Timer0
    IER |= M_INT1;    //Timer0  1.7
    EINT;   // Enable Global interrupt INTM
    ERTM;   // Enable Global realtime interrupt DBGM
    ConfigCpuTimer(&CpuTimer0, 50, 100000);
    StartCpuTimer0();
 for(;;)
是芯片坏掉了? 楼主你是不是换块芯片就好了,那块"坏掉"芯片不要丢了,那块芯片应该没有坏,很少会出现芯片上某一模块损坏,其他功能完好的现象。 我估计就是楼主的焊接问题。  详情 回复 发表于 2012-4-18 10:39
569
用TI例程包中的例程试一下,如果还有问题就检查硬件。
否则比对例程检查软件。
回复 沙发 hlx3012 的帖子
你好,我用例程ADCSOC试了一下,采集到的数据还是零,但是硬件应该没问题,我用万用表测试过,输入电压值为1.6V,为什么呢?
569
如果程序没问题。那就只能是硬件问题。
比如焊接,比对一下芯片厂家的参考电路吧。
硬件应该没问题吧?
我用万用表测试过ADCINA0  ADCINA1的电压值,是1.6V,这是不是就已经说明硬件没有问题了呢?
2606
仔细看看,你实际硬件电路和你采样设置是否相同。另请检测下AD是否正常供电。一般不会是DSP的问题
个人签名工程 = 数学+物理+经济
回复 6楼 安_然 的帖子
你好,我读AD的标志位可以发现AD的确启动了转换,但是结果却一直为0,为了防止我采样的管脚错了,我设置采样为级联顺序采样,采样通道为16,将所有管脚的值都读出来,但是一直是0,请问还有可能是哪方面的原因错了呢?
569
我猜测就是硬件问题。
楼主可以看看ADCLO引脚是否有接地,ADC的ACDDREFBG,AVSSREFBG....有没有正确连接,如果用的是内部参考那么ADCREFP有没有按要求接地。
如果都有,那我建议楼主卸下芯片重新焊一下
2606
楼主,外部硬件确实有电压,但是采集的时候却采不到。那么我觉问题集中在DSP上。DSP 硬件及软件。楼主用例程也采不到,那说明很可能是硬件问题。看看DSP供电什么的。不行的话,换一块DSP试试
个人签名工程 = 数学+物理+经济
解决了,是我DSP芯片坏掉了。
赞赏
查看全部赞赏
569
是芯片坏掉了?
我估计就是楼主的焊接问题。
回复 11楼 hlx3012 的帖子
应该是芯片的问题或者你说的焊接问题吧,我目前认为是芯片上的AD坏了,因为我的板子是焊死的,不方便直接更换芯片,我又重新换了一套板子,功能就正常了。软件程序没有改动过的。
