3381|0
5310
453
小试LM4F232的64位定时器!64位定时器应用到那些方面比较好呢! [复制链接]
直接修改LM4F232\boards\ek-lm4f232\timers 的例程,
定时10S。
在主函数里增加64位部分
    // Enable the peripherals used by this example.
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER0);
    ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_TIMER1);
// 使能宽64位定时器0外设
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_WTIMER0);
    // Enable processor interrupts.
    ROM_IntMasterEnable();
    // Configure the two 32-bit periodic timers.
    ROM_TimerConfigure(TIMER0_BASE, TIMER_CFG_PERIODIC);
    ROM_TimerConfigure(TIMER1_BASE, TIMER_CFG_PERIODIC);
    ROM_TimerLoadSet(TIMER0_BASE, TIMER_A, ROM_SysCtlClockGet());
    ROM_TimerLoadSet(TIMER1_BASE, TIMER_A, ROM_SysCtlClockGet() / 2);
//配置64位宽的定时器0
ROM_TimerConfigure(WTIMER0_BASE,TIMER_CFG_PERIODIC);
ROM_TimerLoadSet64(WTIMER0_BASE,ROM_SysCtlClockGet()*10);
    // Setup the interrupts for the timer timeouts.
    ROM_IntEnable(INT_TIMER0A);
    ROM_IntEnable(INT_TIMER1A);
//使能64位宽的定时器0中断
ROM_IntEnable(INT_WTIMER0A);
    ROM_TimerIntEnable(TIMER0_BASE, TIMER_TIMA_TIMEOUT);
    ROM_TimerIntEnable(TIMER1_BASE, TIMER_TIMA_TIMEOUT);
ROM_TimerIntEnable(WTIMER0_BASE,TIMER_TIMA_TIMEOUT);
    // Enable the timers.
    //ROM_TimerEnable(TIMER0_BASE, TIMER_A);
    ROM_TimerEnable(TIMER1_BASE, TIMER_A);
//使能64位宽的定时器0
ROM_TimerEnable(WTIMER0_BASE,TIMER_A);
中断函数
void
WTimer0IntHandler(void)
    // Clear the timer interrupt.
    ROM_TimerIntClear(WTIMER0_BASE,TIMER_TIMA_TIMEOUT);
    // Toggle the flag for the first timer.
    HWREGBITW(&g_ulFlags, 0) ^= 1;
    // Update the interrupt status on the display.
    ROM_IntMasterDisable();
    GrStringDraw(&g_sContext, (HWREGBITW(&g_ulFlags, 0) ? "1" : "0"), -1, 68,
                 26, 1);
然后修改startup_rvmdk.s里增加
EXTERN  WTimer0IntHandler
还有
DCD     WTimer0IntHandler           ; Wide Timer 0 subtimer A
