5226|1
312
在CCSv4下配置XDS510USB仿真调试TI Stellairs M3 [复制链接]
用过XDS510仿真C2000的,现在可以参考如下方法调试M3
The Texas Instruments Stellaris microcontroller does not support a return TCK pin and most Stellaris boards do not connect the TCK to TCK_RET at the emulation header. Fortunately if you are using an XDS510USB Plus emulator you can use the internal TCK loop back feature to provide an emulation clock. The steps below show how to configure the XDS510USB Plus using the emulation drivers included in CCS v4. If your CCS v4 installation does not show the “SdConfigEx v4” icon then you should either update to a newer CCS v4 release or simply follow the instructions for alternate configuration. Please note that older emulators like XDS510PP-PLUS and XDS510USB do not support the internal TCK loop back feature. However you should be able to use those emulators if you manually wire the TCK to TCK_RET pin at the emulation header of your board or adapter. Please see here for details. For these older emulators, you may want to reduce the TCK speed through SdConfigEx (i.e. TCK Divisor =2 to 4).1) Select the SdConfigEx v4 icon on your desktop:查看详情
2) Under the TCK Mode select “CounterITckr”. The CounterITckr mode will internally loop TCK to RTCK and no RTCK is needed at the JTAG header. Most Stellaris devices specify a TCK max of 10MHz so you may want to set the TCK Frequency field to 10.
查看详情
3) Start CCSv4 and configure your CCS connection. Attached is LM3S8962 configuration file
[ 本帖最后由 hansonhe 于 2012-3-22 19:21 编辑 ]
Evmlm3s8962.zip
424 Bytes, 下载次数: 31
看一下 谢谢楼主分享  详情 回复 发表于 2012-3-23 08:51
565
513
裸片初长成(中级)
看一下 谢谢楼主分享
