2729|7
初学者,请教问题!!!1 [复制链接]
entity cnt16 is
port(clk:in std_logic;
     dout:out std_logic_vector(3 downto 0);
          dclk1:out std_logic);
end cnt16;
architecture Behavioral of cnt16 is
     signal clk1:std_logic :='1';
          signal q:integer range 0 to 24000000:=0;
     signal w:std_logic_vector(3 downto 0):="0000";
begin
     dclk1<=clk1; dout<=not w;
          t1:process(clk)
            begin
                       if clk'event and clk='1' then
                                   if q=23999999 then
                                           q<=0;clk1<=not clk1;
                                        else
                                           q<=q+1;
                                        end if;
                                  end if;
                 end process;
          t2:process(clk1)
            begin
                       if clk1'event and clk1='1' then
                                   if w=9 then
                                           w<="0000";
                                        else
                                           w<=w+1;
                                        end if;
                                  end if;
                 end process;
end Behavioral;
错误提示在if w=9 then
                                           w<="0000";
                                        else
                                           w<=w+1;
can not have such operands in this context. 请问这是什么意思?应该怎么修改?
此帖出自FPGA/CPLD论坛
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.std_logic_arith.all; entity test_fpga is port(clk:in std_logic; dout:out std_logic_vector(3 downto 0); dclk1:out std_logic); end test_fpga; architecture Behavioral of test_fpga is signal clk1:std_logic :='1'; signal q:integer range 0 to 24000000:=0; signal w:std_logic_vector(3 downto 0):="0000"; begin dclk1  详情 回复 发表于 2012-3-3 17:01
没人知道怎么修改吗?
此帖出自FPGA/CPLD论坛
可能是你的library没加全
library ieee;
此帖出自FPGA/CPLD论坛
按照你说的都加上了还是同样地方出错
此帖出自FPGA/CPLD论坛
815
w是标准逻辑类型,不能和1进行加操作。
此帖出自FPGA/CPLD论坛
207
此帖出自FPGA/CPLD论坛
写成w=“1001”试试!
此帖出自FPGA/CPLD论坛
编译通过在11.0下!
library ieee;
entity test_fpga is
end test_fpga;
begin
t1:process(clk)
begin
if q=23999999 then
else
q<=q+1;
end if;
end if;
end process;
t2:process(clk1)
begin
if w=9 then
w<="0000";
else
w<=w+1;
end if;
end if;
end process;
end Behavioral;
此帖出自FPGA/CPLD论坛
