3110|0
C6713烧写求助,有CODE_SECTION [复制链接]
我打算把程序的一部分放入CE0口的SDRAM中运行,就用了#pragma CODE_SECTION(counting,".xxxsect")
然后在.cmd文件中将.xxxsect段放入SDRAM中,编译链接运行正确,但烧写时却总是boot失败,求各位高手指导,不胜感激!!
烧写用的cmd文件如下:
MEMORY
{       BOOTRAM:       o = 00000000h   l= 00000400h
    IRAM:          o = 00000400h   l = 0000FA00h
    SDRAM:               o = 80000000h   l = 00010000h
    FLASH_BOOT:    o = 0x90000000  l = 00000400h
    FLASH_REST:    o = 0x90000400  l = 0001fc00h
SECTIONS
{          .boot_load : load =0x90000000, run = BOOTRAM
    /* Initialized User Code Section */
    .text           : load = FLASH_REST, run = IRAM
            LOAD_START(_text_ld_start),
            RUN_START(_text_rn_start),
            SIZE(_text_size)
    .xxxsect   : load = FLASH_REST, run = SDRAM
        LOAD_START(_xxxsect_ld_start),
            RUN_START(_xxxsect_rn_start),
            SIZE(_xxxsect_size)
    .cinit            >         FLASH_REST
    .const      >       IRAM
    .stack      >       IRAM
    .bss        >       IRAM
    .data       >       IRAM
    .far        >       IRAM
    .switch     >       IRAM
    .sysmem     >       IRAM
    .cio        >       IRAM
快来报名!
