5438给PCF8563读写数据,出错,请大家给找找错
#include <msp430x54x.h>
#define SDA_1 P3OUT |= BIT7 //SDA = 1 #define SDA_0 P3OUT &=~ BIT7 //SDA = 0 #define SCL_1 P5OUT |= BIT4 //SCL = 1 #define SCL_0 P5OUT &=~ BIT4 //SCL = 0 #define DIR_IN P3DIR &=~ BIT7 //I/O口为输入 #define DIR_OUT P3DIR |= BIT7 //I/0口为输出 #define SDA_IN (P3IN & 0x80) //Read SDA
void Delay(); void start_I2C(); void stop_I2C(); void Ack(); void NAck(); void CheckAck(); void SendByte(unsigned char c); unsigned char ReadByte(); unsigned char read_PCF8563(unsigned char slave_addr,unsigned char write_addr); void write_PCF8563(unsigned char slave_addr,unsigned char write_addr,unsigned char writedata);
void main() { WDTCTL = WDTPW+WDTHOLD; //关闭看门狗定时器 P3DIR |= BIT7; P5DIR |= BIT4; write_PCF8563(0xA2,0x02,0x59); read_PCF8563(0xA2,0x02); }
void Delay() {_NOP();}
void start_I2C(void) //I2C的开始条件 { SDA_1; //发送起始条件的数据信号 Delay(); SCL_1; Delay(); SDA_0; //发送起始信号 Delay(); SCL_0; //钳住I2C总线,准备发送或接收数据 Delay(); }
void stop_I2C(void) //I2C的停止条件 {SDA_0; //发送结束条件的数据信号 Delay(); SCL_1; Delay(); SDA_1; //发送I2C总线结束信号 Delay(); } void SendByte(unsigned char c) {int BitCnt; for(BitCnt=0;BitCnt<8;BitCnt++) { if((c<<BitCnt)&0x80) SDA_1; else SDA_0; Delay(); SCL_1; //置时钟线为高,通知从机开始接收数据位 Delay(); SCL_0; } Delay(); CheckAck(); }
{ unsigned char read_data=0; unsigned char BitCnt; DIR_IN; //置数据线为输入方式 for(BitCnt=0;BitCnt<8;BitCnt++) { Delay(); SCL_0; //置时钟线为低,准备接收数据位 Delay(); SCL_1; //置时钟线为高使数据线上数据有效 Delay(); if(SDA_IN==0x80) read_data=read_data+1; //读数据位,接收的数据位放入read_data中 read_data=read_data<<1; Delay();
} SCL_0; Delay(); DIR_OUT; return(read_data); }
void CheckAck() {unsigned char count=20; DIR_IN; SDA_1; //8位发送完后释放数据线,准备接收应答位 Delay(); SCL_1; Delay(); while(SDA_IN) {count--; if(!count) stop_I2C(); } SCL_0; Delay(); DIR_OUT; }
void Ack() { SDA_0; //在此发出应答信号 Delay(); SCL_1; Delay(); SCL_0; //清时钟线,钳住I2C总线以便继续接收 Delay(); }
void NAck() {SDA_1; Delay(); SCL_1; Delay(); SCL_0; //清时钟线,钳住I2C总线以便继续接收 Delay();
void write_PCF8563(unsigned char slave_addr,unsigned char write_addr,unsigned char writedata) { start_I2C(); //启动总线 SendByte(slave_addr); //发送器件地址 SendByte(write_addr); //发送器件子地址 SendByte(writedata); //发送数据 stop_I2C(); //结束总线 }
unsigned char read_PCF8563(unsigned char slave_addr,unsigned char write_addr) { unsigned char Y; start_I2C(); //启动总线 SendByte(slave_addr); //发送器件地址 SendByte(write_addr); //发送器件子地址 start_I2C(); //重新启动总线 SendByte(slave_addr+1); Y=ReadByte(); NAck(); //发送非应位 stop_I2C(); //结束总线 return(Y); }
用5438给PCF8563读写数据,试了一下,每次都是检测不到从机应答(即运行到CheckAck后便停止),想让大家给看看程序是不是有问题,如果程序没问题的话,那是不是PCF8563坏了?
[ 本帖最后由 zzbaizhi 于 2012-2-21 16:40 编辑 ]
