1844|0
6892
Verilog代码
  1. module uart #(
  2.     parameter clk_freq = 50000000,
  3.     parameter baud = 9600
  4. ) (
  5.     input sys_clk,
  6.     input sys_rst,
  7.
  8.     output rx_irq,
  9.     output tx_irq,
  10.
  11.     input uart_rx,
  12.     output uart_tx
  13. );
  14.
  15. wire [7:0] rx_data;
  16. reg [7:0] tx_data;
  17. reg tx_wr;
  18.
  19. always @(posedge sys_clk)
  20. begin
  21.     if (rx_irq)
  22.     begin
  23.     tx_data <= rx_data;
  24.     tx_wr <= 1'b1;
  25.     end
  26.     else
  27.     begin
  28.     tx_wr <= 1'b0;
  29.     end
  30. end
  31.
  32. uart_transceiver transceiver(
  33.     .sys_clk(sys_clk),
  34.     .sys_rst(sys_rst),
  35.
  36.     .uart_rx(uart_rx),
  37.     .uart_tx(uart_tx),
  38.
  39.     .divisor(clk_freq/baud/16),
  40.
  41.     .rx_data(rx_data),
  42.     .rx_done(rx_irq),
  43.
  44.     .tx_data(tx_data),
  45.     .tx_wr(tx_wr),
  46.     .tx_done(tx_irq)
  47. );
  48.
  49. endmodule
  uart_transceiver.v
Verilog代码
  1.  * Milkymist VJ SoC
  2.  * Copyright (C) 2007200820092010 Sebastien Bourdeauducq
  3.  * Copyright (C) 2007 Das Labor
  4.  *
  5.  * This program is free software: you can redistribute it and/or modify
  6.  * it under the terms of the GNU General Public License as published by
  7.  * the Free Software Foundation, version 3 of the License.
  8.  *
  9.  * This program is distributed in the hope that it will be useful,
  10.  * but WITHOUT ANY WARRANTY; without even the implied warranty of
  11.  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  12.  * GNU General Public License for more details.
  13.  *
  14.  * You should have received a copy of the GNU General Public License
  15.  * along with this program.  If not, see <http://www.gnu.org/licenses/>.
  16.  */
  17.
  18. module uart_transceiver(
  19.     input sys_rst,
  20.     input sys_clk,
  21.
  22.     input uart_rx,
  23.     output reg uart_tx,
  24.
  25.     input [15:0] divisor,
  26.
  27.     output reg [7:0] rx_data,
  28.     output reg rx_done,
  29.
  30.     input [7:0] tx_data,
  31.     input tx_wr,
  32.     output reg tx_done
  33. );
  34.
  35. //-----------------------------------------------------------------
  36. // enable16 generator
  37. //-----------------------------------------------------------------
  38. reg [15:0] enable16_counter;
  39.
  40. wire enable16;
  41. assign enable16 = (enable16_counter == 16'd0);
  42.
  43. always @(posedge sys_clk) begin
  44.     if(sys_rst)
  45.         enable16_counter <= divisor - 16'b1;
  46.     else begin
  47.         enable16_counter <= enable16_counter - 16'd1;
  48.         if(enable16)
  49.             enable16_counter <= divisor - 16'b1;
  50.     end
  51. end
  52.
  53. //-----------------------------------------------------------------
  54. // Synchronize uart_rx
  55. //-----------------------------------------------------------------
  56. reg uart_rx1;
  57. reg uart_rx2;
  58.
  59. always @(posedge sys_clk) begin
  60.     uart_rx1 <= uart_rx;
  61.     uart_rx2 <= uart_rx1;
  62. end
  63.
  64. //-----------------------------------------------------------------
  65. // UART RX Logic
  66. //-----------------------------------------------------------------
  67. reg rx_busy;
  68. reg [3:0] rx_count16;
  69. reg [3:0] rx_bitcount;
  70. reg [7:0] rx_reg;
  71.
  72. always @(posedge sys_clk) begin
  73.     if(sys_rst) begin
  74.         rx_done <= 1'b0;
  75.         rx_busy <= 1'b0;
  76.         rx_count16  <= 4'd0;
  77.         rx_bitcount <= 4'd0;
  78.     end else begin
  79.         rx_done <= 1'b0;
  80.
  81.         if(enable16) begin
  82.             if(~rx_busy) begin // look for start bit
  83.                 if(~uart_rx2) begin // start bit found
  84.                     rx_busy <= 1'b1;
  85.                     rx_count16 <= 4'd7;
  86.                     rx_bitcount <= 4'd0;
  87.                 end
  88.             end else begin
  89.                 rx_count16 <= rx_count16 + 4'd1;
  90.
  91.                 if(rx_count16 == 4'd0) begin // sample
  92.                     rx_bitcount <= rx_bitcount + 4'd1;
  93.
  94.                     if(rx_bitcount == 4'd0) begin // verify startbit
  95.                         if(uart_rx2)
  96.                             rx_busy <= 1'b0;
  97.                     end else if(rx_bitcount == 4'd9) begin
  98.                         rx_busy <= 1'b0;
  99.                         if(uart_rx2) begin // stop bit ok
  100.                             rx_data <= rx_reg;
  101.                             rx_done <= 1'b1;
  102.                         end // ignore RX error
  103.                     end else
  104.                         rx_reg <= {uart_rx2, rx_reg[7:1]};
  105.                 end
  106.             end
  107.         end
  108.     end
  109. end
  110.
  111. //-----------------------------------------------------------------
  112. // UART TX Logic
  113. //-----------------------------------------------------------------
  114. reg tx_busy;
  115. reg [3:0] tx_bitcount;
  116. reg [3:0] tx_count16;
  117. reg [7:0] tx_reg;
  118.
  119. always @(posedge sys_clk) begin
  120.     if(sys_rst) begin
  121.         tx_done <= 1'b0;
  122.         tx_busy <= 1'b0;
  123.         uart_tx <= 1'b1;
  124.     end else begin
  125.         tx_done <= 1'b0;
  126.         if(tx_wr) begin
  127.             tx_reg <= tx_data;
  128.             tx_bitcount <= 4'd0;
  129.             tx_count16 <= 4'd1;
  130.             tx_busy <= 1'b1;
  131.             uart_tx <= 1'b0;
  132. `ifdef SIMULATION
  133.             $display("UART: %c", tx_data);
  134. `endif
  135.         end else if(enable16 && tx_busy) begin
  136.             tx_count16  <= tx_count16 + 4'd1;
  137.
  138.             if(tx_count16 == 4'd0) begin
  139.                 tx_bitcount <= tx_bitcount + 4'd1;
  140.
  141.                 if(tx_bitcount == 4'd8) begin
  142.                     uart_tx <= 1'b1;
  143.                 end else if(tx_bitcount == 4'd9) begin
  144.                     uart_tx <= 1'b1;
  145.                     tx_busy <= 1'b0;
  146.                     tx_done <= 1'b1;
  147.                 end else begin
  148.                     uart_tx <= tx_reg[0];
  149.                     tx_reg <= {1'b0, tx_reg[7:1]};
  150.                 end
  151.             end
  152.         end
  153.     end
  154. end
  155.
  156. endmodule
此帖出自FPGA/CPLD论坛
