2144
21
回复 17楼 zhaohuijing 的帖子
* This is a template for early application low-level initialization.
* Copyright 1996-2010 IAR Systems AB.
* $Revision: 5993 $
* The function __low_level_init it called by the start-up code before
* "main" is called, and before data segment initialization is
* performed.
* This is a template file, modify to perform any initialization that
* should take place early.
* The return value of this function controls if data segment
* initialization should take place. If 0 is returned, it is bypassed.
* For the MSP430 microcontroller family, please consider disabling
* the watchdog timer here, as it could time-out during the data
* segment initialization.
* To disable the watchdog timer, include a suitable device header
* file (or "msp430.h") and add the following line to the function
* below:
*     WDTCTL = WDTPW+WDTHOLD;
#include
int __low_level_init(void)
  /* Insert your low-level initializations here */
   * Return value:
   *  1 - Perform data segment initialization.
   *  0 - Skip data segment initialization.
  return 1;
:shy: :victory: Thank you!!:) 真的可以了!~ 大神啊!~~  详情 回复 发表于 2012-7-12 22:32
22
回复 21楼 lyzhangxiang 的帖子
Thank you!!   真的可以了!~ 大神啊!~~
