9389|15
SD 卡 SPI 模式初始化过程,带流程图。 [复制链接]
流程图如下,该代码能识别 MMC V3, SD V1.X 和 SD V2.00及其后续版本,其中 SD V2.00及其后续版本又可分为标准容量和大容量版本。
此帖出自stm32/stm8论坛
强大  详情 回复 发表于 2014-11-14 15:56
感谢楼主提供的技术资料  详情 回复 发表于 2012-9-24 16:14
SD SPI 发送命令 API 如下,所有实现代码参考附件。
  * @brief  Send 6 bytes command to the SD card.
  * @param  Cmd: The command send to SD card.
  * @param  argument: The command argument.
  * @param  response_type: the SPI command response type.
  * @param  *response: the SPI response returned.
  * @retval The SD Response.
uint8_t ARC_sd_send_command(uint8_t cmd, uint32_t argument,
                            SD_Response response_type, uint8_t *response)
    int32_t i = 0;
    uint8_t crc = 0x01;
    int8_t response_length = 0;
    uint8_t tmp;
    uint8_t Frame[6];
    if (cmd & 0x80)  /* Send a CMD55 prior to ACMD<n> */
        cmd &= 0x7F;
        ARC_sd_send_command(SD_CMD_APP_CMD, 0, R1, response);
        if (response[0] > 0x1)
            ARC_SD_CS_HIGH();
            ARC_SPI_SendByte(SPI1, SD_DUMMY_BYTE);
            return response[0];
    ARC_SD_CS_LOW();
    if(cmd == SD_CMD_GO_IDLE_STATE)
        crc = 0x95;
    if(cmd == SD_CMD_SEND_IF_COND)
        crc = 0x87;
    /* All data is sent MSB first, and MSb first */
    /* cmd Format:
    cmd[7:6] : 01
    cmd[5:0] : command */
    Frame[0] = ((cmd & 0x3F) | 0x40); /*!< Construct byte 1 */
    Frame[1] = (uint8_t)(argument >> 24); /*!< Construct byte 2 */
    Frame[2] = (uint8_t)(argument >> 16); /*!< Construct byte 3 */
    Frame[3] = (uint8_t)(argument >> 8); /*!< Construct byte 4 */
    Frame[4] = (uint8_t)(argument); /*!< Construct byte 5 */
    Frame[5] = (uint8_t)(crc); /*!< Construct CRC: byte 6 */
    for (i = 0; i < 6; i++)
        ARC_SPI_SendByte(SPI1, Frame); /*!< Send the Cmd bytes */
    switch (response_type)
        case R1:
        case R1B:
            response_length = 1;
            break;
        case R2:
            response_length = 2;
            break;
        case R3:
        case R7:
            response_length = 5;
            break;
        default:
            break;
    /* Wait for a response. A response can be recognized by the start bit (a zero) */
    i = 0xFF;
    do
        tmp = ARC_SPI_SendByte(SPI1, SD_DUMMY_BYTE);
    }while ((tmp & 0x80) && --i);
    response[0] = tmp;
    /* Just bail if we never got a response */
    if (i == 0)
        ARC_SD_CS_HIGH();
        return response[0];
    if((response[0] & SD_ILLEGAL_COMMAND) == SD_ILLEGAL_COMMAND)
        ARC_SD_CS_HIGH();
        return response[0];
    i = 1;
    while(i < response_length)
        response = tmp;
        i++;
    /* If the response is a "busy" type (R1B), then there's some
     * special handling that needs to be done. The card will
     * output a continuous stream of zeros, so the end of the BUSY
     * state is signaled by any nonzero response. The bus idles
     * high.
    if (response_type == R1B)
        do
            tmp = ARC_SPI_SendByte(SPI1, SD_DUMMY_BYTE);;
        }while (tmp != 0xFF);
    ARC_SD_CS_HIGH();
    return response[0];
ARC_SD.rar
2.12 KB, 下载次数: 122
此帖出自stm32/stm8论坛
使用手册。
14_SD.pdf
323.53 KB, 下载次数: 266
此帖出自stm32/stm8论坛
5015
裸片初长成(初级)
正有一个人在问呢!
谢谢楼主!
此帖出自stm32/stm8论坛
48
谢谢了!
此帖出自stm32/stm8论坛
多谢
此帖出自stm32/stm8论坛
21
学习来了
此帖出自stm32/stm8论坛
134
MARk
此帖出自stm32/stm8论坛
234
楼主有sdhc的标准不,整点上来看看呗。
此帖出自stm32/stm8论坛
个人签名努力就有不清不楚的收获。
楼主强大
此帖出自stm32/stm8论坛
学习来了
此帖出自stm32/stm8论坛
227
回复 楼主 armrunc 的帖子
感谢楼主提供的技术资料
此帖出自stm32/stm8论坛
26
学习了。。谢谢楼主提供资料
此帖出自stm32/stm8论坛
谢谢,呵呵
此帖出自stm32/stm8论坛
21
话说SPI操作SD卡的读写速度虽然差不多只能十来K,可对SD卡的兼容性很好。SDIO的老是出问题来着。
此帖出自stm32/stm8论坛
52
强大
此帖出自stm32/stm8论坛
