7435|4
569
关于C2000芯片的PWM同步 [复制链接]
好像TI没有给出专门讨论PWM同步的例程
EPwm1Regs.TBCTL.bit.SWFSYNC = 1;
需要等一段时间才能产生作用,比如
 asm("          NOP");
  asm("          NOP");
   asm("          NOP");
    asm("          NOP");
  asm("          NOP");
   asm("          NOP");
    asm("          NOP");
     asm("          NOP");
   asm("          NOP");
       asm("          NOP");
因为C2000的结构是流水线结构,需要等几个周期清空流水线。
下面的程序运行时可以看到GPIO33引脚持续输出Synchronization Pulse。EPwm1Regs.TBCTR,EPwm2Regs.TBCTR,EPwm3Regs.TBCTR基本上一直定在0x300这里
可以尝试修改EPwm1Regs.TBCTL.bit.SYNCOSEL,以改变Synchronization Pulse产生来源,同样也可以看到SYNCOSEL信号。
该程序可以直接用于C2000所有芯片(除28069)只要改变#include中的值。
[ 本帖最后由 hlx3012 于 2012-1-31 15:36 编辑 ]
你这个一进for循环就会产生软件同步,使计数器无论在哪都会回到这个值TBPHS = 0x0300.有什么意义?为什么不用 EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_SYNCOSEL_CTR_ZERO; EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_SYNCOSEL_EPWMXSYNC; EPwm3Regs.TBCTL.bit.SYNCOSEL = TB_SYNCOSEL_EPWMXSYNC; 这个产生同步很好.  详情 回复 发表于 2013-5-14 10:15
569
#include "DSP280x_Device.h"     // DSP280x Headerfile Include File
#include "DSP280x_Examples.h"   // DSP280x Examples Include File
void InitEPwm1Example(void);
void main(void)
   InitSysCtrl();
   InitEPwm1Gpio();
   InitEPwm2Gpio();
   InitEPwm3Gpio();
   EALLOW;
   GpioCtrlRegs.GPBPUD.bit.GPIO33 = 0;
   GpioCtrlRegs.GPBMUX1.bit.GPIO33 = 2;
   EDIS;
   EALLOW;
   SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;
   EDIS;
   InitEPwm1Example();
   EALLOW;
   SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;
   EDIS;
   for(;;)
 asm("          NOP");
  asm("          NOP");
   asm("          NOP");
    asm("          NOP");
  asm("          NOP");
   asm("          NOP");
    asm("          NOP");
     asm("          NOP");
   asm("          NOP");
      asm("          NOP");
void InitEPwm1Example()
   EPwm1Regs.TBCTL.bit.CTRMODE = 0;
   EPwm1Regs.TBPRD = 0x1000;
   EPwm1Regs.TBCTL.bit.PHSEN = 1;
   EPwm1Regs.TBCTL.bit.PHSDIR =1;
   EPwm1Regs.TBCTL.bit.SYNCOSEL =0;
   EPwm1Regs.TBPHS.half.TBPHS = 0x0300;
   EPwm1Regs.TBCTR = 0x0000;
   EPwm1Regs.CMPA.half.CMPA = 0x200;
   EPwm1Regs.AQCTLA.bit.ZRO = 2;
   EPwm1Regs.AQCTLA.bit.CAU = 1;
   EPwm2Regs.TBCTL.bit.CTRMODE = 0;
   EPwm2Regs.TBPRD = 0x1000;
   EPwm2Regs.TBCTL.bit.PHSEN = 1;
   EPwm2Regs.TBCTL.bit.SYNCOSEL =0;
   EPwm2Regs.TBPHS.half.TBPHS = 0x0300;
   EPwm2Regs.TBCTR = 0x0000;
   EPwm2Regs.CMPA.half.CMPA = 0x200;
   EPwm2Regs.AQCTLA.bit.ZRO = 2;
   EPwm2Regs.AQCTLA.bit.CAU = 1;
   EPwm2Regs.TBCTL.bit.PHSDIR =1;
   EPwm3Regs.TBCTL.bit.CTRMODE = 0;
   EPwm3Regs.TBPRD = 0x1000;
   EPwm3Regs.TBCTL.bit.PHSEN = 1;
   EPwm3Regs.TBCTL.bit.SYNCOSEL =0;
   EPwm3Regs.TBPHS.half.TBPHS = 0x0300;
   EPwm3Regs.TBCTR = 0x0000;
   EPwm3Regs.CMPA.half.CMPA = 0x200;
   EPwm3Regs.AQCTLA.bit.ZRO = 2;
   EPwm3Regs.AQCTLA.bit.CAU = 1;
   EPwm3Regs.TBCTL.bit.PHSDIR =1;
2606
这是一种软件同步的方法
个人签名工程 = 数学+物理+经济
2606
个人签名工程 = 数学+物理+经济
有个疑问
这个产生同步很好.
