2652|4
38
★基于LM3S811 的微型手持多功能测量器❤ [复制链接]
看看老外是怎样设计的吧!
原理图+PCB倾情大放送!!!
We built a multifunction scope based on Luminary Micro’s LM3S811 Evaluation board. This small handheld tool can be operated either standalone with 3 AAA batteries or powered by a PC’s USB port. When it runs in conjunction with a PC, the oscilloscope’s traces and measurement readouts can also be displayed on the PC screen though the USB cable. The multifunction tool supports the following modes:
  1. Dual ChannelTrace Oscilloscope: The oscilloscope supports 250K sampling/s for each channel. It provides free running (auto) mode, edge-triggered mode from channel 1 (+/- edge), and single shot mode.
  2. AC/DC Voltmeter: Auto ranged from mV to 10V.
  3. Ohmmeter: Auto ranged from 0W to 1.36 MW, with audible sound for connectivity.
  4. Capacitor Meter: Auto ranged from pF to 100 uF.
  5. Inductor Meter: Measures inductors in the mH/H range.
  6. Frequency Counter: Counts small level signal frequency.
  7. Logic Probe: Senses Logic High, Logic Low, Open Circuit (tri-state) and Pulse.
  8. Pulse Generator: Pulse repeat frequency: 5 Hz to 5MHz. Duty cycle: 1% -99%. Support single pulse output.
原理图:
PCB 、元件安装图:
效果图:
有兴趣的朋友也可以自己DIY一个呀!
不厚道,还要芯币。我在GOOGLE上输入“multifunction scope Luminary Micro’s LM3S811 Evaluation board”,全都出来了。 http://www.circuitcellar.com/archives/viewable/Zhang205/2.html  详情 回复 发表于 2012-1-8 23:11
87
38
原帖由 honestapple 于 2012-1-8 23:11 发表 不厚道,还要芯币。我在GOOGLE上输入“multifunction scope Luminary Micro’s LM3S811 Evaluation board”,全都出来了。 http://www.circuitcellar.com/archives/viewable/Zhang205/2.html
哪里要芯币了???
晕!
直接存图片不就可以了???!!!
38
原帖由 vvv9876 于 2012-1-9 15:15 发表 论坛都发过了,还发,,,,,,,
我之前不知道哈~
发过了,大家也可以看看学习学习呀!
38
原帖由 vvv9876 于 2012-1-10 09:38 发表 发的一模一样的,你又发一次不就是垃圾贴了
说话注意点行不?
不知者无罪,
晕!
我是在其他地方看到的,在这里贴出来大家分享一下,
着实晕了。。。。。
[ 本帖最后由 583199723 于 2012-1-10 13:30 编辑 ]
