3597|0
6482
管理员
[应用资料]TMP175:具有双线接口的数字温度传感器 [复制链接]
说明
The TMP175 and TMP75 are two-wire, serial output temperature sensors available in SO-8 and MSOP-8 packages. Requiring no external components, the TMP175 and TMP75 are capable of reading temperatures with a resolution of 0.0625°C.
The TMP175 and TMP75 feature a Two-Wire interface that is SMBus-compatible, with the TMP175 allowing up to 27 devices on one bus and the TMP75 allowing up to eight devices on one bus. The TMP175 and TMP75 both feature an SMBus Alert function.
The TMP175 and TMP75 are ideal for extended temperature measurement in a variety of communication, computer, consumer, environmental, industrial, and instrumentation applications.
The TMP175 and TMP75 are specified for operation over a temperature range of –40°C to +125°C.
特性
    * 27 ADDRESSES (TMP175)
      8 ADDRESSES (TMP75)
    * DIGITAL OUTPUT: Two-Wire Serial Interface
    * RESOLUTION: 9- to 12-Bits, User-Selectable
    * ACCURACY:
      ±.5°C (max) from –25°C to +85°C
      ±2.0°C (max) from –40°C to +125°C
    * LOW QUIESCENT CURRENT:
      50µA, 0.1µA Standby
    * WIDE SUPPLY RANGE: 2.7V to 5.5V
    * SMALL SO-8 AND MSOP-8 PACKAGES
    * APPLICATIONS
          o POWER-SUPPLY TEMPERATURE MONITORING
          o COMPUTER PERIPHERAL THERMAL PROTECTION
          o NOTEBOOK COMPUTERS
          o CELL PHONES
          o BATTERY MANAGEMENT
          o OFFICE MACHINES
          o THERMOSTAT CONTROLS
          o ENVIRONMENTAL MONITORING AND HVAC
          o ELECTROMECHANICAL DEVICE TEMPERATURE
Datasheet:
Digital Temperature Sensor with Two-Wire Interface.pdf (487.53 KB, 下载次数: 41)
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
个人签名微信搜索公众号“EEWORLDBBS”快去添加关注吧!
