4699|3
6550
管理员
[应用资料]TMP102: 采用 SOT563 封装具有 SMBus/双线串行接口的低功耗数字温度传感器 [复制链接]
The TMP102 is a two-wire, serial output temperaturesensor available in a tiny SOT563 package. Requiring no external components, the TMP102 is capable of reading temperatures to a resolution of 0.0625°C.
The TMP102 features SMBus and two-wire interface compatibility, and allows up to four devices on one bus. It also features an SMB alert function.
The TMP102 is ideal for extended temperature measurement in a variety of communication, computer, consumer, environmental, industrial, and instrumentation applications. The device is specified for operation over a temperature range of -40°C to +125°C.
特性
    * TINY SOT563 PACKAGE
    * ACCURACY: 0.5°C (-25°C to +85°C)
    * LOW QUIESCENT CURRENT:
      10µA Active (max)
      1µA Shutdown (max)
    * SUPPLY RANGE: 1.4V to 3.6V
    * RESOLUTION: 12 Bits
    * DIGITAL OUTPUT: Two-Wire Serial Interface
    * APPLICATIONS
          o PORTABLE AND BATTERY-POWERED APPLICATIONS
          o POWER-SUPPLY TEMPERATUREMONITORING
          o COMPUTER PERIPHERAL THERMAL PROTECTION
          o NOTEBOOK COMPUTERS
          o BATTERY MANAGEMENT
          o OFFICE MACHINES
          o THERMOSTAT CONTROLS
          o ELECTROMECHANICAL DEVICE TEMPERATURES
          o GENERAL TEMPERATURE MEASUREMENTS:
            Industrial Controls
            Test Equipment
            Medical Instrumentations
Datasheet:
Low Power Digital Temp Sensor with SMBusTwo-Wire Serial Interface in SOT563.pdf (338.39 KB, 下载次数: 52)
用户指南:
TMP102EVM User Guide.pdf (1.71 MB, 下载次数: 46)
解决方案指南:
面向平板电脑及电子书的 TI 解决方案.pdf (3.48 MB, 下载次数: 37)
TI Solutions for Tablets and eBooks.pdf (815.45 KB, 下载次数: 11)
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
最近在使用这个,用单片机编程,好苦,英文不好  详情 回复 发表于 2013-4-3 12:02
个人签名微信搜索公众号“EEWORLDBBS”快去添加关注吧!
242
貌似我做沙发来选这个片子嘛···
在我需要的温度范围内,且功耗低
个人签名以摆脱无知为起点,以力求专业为目标
低操作电压,低功耗啊
【直播时间】5月28日(周三)上午10:00
