本人最近在学习enet_io这个例程,可是程序下到板子里一直ping不通,由于没用lm3s8962的开发板,是自己焊的一块lm3s69911的板子,所以外围电路不一样,但以太网口都是一样的,所以我感觉应该是能ping通的,那些功能实现不了又是另外一码事,可是就是ping不通,请问是什么原因啊?我在主程序中将其已改成静态ip了,是不是哪个函数还要做简单修改?这个例程中只要哪个函数能顺利执行,就能实现和电脑的通讯,web能控制?
int main(void) { // unsigned long ulUser0, ulUser1; // unsigned char pucMACArray[8]; unsigned long ulIPAddr=0xC0A80619,ulNetMask=0xFFFFFF00,ulGWAddr=0xC0A80601; const unsigned char pucMACArray[] ={0X00,0x14,0x97,0xF0,0x00,0x01}; /****hmm************************/ #if PLL_EN == 0 /* Not use PLL 不使用PLL */ SysCtlClockSet(CCLK_DIV | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN | EXT_CLK); /* System clock= */ /* EXT_CLK/CCLK_DIV */ /* 系统时钟=EXT_CLK/CCLK_DIV */
#else /* Use PLL 使用PLL */ SysCtlClockSet(CCLK_DIV | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | EXT_CLK); /* System clock=200MHz/CCLK_DIV*/ /* 系统时钟=200MHz/CCLK_DIV */ #endif /********hmm**************/ // // Set the clocking to run directly from the crystal. // /* SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | SYSCTL_XTAL_8MHZ); */ // // Initialize the OLED display. // RIT128x96x4Init(1000000); // RIT128x96x4StringDraw("Web-Based I/O Control", 0, 0, 15); // RIT128x96x4StringDraw("Browser Message:", 0, 53, 15);
// // Enable and Reset the Ethernet Controller. // SysCtlPeripheralEnable(SYSCTL_PERIPH_ETH); SysCtlPeripheralReset(SYSCTL_PERIPH_ETH);
// // Enable Port F for Ethernet LEDs. // LED0 Bit 3 Output // LED1 Bit 2 Output // SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF); GPIOPinTypeEthernetLED(GPIO_PORTF_BASE, GPIO_PIN_2 | GPIO_PIN_3);
// // Configure SysTick for a periodic interrupt. // SysTickPeriodSet(SysCtlClockGet() / SYSTICKHZ); SysTickEnable(); SysTickIntEnable();
// // Enable processor interrupts. // IntMasterEnable();
// // Configure the hardware MAC address for Ethernet Controller filtering of // incoming packets. // // For the LM3S6965 Evaluation Kit, the MAC address will be stored in the // non-volatile USER0 and USER1 registers. These registers can be read // using the FlashUserGet function, as illustrated below. // /* FlashUserGet(&ulUser0, &ulUser1); if((ulUser0 == 0xffffffff) || (ulUser1 == 0xffffffff)) { // // We should never get here. This is an error if the MAC address // has not been programmed into the device. Exit the program. // RIT128x96x4StringDraw("MAC Address", 0, 16, 15); RIT128x96x4StringDraw("Not Programmed!", 0, 24, 15); while(1); }
// // Convert the 24/24 split MAC address from NV ram into a 32/16 split // MAC address needed to program the hardware registers, then program // the MAC address into the Ethernet Controller registers. // pucMACArray[0] = ((ulUser0 >> 0) & 0xff); pucMACArray[1] = ((ulUser0 >> 8) & 0xff); pucMACArray[2] = ((ulUser0 >> 16) & 0xff); pucMACArray[3] = ((ulUser1 >> 0) & 0xff); pucMACArray[4] = ((ulUser1 >> 8) & 0xff); pucMACArray[5] = ((ulUser1 >> 16) & 0xff); */ // // Initialze the lwIP library, using DHCP. // //lwIPInit(pucMACArray, 0, 0, 0, IPADDR_USE_DHCP); lwIPInit(pucMACArray,ulIPAddr, ulNetMask, ulGWAddr, IPADDR_USE_STATIC);
// // Setup the device locator service. // /* LocatorInit(); LocatorMACAddrSet(pucMACArray); LocatorAppTitleSet("EK-LM3S8962 enet_io"); */ // // Initialize a sample httpd server. // httpd_init(); /*********hmm****/ SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE); GPIODirModeSet(GPIO_PORTE_BASE, SYS, GPIO_DIR_MODE_OUT); /* 设置连接sys收发指示灯PE5为输出 */ GPIOPadConfigSet(GPIO_PORTE_BASE, SYS, /* 设置驱动强度和类型 */ GPIO_STRENGTH_4MA, /* 4mA的输出驱动强度 */ GPIO_PIN_TYPE_STD); /* 设置为推挽管脚 */ GPIOPinWrite(GPIO_PORTE_BASE, SYS, ~SYS); /******HMM*****/ // // Pass our tag information to the HTTP server. // http_set_ssi_handler(SSIHandler, g_pcConfigSSITags, NUM_CONFIG_SSI_TAGS);
// // Pass our CGI handlers to the HTTP server. // http_set_cgi_handlers(g_psConfigCGIURIs, NUM_CONFIG_CGI_URIS);
// // Initialize IO controls // io_init();
// // Loop forever. All the work is done in interrupt handlers. // while(1) { } } 上面是主程序,其余未做修改 |
