#define IAP_LOCATION 0x1FFF1FF1
#define iap_entry(a, b) ((void (*)())(IAP_LOCATION))(a, b)
unsigned long command[5] = {0,0,0,0,0};
unsigned long result[3]= {0,0,0};
* Function Name: IAP_PrepareSec
* Parameters: unsigned long StartSecNum -- Start Sector Number
* unsigned long EndSecNum -- End Sector Number
* Return: unsigned long -- Status Code
* Description: This command must be executed before executing "Copy RAM to Flash" or
* "Erase Sector(s)" command.
unsigned long IAP_PrepareSec (unsigned long StartSecNum, unsigned long EndSecNum)
if (EndSecNum < StartSecNum)
return IAP_STA_INVALD_PARAM;
* Function Name: IAP_CopyRAMToFlash
* Parameters: unsigned long dst -- Destination Flash address, should be a 256 byte boundary.
* unsigned long src -- Source RAM address, should be a word boundary
* unsigned long number -- 256 | 512 |1024 |4096
* Description: This command is used to program the flash memory.
unsigned long IAP_CopyRAMToFlash (unsigned long dst, unsigned long src,
unsigned long number)
command[0] = IAP_CMD_CopyRAMToFlash;
command[1] = dst;
command[2] = src;
command[3] = number;
command[4] = IAP_CLK / 1000; // Fcclk in KHz
iap_entry(command, result);
return result[0];
* Function Name: IAP_EraseSec
* Description: This command is used to erase a sector or multiple sectors of on-chip Flash
* memory.
unsigned long IAP_EraseSec (unsigned long StartSecNum, unsigned long EndSecNum)
* Function Name: IAP_BlankChkSec
* Description: This command is used to blank check a sector or mutilple sectors of on-chip
* Flash memory.
unsigned long IAP_BlankChkSec (unsigned long StartSecNum, unsigned long EndSecNum,
unsigned long * pResult)
* Function Name: IAP_ReadParID
* Parameters: unsigned long * PartID
* Description: This command is used to read the part identification number.
unsigned long IAP_ReadParID (unsigned long * PartID)
* Function Name: IAP_ReadBootVer
* Parameters: char * MajorVer
* char * MinorVer
* Description: This command is used to read the boot code version number.
unsigned long IAP_ReadBootVer (unsigned long * MajorVer, unsigned long * MinorVer)
command[0] = IAP_CMD_ReadBootVer;
*MajorVer = (result[1] & 0xff00)>>8;
*MinorVer = result[1] & 0xff;
return result[0];
* Function Name: IAP_Compare
* unsigned long number -- Should be in mutilple of 4
* Description: This command is used to compary the memory contents at two locations.
* NOTE: Compary result may not be correct when source or destination address contains
* any of the first 64 bytes starting from address zero. First 64 bytes can be re-mapped
* to RAM.
unsigned long IAP_Compare (unsigned long dst, unsigned long src,
unsigned long number, unsigned long *offset)
command[0] = IAP_CMD_Compare;
command[1] = dst;
command[2] = src;
if (result[0] == IAP_STA_COMPARE_ERROR)
*offset = result[1];
