各位大虾,我有一程序描述的是乒乓球游戏机,可是当球处于刚过网的时候,即i=4或5时,仿真击球会出现问题,还请大虾们能够解释下,多谢了。。
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; --引用必要的库函数和包集合 entity pingponggame is --实体名为pingponggame port(reset:in std_logic; clk:in std_logic; startbutton:in std_logic; --开始游戏输入端口 serve:in std_logic_vector(1 to 2); --发球输入端口 hit1,hit2:in std_logic; --甲和乙的击球输入端口 light:out std_logic_vector(1 to 8); --控制8个发光二极管的输出端口 score11,score12,score21,score22:out std_logic_vector(1 to 7)); --4个用于控制4个7段译码器的输出端口 end pingponggame; architecture game of pingponggame is type pingpong is (waitserve,light1on,ballmoveto2,allow2hit,light8on,ballmoveto1,allow1hit); ---设置7个状态,为枚举数据类型,记为pingpong signal state:pingpong; signal i:integer range 0 to 8; signal count1,count2:std_logic_vector(1 to 5):="00000"; ---内部计数器,是5位二进制变量 component mydecoder is port(binaryin: in std_logic_vector(1 to 5); bcdout1:out std_logic_vector(1 to 7); bcdout2:out std_logic_vector(1 to 7)); end component; ---调用记分译码器 begin process(clk) --状态机进程 begin if reset='1' then --异步置位 i<=0; count1<="00000"; count2<="00000"; elsif clk'event and clk='1' then --当处于时钟inclock上升沿时 if count1="10101"or count2="10101"then i<=0; count1<="00000"; count2<="00000"; elsif startbutton='0' then i<=0; count1<="00000"; count2<="00000"; else --以下case语句是程序中最关键的状态机部分 case state is when waitserve=> --进程处于等待发球状态 case serve is when "10"=> i<=1;state<=light1on; when "01"=> i<=8;state<=light8on; when others=> i<=0; end case; when light1on=> --进程处于第一盏灯亮状态 i<=2; if hit2='1' then i<=0; count1<=count1+1;state<=waitserve; else state<=ballmoveto2; end if; when light8on=> --进程处于第八盏灯亮状态 i<=7; if hit1='1' then i<=0; count2<=count2+1;state<=waitserve; else state<=ballmoveto1; end if; when ballmoveto1=> --进程处于球向甲移动状态 if hit1='1' then i<=0; count2<=count2+1; state<=waitserve; elsif i=5 then i<=4; state<=allow1hit; else i<=i-1; end if; when ballmoveto2=> --进程处于球向乙移动状态 if hit2='1'then i<=0; count1<=count1+1;state<=waitserve; elsif i=4 then i<=5; state<=allow2hit; else i<=i+1; end if; when allow1hit=> --进程处于允许甲击球状态 if hit1='1' then i<=i+1; state<=ballmoveto2; elsif i=1 then count2<=count2+1; i<=0; state<=waitserve; else i<=i-1; end if; when allow2hit=> --进程处于允许乙击球状态 if hit2='1'then i<=i-1; state<=ballmoveto1; elsif i=8 then count1<=count1+1; i<=0; state<=waitserve; else i<=i+1; end if; end case; end if; end if; end process; light<="10000000"when(i=1) else --进程处i信号控制发光二极管的亮暗 "01000000" when(i=2) else "00100000" when(i=3) else "00010000" when(i=4) else "00001000" when(i=5) else "00000100" when(i=6) else "00000010" when(i=7) else "00000001" when(i=8) else "00000000"; --其他情况所有发光二极管都暗 u0:mydecoder port map(count1,score11,score12); --用七段译码器显示甲的分数 u1:mydecoder port map(count2,score21,score22); --用七段译码器显示乙的分数 end game;
以下程序是调用的mydecoder程序,说明的是用七段数码管显示分数。。
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity mydecoder is port(binaryin:in std_logic_vector(1 to 5); --5位二进制码的输入端口 bcdout1:out std_logic_vector(1 to 7); --七段译码器输出端口 bcdout2:out std_logic_vector(1 to 7)); end mydecoder; architecture m of mydecoder is signal tembinaryin:std_logic_vector(1 to 5); begin process(binaryin) begin tembinaryin<=binaryin; case tembinaryin is when"00000"=>bcdout1<="1111110";bcdout2<="1111110"; --把0到9的5位二进制码转换成七段译码 when"00001"=>bcdout1<="1111110";bcdout2<="0110000"; when"00010"=>bcdout1<="1111110";bcdout2<="1101101"; when"00011"=>bcdout1<="1111110";bcdout2<="1111001"; when"00100"=>bcdout1<="1111110";bcdout2<="0110011"; when"00101"=>bcdout1<="1111110";bcdout2<="1011011"; when"00110"=>bcdout1<="1111110";bcdout2<="1011111"; when"00111"=>bcdout1<="1111110";bcdout2<="1110000"; when"01000"=>bcdout1<="1111110";bcdout2<="1111111"; when"01001"=>bcdout1<="1111110";bcdout2<="1111011"; when"01010"=>bcdout1<="0110000";bcdout2<="1111110";--把10到19的5位二进制码转换成七段译码 when"01011"=>bcdout1<="0110000";bcdout2<="0110000"; when"01100"=>bcdout1<="0110000";bcdout2<="1101101"; when"01101"=>bcdout1<="0110000";bcdout2<="1111001"; when"01110"=>bcdout1<="0110000";bcdout2<="0110011"; when"01111"=>bcdout1<="0110000";bcdout2<="1011011"; when"10000"=>bcdout1<="0110000";bcdout2<="1011111"; when"10001"=>bcdout1<="0110000";bcdout2<="1110000"; when"10010"=>bcdout1<="0110000";bcdout2<="1111111" when"10011"=>bcdout1<="0110000";bcdout2<="1111011"; when"10100"=>bcdout1<="1101101";bcdout2<="1111110";--把20到21的5位二进制码转换成七段译码 when"10101"=>bcdout1<="1101101";bcdout2<="0110000"; when others=>bcdout1<="1101101";bcdout2<="1111110";--如果5位二进制码不在0到21范围内,那么两个七段译码器都显示0 end case; end process; end m;
