3168|0
219
我的s3c2440定时器0无法进入中断, [复制链接]
我的定时器0设置如下,但是运行时如法进入中断,难道设置有错误??
void timer0_init(void)
    rSRCPND   =  rSRCPND  |   (0x1<<10);     //清空定时器0源请求
    rINTPND   =  rINTPND  |   (0x1<<10);     //清空定时器0中断请求
    rINTMSK   =  rINTMSK  &  ~(0x1<<10);     //打开定时器0中断
    //定时器0输入时钟频率 = PCLK/(预分频值+1)/(分频值),即25KHz=50MHz/(250*8)=50MHz/(2000)
    rTCFG0 = (rTCFG0 & ~(0xff))  | 249;  // prescaler1=249
    rTCFG1 = (rTCFG1 & ~(0x0f))  | (0x2); //divider:8,0b0010
    rTCNTB0 = 25000;     //让定时器0每隔1秒中断一次,则写入寄存器的数值为25000=25kHz/1Hz
    rTCON   =( rTCON & ~(0x0F) ) | (0xA); //自动重载?输出不取反,手动更新、启动定时器0
    rTCON   =  rTCON & ~(0x2);            //关闭手动更新
此帖出自ARM技术论坛
