在测量尺寸较小样本时,样本安装基底可能会成为测量误差的主要来源,这是其体积和表面电阻率造成的。通过(可能被污染的)基底表面阻止漏电流的方法是,使用两个分开的绝缘片,而不是将样本放置在一个绝缘片上。为了简化对不同尺寸小型样本的测试,安装硬件应当包括测微螺旋,以调整两个绝缘片之间的缝隙宽带。
When characterizing small samples, the substrate on which thesample is mounted can become a significant source of measure-ment error, as result of both its volume and surface resistivity.The obvious way to prevent any leakage current through a (pos-sibly contaminated) substrate surface is to use two insulator plates separated by a gap, rather than placing the sample on asingle plate. To simplify testing small samples of various sizes,the mounting hardware should include a micrometer screw toadjust the width of this gap.
图2: 使用液体镓(不会弄湿大多数材料)可以对同一晶体的不同方向进行测量。为了避免造成漏电流,样本要放置到两个蓝宝石片构成的间隙中。
Figure 2: Using liquid gallium, which doesn’t wet most materials, allows measuring conductivity in different directions on thesame crystal. To avoid creating leakage currents, the sample is placed on a gap formed by two sapphire plates.
了解更多信息 要想了解有关6517A型静电计/高阻表或者吉时利其他系列数字源表的更多信息,请点击http://www.keithley.com.cn/products/localizedproducts/highresistance/6517a,或者联系吉时利公司:全国免费电话800-810-1334手机用户请拨打440-650-1334。
登录吉时利官方微博(http://weibo.com/keithley)与专家进行互动。
吉时利仪器公司(中国)市场部 (T) 8008101334, 8610 82255010, 82255011 |
