3382|0
allegro规则设置里常见缩写的含义 [复制链接]
allegro规则设置里常见缩写词的含义
  Dsn Design整个设计
  DsnI Design Instance设计实例
  Lyr Layer层
  PrtD Part Definition
PrtI Part Instance
  GtI Gate Instance
  Bus Bus总线
  MGrp Matech Group
  DPr Differential Pair
  Xnet Extended Net
  Net Net网络
  PPr Pin Pair
  NCLs Net Class网络簇
  NCC Net Class-Class
  Rgn Region
  RCls Region Class
  RCC Region Class-Class
  Rslt Result
  PCS Physical Constraint Set
  SCS Spacing Constraint Set
  SNSC Same Net Spacing Constraint
  ECS Electrical Constraint Set
  RBnd Ratsnest Bundle鼠线束
此帖出自PCB设计论坛
