LM4F231H5QR QEI功能 ph1A口 读不到脉冲?条件是phA1接入10-100KHZ的频率,
unsigned int i; signed int j1=0,j0=0; // // The FPU should be enabled because some compilers will use floating- // point registers, even for non-floating-point code. If the FPU is not // enabled this will cause a fault. This also ensures that floating- // point operations could be added to this application and would work // correctly and use the hardware floating-point unit. Finally, lazy // stacking is enabled for interrupt handlers. This allows floating- // point instructions to be used within interrupt handlers, but at the // expense of extra stack usage. // //FPUEnable(); //FPULazyStackingEnable();
// // Set the clocking to run directly from the crystal. // SysCtlClockSet(SYSCTL_SYSDIV_2_5 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN |SYSCTL_XTAL_6MHZ);//80MHZ
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC); ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOG); ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_QEI1); ROM_GPIOPinTypeQEI(GPIO_PORTC_BASE,GPIO_PIN_5); ROM_GPIOPinTypeQEI(GPIO_PORTG_BASE,GPIO_PIN_4); ROM_QEIConfigure(QEI1_BASE,(QEI_CONFIG_CAPTURE_A|QEI_CONFIG_NO_RESET|QEI_CONFIG_CLOCK_DIR|QEI_CONFIG_NO_SWAP),0); //* 设置速度检测周期为 0.01秒 ROM_QEIVelocityConfigure(QEI1_BASE, QEI_VELDIV_1, 60000); ROM_QEIEnable(QEI1_BASE); ROM_QEIVelocityEnable(QEI1_BASE); // Loop forever while the timers run. while(1) { //* 读出上一个周期的速度计数值 */ i = ROM_QEIVelocityGet(QEI1_BASE); /* 转化为 转/分钟*/ i = (i*100*60)/(4*512); //读取当前方向 j1 = ROM_QEIDirectionGet(QEI1_BASE); j1=j1; ROM_SysCtlDelay(150*(ROM_SysCtlClockGet()/3000)); //DELAY 150MS }
以上仿真时候i ,j1 没反映 ;为什么?请高人指点
