6733|13
6482
管理员
TPS54260:2.5A 降压转换器DataSheet&用户手册 [复制链接]
芯片介绍:
The TPS54260 device is a 60V, 2.5A, step down regulator with an integrated high side MOSFET. Current mode control provides simple external compensation and flexible component selection. A low ripple pulse skip mode reduces the no load, regulated output supply current to 138µA. Using the enable pin, shutdown supply current is reduced to 1.3µA, when the enable pin is low.
Under voltage lockout is internally set at 2.5V, but can be increased using the enable pin. The output voltage startup ramp is controlled by the slow start pin that can also be configured for sequencing/tracking. An open drain power good signal indicates the output is within 94% to 107% of its nominal voltage.
A wide switching frequency range allows efficiency and external component size to be optimized.
DataSheet:
TPS54260.pdf (1.91 MB, 下载次数: 753)
应用手册:
Creating GSM Power Supply from TPS54260.pdf (1.17 MB, 下载次数: 2507)
Creating a Universal Car Charger for USB Devices From the TPS54240 and TPS2540A.pdf (1.02 MB, 下载次数: 2419)
用户指南:
TPS54260EVM-597 2.5-A, SWIFT™ Regulator Evaluation Module.pdf (307.55 KB, 下载次数: 167)
选择指南:
Altera FPGA 的电源管理 (Rev. B).pdf (199.4 KB, 下载次数: 117)
Point-of-Load (POL) Power Solutions for Industrial Designs.pdf (246.01 KB, 下载次数: 66)
Power Management for Altera FPGAs.pdf (155.57 KB, 下载次数: 66)
SWIFT Converter Product Portfolio.pdf (69.14 KB, 下载次数: 48)
SWIFT(TM) and Step-Down DCDC Converters Selector Guide.pdf (197.17 KB, 下载次数: 93)
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
好东西,谢谢!!!!!!!!  详情 回复 发表于 2014-5-27 10:21
个人签名微信搜索公众号“EEWORLDBBS”快去添加关注吧!
89
回复 楼主 EEWORLD社区 的帖子
这芯片性能不错的,正好用来做板子用上了,呵呵,感谢群主与TI的支持,感谢论坛 的支持.
63
芯片的温漂很低,稳定性能很好!其实我对电子所有器件都感兴趣!特别点的就是AD跟升降压芯片!
63
好东西!想拥有!
41
大电流的的转换器,真真给力啊
63
这东西绝对给力!
给力
给力 顶顶啊 初来乍到
155
支持.............
太给力了
个人签名http://www.tdhj.cn
器件很给力
器件很给力!
您这资料在哪下的,我一般也只能下载到个数据手册就完了
242
很好,比我的TPS54331给力,电压范围更大,收了:carnation:
个人签名以摆脱无知为起点,以力求专业为目标
我喜欢
大电流,宽电压,高效率
158
好东西,谢谢!!!!!!!!
