大侠们帮忙看看这个程序24c64读写程序 在keilc上运行时提示target not created,电脑是win7系统,跟这个有关系吗? #include<reg52.h> #define uchar unsigned char #define uint unsigned int #define ulong unsigned long #define writedeviceaddress oxa0//定义期间在ⅡC总线中得地址 #define readdeviceaddress oxa1 sbit wp=P2^5; sbit sda=P2^6; sbit scl=P2^7;
//延时函数 void DelayMs(unsigned int number) { unsigned char temp; for(;number!=0;number--) { for(temp=112;temp!=0;temp--) ; } } void Delay10us() { unsigned char k; for(k=10;k!=0;k--) ; } //开始总线 void start() { sda=1; Delay10us(); scl=1; Delay10us(); sda=0; Delay10us(); scl=0; Delay10us(); }
//结束总线 void stop() { sda=0; Delay10us(); sda=1; Delay10us(); scl=1; Delay10us(); }
void ack() { sda=0; Delay10us(); scl=1; Delay10us(); scl=0; Delay10us(); }
void nack() { sda=1; Delay10us(); scl=1; Delay10us(); scl=0; Delay10us(); }
bit send_byte(uchar d) { unsigned int i=8; bit bit_ack; while(i--) { if(d&0x80) sda=1; else sda=0; Delay10us(); scl=1; Delay10us(); scl=0; d=d<<1; } Delay10us(); sda=1; Delay10us(); scl=1; Delay10us(); bit_ack=sda; scl=0; Delay10us(); return bit_ack; }
uchar receive_byte() { uchar i=8,d; Delay10us(); sda=1; while(i--) { d=d<<1; Delay10us(); scl=1; Delay10us(); if(sda) d++; Delay10us(); scl=0; } return d; }
void AT24C64_write(void *mcu_address,uint AT24C64_address,uint count) { while(count--) { start(); send_byte(0xa0); send_byte(AT24C64_address/256); send_byte(AT24C64_address%256); send_byte(*(uchar*)mcu_address); stop(); DelayMs(10); (*(uchar*)mcu_address)++; AT24C64_address++; } }
void AT24C64_read(uchar *mcu_address,uint AT24C64_address,uint count) { while(count--) { start(); send_byte(0xa0); send_byte(AT24C64_address/256); send_byte(AT24C64_address%256); start(); send_byte(0xa1); nack(); stop(); DelayMs(10); (*(uchar*)mcu_address)++; AT24C64_address++; } }
