2218|0
294
2600A系列数字源表实现精密脉冲定时和直流偏置开启序列2 [复制链接]
2600A系列型数字源表[1]触发模型,允许用户在微秒数量级的精度对源电平和延迟时间进行编程。下面的命令序列将2602A[2]型数字源表SMUA[3]SMUB[4]开启时间延迟设置为200µs
The Series 2600A trigger model allows the user topreprogram source levels and delay times with accuracies onthe order of microseconds. The following command sequenceprograms a 200µs delay between turn-on of SMUA and SMUB ona Model 2602A.
reset()
smua.trigger.source.listv({5})
smua.trigger.source.action = smua.ENABLE
smub.trigger.source.listv({3.5})
smub.trigger.source.action = smub.ENABLE
--Program timer with a delay of 200us
trigger.timer[1].delay = 200e-6
trigger.timer[1].stimulus = smua.trigger.ARMED_EVENT_ID
trigger.timer[1].count = 1
trigger.timer[1].passthrough = false
smua.trigger.source.stimulus = 0
smub.trigger.source.stimulus = trigger.timer[1].EVENT_ID
smua.trigger.endsweep.action = smua.SOURCE_HOLD
smub.trigger.endsweep.action = smub.SOURCE_HOLD
smua.source.output = smua.OUTPUT_ON
smub.source.output = smub.OUTPUT_ON
smub.trigger.initiate()
smua.trigger.initiate()
4给出前述命令序列的结果。注意,通道之间的延迟大约是196.8µs(50% SMUA振幅到50% SMUB振幅间测量)
The results of the preceding command sequence are capturedin Figure 4. Note that the delay between the channels isapproximately 196.8µs (measured at 50% amplitude of SMUA to50% amplitude of SMUB).
4  2602A型数字源表的直流偏置序列。期望延迟是200µs。实际延迟是196.8µs
With Series 2600A instruments a minimum delay time of10µs seconds is possible.
利用2600A系列数字源表,可以实现10µs的最小时间延迟。
Figure 4. DC bias sequencing with Model 2602. Desired delay was 200µs. Actual delay was 196.8µs.
 了解更多信息
要想了解有关2600A系列数字源表或者吉时利其他系列数字源表的更多信息,或者咨询全套直接可用的多通道测试系统的价格,请点击https://admin.acrobat.com/_a16893448/p81871518/,或者联系吉时利公司:全国免费电话800-810-1334手机用户请拨打440-650-1334
登录吉时利官方微博(http://weibo.com/keithley)与专家进行互动。
吉时利仪器公司(中国)市场部
(T) 8008101334,  8610 82255010,  82255011
[1] 2600A http://www.keithley.com.cn/news/prod080923
[2] 2602Ahttp://www.keithley.com.cn/products/semiconductor/sourcemeasureunits/series2600sys/?mn=2602A
[3] SMUA http://www.keithley.com.cn/promo/wb/294/download_file/Bipolar_Tran_App.pdf
[4] SMUB http://www.keithley.com.cn/images/promoimages/Ban_2600_04-a.swf/view_swf
