学430 lanchpad板上的TimerA模拟uart通信,总是不成功,下面是TI的演示程序,只做了简单修改,可用串口调试软件观察还是没数据,不知道那个地方有问题
#include <msp430g2231.h>
#define RXD BIT2 // RXD on P1.2 #define TXD BIT1 // TXD on P1.1 #define Bitime_5 0x05*4 #define Bitime 13*4 unsigned int RXTXData=10; unsigned char BitCnt;
void TX_Byte (void); void RX_Ready (void); void InitializeClocks(void);
void main (void) { WDTCTL = WDTPW + WDTHOLD; InitializeClocks(); CCTL0 = OUT; // TXD Idle as Mark TACTL = TASSEL_2 + MC_2+ID_3; // ACLK, continuous mode P1SEL = TXD + RXD; // P1DIR = TXD; //
// Mainloop for (;;) { RX_Ready(); // UART ready to RX one Byte _BIS_SR(LPM3_bits + GIE); // Enter LPM3 w/ interr until char RXed TX_Byte(); // TX Back RXed Byte Received } }
// Function Transmits Character from RXTXData Buffer void TX_Byte (void) { BitCnt = 0xA; // Load Bit counter, 8data + ST/SP while (CCR0 != TAR) // Prevent async capture CCR0 = TAR; // Current state of TA counter CCR0 += Bitime; // Some time till first bit RXTXData |= 0x100; // Add mark stop bit to RXTXData RXTXData = RXTXData << 1; // Add space start bit CCTL0 = CCIS0 + OUTMOD0 + CCIE; // TXD = mark = idle while ( CCTL0 & CCIE ); // Wait for TX completion }
// Function Readies UART to Receive Character into RXTXData Buffer void RX_Ready (void) { BitCnt = 0x8; // Load Bit counter CCTL0 = SCS + OUTMOD0 + CM1 + CAP + CCIE; // Sync, Neg Edge, Cap }
// Timer A0 interrupt service routine #pragma vector=TIMERA0_VECTOR __interrupt void Timer_A (void) { CCR0 += Bitime; // Add Offset to CCR0
// TX if (CCTL0 & CCIS0) // TX on CCI0B? { if ( BitCnt == 0) CCTL0 &= ~ CCIE; // All bits TXed, disable interrupt else { CCTL0 |= OUTMOD2; // TX Space if (RXTXData & 0x01) CCTL0 &= ~ OUTMOD2; // TX Mark RXTXData = RXTXData >> 1; BitCnt --; } } // RX else { if( CCTL0 & CAP ) // Capture mode = start bit edge { CCTL0 &= ~ CAP; // Switch from capture to compare mode CCR0 += Bitime_5; } else { RXTXData = RXTXData >> 1; if (CCTL0 & SCCI) // Get bit waiting in receive latch RXTXData |= 0x80; BitCnt --; // All bits RXed? if ( BitCnt == 0) //>>>>>>>>>> Decode of Received Byte Here <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< { CCTL0 &= ~ CCIE; // All bits RXed, disable interrupt _BIC_SR_IRQ(LPM3_bits); // Clear LPM3 bits from 0(SR) } //>>>>>>>>>> Decode of Received Byte Here <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< } } } void InitializeClocks() { BCSCTL1 = CALBC1_1MHZ; DCOCTL = CALDCO_1MHZ; BCSCTL2 &= ~(DIVS_3); }
