11785|25
23
LaunchPad板上资源解读 [复制链接]
为支持LaunchPad活动,我这个万年潜水者也来发帖了。
MSP-EXP430G2 LaunchPad features:
• USB debugging and programming interface featuring a driverless installation and application UART
    serial communication with up to 9600 Baud
   板上的串口转 usb 最多只能到9600的波特率
3、仿真连接:
The power supply and the Spy-Bi-Wire JTAG signals TEST and RST must be connected with jumper J3 to allow the onboard emulation connection to the device.
Jtag看来只需要TEST RST两个接口,要断开仿真只需断开这两个跳线
The jumper 5 VCC also must be opened if the LaunchPad board is powered with an external power supply over J6. 如果在J6接外部电源,J3 Jumper 5VCC必须断开
Table 1. Jumper Connection J3 Between Emulator and Target
Jumper
Signal
TEST
Test mode for JTAG pins / Spy-Bi-Wire test clock input during programming and test
RST
Reset / Spy-Bi-Wire test data input/output during programming and test
RXD
UART receive data input
TXD
UART transmit data output
VCC
Target socket power supply voltage (power consumption test jumper)
可通过5脚来用电流表测整个板(包括外设)的耗电量
6J4
这里的TXD与板上的MSP430RXD相连接,RXDTXD相连,所以要是有eZ430可不用管什么跳线,它们的串口直接就可以通信了。而TESTRET脚则是直接与模拟器相连,不用跳线。
The signal lines XIN and XOUT can also be used as multipurpose I/Os or as a digital frequency input.
8It should be noted that there are two 0 ohms resistors (R28 and R29) that extend the crystal pin leads to the single-in-line break out connector (J2). In case of oscillator signal distortion which leads to a fault indication at the basic clock module, these resistors can be used to disconnect connector J2 from the oscillating lines.
R28R29 0欧,可移除以断开与J2的连接
以上从 MSP-EXP430G2 LaunchPad Experimenter Board User's Guide.pdf (Literature Number: SLAU318)里面摘录,这些我认为比较重要的。
支持一个,不错的帖子  详情 回复 发表于 2015-5-24 18:22
点赞 关注(2)
推荐
发现好像有点小错误,我也不是很懂,只是说出来大家讨论一下
第四项的那个应该是J3 的vcc要断开吧?J5 好像只是两个LED灯!
顶下
2751
裸片初长成(初级)
原帖由 ddllxxrr 于 2011-10-13 09:45 发表
同上,顶顶。
6066
90
裸片初长成(初级)
谢谢分享
42
受教了,多谢分享
26
好资料  谢谢分享
这个可以顶,呵呵
1632
好帖 留名
1729
这个一定要顶啊!
2734
裸片初长成(初级)
拿去看看,给楼主顶一个帖子,算是对于楼主给大家做贡献的一个鼓励吧,嗯嗯,值得值得,希望楼主继续努力啊!加油
个人签名我爱电子!
27
 顶器
2734
裸片初长成(初级)
上次板子回来之后,第一是没时间,第二是没资料,后来有资料了,现在也有时间了,多看看板子上有什么可以开发的资源,具体的了解一下,不能白买了啊
个人签名我爱电子!
45
加油
59
多谢分享
学习了,吸取大家ㄉ重点
519
回复 10楼 smiling916 的帖子
你说的对,楼主的帖子确实有点表述不当。J5是LED1和LED2,J6接外接电源,应该是J3的VCC断开。
519
支持一下,不过希望楼主下次能认真点
23
回复 楼主 TrueElement 的帖子
超过7200小时,编辑不了了,应该为 “J3的Jumper 5才对
不好意思,大意了。
