3455|7
LM3S1911如何读P口 [复制链接]
LM3S1911如何读P口,就是如何把P口,比如PF口的状态读到一个字符变量,初学,请各位不吝赐教,谢谢,在线等
学习了 [ 本帖最后由 boyong 于 2011-10-16 13:09 编辑 ]  详情 回复 发表于 2011-10-16 13:08
2749
裸片初长成(初级)
原帖由 yuanyc5877 于 2011-10-11 21:05 发表 LM3S1911如何读P口,就是如何把P口,比如PF口的状态读到一个字符变量,初学,请各位不吝赐教,谢谢,在线等
翻阅一下GPIO的相关库函数即可gpio.c,读整个口的话,用HWREG()函数应该可以吧。
1803
回复 楼主 yuanyc5877 的帖子
首先 GPIO 口是做为输入的。
用下面的 API ,返回的是 Long
//! Reads the values present of the specified pin(s).
//! \param ulPort is the base address of the GPIO port.
//! \param ucPins is the bit-packed representation of the pin(s).
//! The values at the specified pin(s) are read, as specified by \e ucPins.
//! Values are returned for both input and output pin(s), and the value
//! for pin(s) that are not specified by \e ucPins are set to 0.
//! The pin(s) are specified using a bit-packed byte, where each bit that is
//! set identifies the pin to be accessed, and where bit 0 of the byte
//! represents GPIO port pin 0, bit 1 represents GPIO port pin 1, and so on.
//! \return Returns a bit-packed byte providing the state of the specified
//! pin, where bit 0 of the byte represents GPIO port pin 0, bit 1 represents
//! GPIO port pin 1, and so on.  Any bit that is not specified by \e ucPins
//! is returned as a 0.  Bits 31:8 should be ignored.
long
GPIOPinRead(unsigned long ulPort, unsigned char ucPins)
    // Check the arguments.
    ASSERT(GPIOBaseValid(ulPort));
    // Return the pin value(s).
    return(HWREG(ulPort + (GPIO_O_DATA + (ucPins << 2))));
谢谢,就用这个HWREGB在试,可能是前面没搞对,我再看看。再次感谢
2749
裸片初长成(初级)
原帖由 yuanyc5877 于 2011-10-11 21:22 发表 谢谢,就用这个HWREGB在试,可能是前面没搞对,我再看看。再次感谢
参考一下hw_types.h里面的定义吧
// Macros for hardware access, both direct and via the bit-band region.
#define HWREG(x)                                                              \
        (*((volatile unsigned long *)(x)))
#define HWREGH(x)                                                             \
        (*((volatile unsigned short *)(x)))
#define HWREGB(x)                                                             \
        (*((volatile unsigned char *)(x)))
#define HWREGBITW(x, b)                                                       \
        HWREG(((unsigned long)(x) & 0xF0000000) | 0x02000000 |                \
              (((unsigned long)(x) & 0x000FFFFF) << 5) | ((b) << 2))
#define HWREGBITH(x, b)                                                       \
        HWREGH(((unsigned long)(x) & 0xF0000000) | 0x02000000 |               \
#define HWREGBITB(x, b)                                                       \
        HWREGB(((unsigned long)(x) & 0xF0000000) | 0x02000000 |               \
547
现在,解决了木。。
个人签名嵌入式培训www.51great.org
2749
裸片初长成(初级)
閺屻儳婀呴張顒€绗橀崗銊╁劥鐠併劏顔戦敍宀冾嚞閻ц缍�閹存牞鈧拷濞夈劌鍞�
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
