3031|0
常用晶振频率 [复制链接]
常用晶振频率: 49US,ZTT 4.00mg,DAY,DY,1.8432MHz,18.432MHZ,25MHZ,4 MHZ,12 MHZ,16 MHZ,13 MHZ,21.47727 MHZ,33.8688 MHZ,3.6864 MHZ,10.245 MHZ,14.7456 MHZ,7.9296875 MHZ,24.576 MHZ,7.2 MHZ,22.1184 MHZ,21.504 MHZ,1.8432 MHZ,13.25 MHZ,24 MHZ,2 MHZ,9.8304 MHZ,20.945 MHZ,9.216 MHZ,14.31818 MHZ,76.8 MHZ,7.3728 MHZ,11.0592 MHZ,44.545 MHZ,40 MHZ,16.384 MHZ,27 MHZ,26 MHZ,48 MHZ,45 MHZ,90 MHZ,130 MHZ,112.32 MHZ,130 MHZ,45.1 MHZ,110.52 MHZ,21.4 MHZ,106.95 MHZ,128.45 MHZ,21.4 MHZ,38.85 MHZ,70 MHZ,45.1 MHZ,26.050 MHZ,8.192 MHZ,44 MHZ,15.36 MHZ,20 MHZ,125 MHZ,25 MHZ,50 MHZ,27 MHZ,65 MHZ,17.734475 MHZ,100 MHZ,32.768 KHZ,31.5 MHZ,29.5 MHZ,56 MHZ,12.288 MHZ,18.432 MHZ,33.333 MHZ,26.975 MHZ,27.145 MHZ,75 MHZ,153.6 MHZ,150 MHZ,455 KHZ,4.91 MHZ,6 MHZ,16.9344 MHZ,10 MHZ,3.64 MHZ,4.1952 MHZ,30 MHZ,8.38 MHZ,4.09 MHZ,16.8 MHZ,4.25 MHZ,9.83 MHZ,33.8688 MHZ,10.7 MHZ,10.8 MHZ,32 MHZ,5 MHZ,14 MHZ,17.28 MHZ,2.68 MHZ,3 MHZ,12.5 MHZ,3.2 MHZ,465 MHZ,446 MHZ,1960 MHZ,433.92 MHZ,225 MHZ,1842 MHZ.5 MHZ,942.5 MHZ,243.5 MHZ,85.38 MHZ,1489 MHZ,1441 MHZ,897.5 MHZ,280 MHZ,926.5 MHZ,903.5 MHZ,360 MHZ,881.5 MHZ,947.5 MHZ,340 KHZ,400 KHZ,26 MHZ,10.245 MHZ,1880 MHZ,1747.5 MHZ,1960 MHZ,1575.45 MHZ,1847 MHZ,842.5 MHZ,1842.5 MHZ,315 MHZ,310 MHZ,19.68 MHZ,13.56 MHZ,19.680 MHZ,16.367667 MHZ,16.8 MHZ,19.44 MHZ,15.360 MHZ,9.6 MHZ,12.8 MHZ,24.5535 MHZ,19.8 MHZ,16.368 MHZ,19.680 MHZ, 19.2 MHZ,897MHZ,1747 MHZ,898 MHZ,1750 MHZ,897.5 MHZ,1323 MHZ,1964 MHZ,1016 MHZ, 3.579545 MHZ,4.433619 MHZ,10.250 MHZ,3.575611 MHZ,4.332 MHZ,33 MHZ,36.860 MHZ,49 MHZ,24.6 MHZ,26.800 MHZ,24.0014 MHZ,16 MHZ,15.4 MHZ,15.360 MHZ,14.745 MHZ,13.5 MHZ,56.448 MHZ,9.216 MHZ,311.06 MHZ,73.720 MHZ,67.750 MHZ,61.5 MHZ,60 MHZ,40.32 MHZ,39.168 MHZ,37 MHZ,35.4689 MHZ,33.86 MHZ,33.8688 MHZ,32.256 MHZ,32.1 MHZ,32 MHZ,28 MHZ.704 MHZ,28.224 MHZ,28.63 MHZ,26.8 MHZ,24.6 MHZ,21.47727 MHZ,20.25 MHZ,19.6608 MHZ,19.3125 MHZ,17.734 MHZ,15.4 MHZ,15.5 MHZ,15.36 MHZ,14.74 MHZ,12.288 MHZ,11.5 MHZ,11.15 MHZ,11.013 MHZ,10.245 MHZ,10.240 MHZ,10.238 MHZ,10.01 MHZ,9.8 MHZ,9.8304 MHZ,9.6 MHZ,7.732 MHZ,7.2 MHZ,5.927 MHZ,4.49923 MHZ,4.5 MHZ,4.194 MHZ,4.140 MHZ,4.096 MHZ,4.032 MHZ,3.6864 MHZ,19.2 MHZ,21.504 MHZ,16.8 MHZ,12.6 MHZ,12.8 MHZ,16.9344 MHZ,11.150 MHZ,21.245 MHZ,,21.24 MHZ,42.105 MHZ,24.431 MHZ,33.868 MHZ,23.040 MHZ,600KHZ,96 MHZ,100KHZ,200KHZ,307.200 MHZ,153.600 MHZ,42.496 MHZ,38.4 MHZ,76.8 MHZ,20.945 MHZ,3.579 MHZ,4.433 MHZ,27.7 MHZ,28.8 MHZ,6.772 MHZ,7.3728 MHZ,7.6 MHZ,29.4912 MHZ,70.5 MHZ,27 MHZ,4.915 MHZ,4.195 MHZ,66.66 MHZ,60 MHZ, 11.288 MHZ,54 MHZ,NDK 7.1137 MHZ,NDK 6.431091MHZ,DY 6.000MHZ,DY 7.000MHZ,40PF,33PF,30PF,27PF,22PF,20PF,16PF,18PF,15PF,12.5PF,11PF,8PF.3.2M,3.47M,340 K HZ,ZTB 3
此帖出自单片机论坛
