7990|4
2606
今天小用了一下ECAP的捕获功能 [复制链接]
void InitECapture()
   ECap1Regs.ECEINT.all = 0x0000;             // Disable all capture interrupts
   ECap1Regs.ECCLR.all = 0xFFFF;              // Clear all CAP interrupt flags
   ECap1Regs.ECCTL1.bit.CAPLDEN = 0;          // Disable CAP1-CAP4 register loads
   ECap1Regs.ECCTL2.bit.TSCTRSTOP = 0;        // Make sure the counter is stopped
   // Configure peripheral registers
  // ECap1Regs.ECCTL2.bit.CONT_ONESHT = 1;      // One-shot
 /*  ECap1Regs.ECCTL2.bit.CONT_ONESHT = EC_CONTINUOUS;
   ECap1Regs.ECCTL2.bit.STOP_WRAP =
 //  ECap1Regs.ECCTL2.bit.STOP_WRAP = 3;        // Stop at 4 events
   ECap1Regs.ECCTL1.bit.CAP1POL = 1;          // Falling edge
   ECap1Regs.ECCTL1.bit.CAP2POL = 0;          // Rising edge
   ECap1Regs.ECCTL1.bit.CAP3POL = 1;          // Falling edge
   ECap1Regs.ECCTL1.bit.CAP4POL = 0;          // Rising edge
   ECap1Regs.ECCTL1.bit.CTRRST1 = 1;          // Difference operation
   ECap1Regs.ECCTL1.bit.CTRRST2 = 1;          // Difference operation
   ECap1Regs.ECCTL1.bit.CTRRST3 = 1;          // Difference operation
   ECap1Regs.ECCTL1.bit.CTRRST4 = 1;          // Difference operation
   ECap1Regs.ECCTL2.bit.SYNCI_EN = 1;         // Enable sync in
   ECap1Regs.ECCTL2.bit.SYNCO_SEL = 0;        // Pass through
   ECap1Regs.ECCTL1.bit.CAPLDEN = 1;          // Enable capture units
// Code snippet for CAP mode Delta Time, Rising and Falling
// edge triggers
// Initialization Time
// ECAP module 1 config
 ECap1Regs.ECCTL1.bit.CAP1POL = EC_RISING;
 ECap1Regs.ECCTL1.bit.CAP2POL = EC_FALLING;
 ECap1Regs.ECCTL1.bit.CAP3POL = EC_RISING;
 ECap1Regs.ECCTL1.bit.CAP4POL = EC_FALLING;
 ECap1Regs.ECCTL1.bit.CTRRST1 = EC_DELTA_MODE;
 ECap1Regs.ECCTL1.bit.CTRRST2 = EC_DELTA_MODE;
 ECap1Regs.ECCTL1.bit.CTRRST3 = EC_DELTA_MODE;
 ECap1Regs.ECCTL1.bit.CTRRST4 = EC_DELTA_MODE;
 ECap1Regs.ECCTL1.bit.CAPLDEN = EC_ENABLE;
 ECap1Regs.ECCTL1.bit.PRESCALE = EC_DIV1;
 ECap1Regs.ECCTL2.bit.CAP_APWM = EC_CAP_MODE;
 ECap1Regs.ECCTL2.bit.SYNCO_SEL = EC_SYNCO_DIS;
 ECap1Regs.ECCTL2.bit.SYNCI_EN = EC_DISABLE;
 ECap1Regs.ECCTL2.bit.TSCTRSTOP = EC_RUN; // Allow TSCTR to run
  //  ECap1Regs.ECCTL2.bit.TSCTRSTOP = 1;        // Start Counter
  //  ECap1Regs.ECCTL2.bit.REARM = 1;            // arm one-shot
  //  ECap1Regs.ECCTL1.bit.CAPLDEN = 1;          // Enable CAP1-CAP4 register loads
    ECap1Regs.ECEINT.bit.CEVT4 = 1;            // 4 events = interrupt
interrupt void ecap1_isr(void)
   // Cap input is syc'ed to SYSCLKOUT so there may be
   // a +/- 1 cycle variation
   if(ECap1Regs.CAP2 > EPwm3Regs.TBPRD*2+1 || ECap1Regs.CAP2 < EPwm3Regs.TBPRD*2-1)
       Fail();
   if(ECap1Regs.CAP3 > EPwm3Regs.TBPRD*2+1 || ECap1Regs.CAP3 < EPwm3Regs.TBPRD*2-1)
       Fail();
   if(ECap1Regs.CAP4 > EPwm3Regs.TBPRD*2+1 || ECap1Regs.CAP4 < EPwm3Regs.TBPRD*2-1)
       Fail();
   ECap1IntCount++;
   if(EPwm3TimerDirection == EPWM_TIMER_UP)
        if(EPwm3Regs.TBPRD < PWM3_TIMER_MAX)
           EPwm3Regs.TBPRD++;
        else
           EPwm3TimerDirection = EPWM_TIMER_DOWN;
           EPwm3Regs.TBPRD--;
   else
        if(EPwm3Regs.TBPRD > PWM3_TIMER_MIN)
           EPwm3Regs.TBPRD--;
        else
           EPwm3TimerDirection = EPWM_TIMER_UP;
           EPwm3Regs.TBPRD++;
// Run Time ( e.g. CEVT1 triggered ISR call)
// Note: here Time-stamp directly represents the Duty cycle values.
 DutyOnTime1 = ECap1Regs.CAP2; // Fetch Time-Stamp captured at T2
 DutyOffTime1 = ECap1Regs.CAP3; // Fetch Time-Stamp captured at T3
 DutyOnTime2 = ECap1Regs.CAP4; // Fetch Time-Stamp captured at T4
 DutyOffTime2 = ECap1Regs.CAP1; // Fetch Time-Stamp captured at T1
 Period1 = DutyOnTime1 + DutyOffTime1;
 Period2 = DutyOnTime2 + DutyOffTime2;
   ECap1PassCount++;
 //  ECap1Regs.ECCLR.bit.CEVT1 = 1;
  // ECap1Regs.ECCLR.bit.INT = 1;
   // Acknowledge this interrupt to receive more interrupts from group 4
   ECap1Regs.ECCLR.bit.CEVT4  = 1;
   PieCtrlRegs.PIEACK.all = PIEACK_GROUP4;
还是有小插曲应该清除CEVT4的标志位的,偶开始清了CEVT1的,发现进了中断后就一直反复进中断。
后来一查就发现了。
大家别像偶一样粗心。
楼主,我现在也在用ecap这块,可不知道怎么回事,进不来中断,能不能指点一下  详情 回复 发表于 2011-11-21 15:26
个人签名工程 = 数学+物理+经济
307
问一下版主,用过黑鹰的USB2000仿真器么?
不知道这款仿真器配合CCS4能够仿真,我平时只是用来烧写,仿真的时候不能打断点,但是能单步调试,不知道什么原因?
2606
你说的,没听过啊
个人签名工程 = 数学+物理+经济
2606
可以啊。把问题贴上来。我们一起看看
个人签名工程 = 数学+物理+经济
