LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY a8255tb IS
GENERIC (
CLKOffset : TIME := 0 ns;
CLKPeriod : TIME := 200 ns;
LoopDelay : TIME := 50 ns
PORT (
RESET_Stim : OUT std_logic;
CLK_Stim : OUT std_logic;
nCS_Stim : OUT std_logic;
nRD_Stim : OUT std_logic;
nWR_Stim : OUT std_logic;
A_Stim : OUT std_logic_vector (1 DOWNTO 0);
DIN_Stim : OUT std_logic_vector (7 DOWNTO 0);
PAIN_Stim : OUT std_logic_vector (7 DOWNTO 0);
PBIN_Stim : OUT std_logic_vector (7 DOWNTO 0);
PCIN_Stim : OUT std_logic_vector (7 DOWNTO 0);
DOUT_Resp : IN std_logic_vector (7 DOWNTO 0);
PAOUT_Resp : IN std_logic_vector (7 DOWNTO 0);
PAEN_Resp : IN std_logic;
PBOUT_Resp : IN std_logic_vector (7 DOWNTO 0);
PBEN_Resp : IN std_logic;
PCOUT_Resp : IN std_logic_vector (7 DOWNTO 0);
PCEN_Resp : IN std_logic_vector (7 DOWNTO 0)
END a8255tb;
-- Architecture Body
ARCHITECTURE MainTest OF a8255tb IS
SIGNAL PA : std_logic_vector (7 DOWNTO 0);
SIGNAL PB : std_logic_vector (7 DOWNTO 0);
SIGNAL PC : std_logic_vector (7 DOWNTO 0);
TYPE LoopBackModeType IS (Mode0, Mode1_AToB, Mode1_BToA, Mode2_AToB, Mode2_BToA);
SIGNAL LoopBackMode : LoopBackModeType;
BEGIN
CLKClockPrc : PROCESS
BEGIN
CLK_Stim <= '0';
WAIT FOR CLKOffset;
LOOP
CLK_Stim <= '0';
WAIT FOR CLKPeriod/2;
CLK_Stim <= '1';
END LOOP;
END PROCESS CLKClockPrc;
GeneralStimulus : PROCESS
CONSTANT PortA : std_logic_vector(1 DOWNTO 0) := "00";
CONSTANT PortB : std_logic_vector(1 DOWNTO 0) := "01";
CONSTANT PortC : std_logic_vector(1 DOWNTO 0) := "10";
CONSTANT ControlReg : std_logic_vector(1 DOWNTO 0) := "11";
CONSTANT ChangeBit : std_logic_vector(1 DOWNTO 0) := "11";
-- Define procedure to initialize inputs to default values and reset
PROCEDURE InitInputsAndReset IS
BEGIN
nCS_Stim <= '1';
nRD_Stim <= '1';
nWR_Stim <= '1';
A_Stim <= "00";
DIN_Stim <= "00000000";
RESET_Stim <= '1';
WAIT FOR CLKPeriod * 2;
RESET_Stim <= '0';
END InitInputsAndReset;
-- Define procedure to read any register and compare to an expected value
PROCEDURE ReadReg (Address : IN std_logic_vector(1 DOWNTO 0);
ExpectedData : IN bit_vector(7 DOWNTO 0)
) IS
BEGIN
A_Stim <= Address;
WAIT FOR CLKPeriod;
nCS_Stim <= '0';
nRD_Stim <= '0';
WAIT FOR CLKPeriod;
ASSERT (DOUT_Resp = to_stdlogicvector(ExpectedData))
REPORT "Read Data does not match Expected Data" SEVERITY WARNING;
nCS_Stim <= '1';
nRD_Stim <= '1';
WAIT FOR CLKPeriod;
END ReadReg;
-- Define procedure to write any register
PROCEDURE WriteReg(Address : IN std_logic_vector(1 DOWNTO 0);
) IS
BEGIN
A_Stim <= Address;
nCS_Stim <= '0';
DIN_Stim <= to_stdlogicvector(Data);
WAIT FOR CLKPeriod;
nWR_Stim <= '0';
WAIT FOR CLKPeriod;
nWR_Stim <= '1';
nCS_Stim <= '1';
END WriteReg;
-- Main Test Program
BEGIN
ASSERT false REPORT "START MODE 0 TEST" SEVERITY NOTE;
-- Set Loop Back Mode
LoopBackMode <= Mode0;
-- Reset chip and set inputs to default values
InitInputsAndReset;
-- Read Control Reg after reset
ReadReg(ControlReg, x"9B"); -- Resets to Mode 0, all inputs
-- Load Port output registers before changing mode and direction
WriteReg(PortA, x"AA");
WriteReg(PortB, x"55");
WriteReg(PortC, x"F0");
-- Set Mode 0, Port A out, B in, C upper in, C lower out
WriteReg(ControlReg, x"8A");
-- Read all ports
ReadReg(PortA, x"AA");
ReadReg(PortB, x"AA");
ReadReg(PortC, x"00");
-- Set Mode 0, Port A in, B out, C upper out, C lower in
WriteReg(ControlReg, x"98");
WriteReg(ControlReg, x"91");
-- Read all ports
ReadReg(PortA, x"55");
ReadReg(PortB, x"55");
ReadReg(PortC, x"FF");
-- Load Port output registers with inverse
WriteReg(PortA, x"55");
WriteReg(PortB, x"AA");
WriteReg(PortC, x"0F");
-- Read all ports
-- Set Mode 0, Port A out, B in, C upper out, C lower in
WriteReg(ControlReg, x"83");
-- Read all ports
-- Test Port C Upper Set/Reset Bit Feature
WriteReg(ChangeBit, x"09"); -- Set Port C (4)
ReadReg(PortC, x"11");
WriteReg(ChangeBit, x"0B"); -- Set Port C (5)
ReadReg(PortC, x"33");
WriteReg(ChangeBit, x"0D"); -- Set Port C (6)
ReadReg(PortC, x"77");
WriteReg(ChangeBit, x"0F"); -- Set Port C (7)
WriteReg(ChangeBit, x"08"); -- Reset Port C (4)
ReadReg(PortC, x"EE");
WriteReg(ChangeBit, x"0A"); -- Reset Port C (5)
ReadReg(PortC, x"CC");
WriteReg(ChangeBit, x"0C"); -- Reset Port C (6)
ReadReg(PortC, x"88");
WriteReg(ChangeBit, x"0E"); -- Reset Port C (7)
WriteReg(PortC, x"00");
-- Test Port C Lower Set/Reset Bit Feature
WriteReg(ChangeBit, x"01"); -- Set Port C (0)
WriteReg(ChangeBit, x"03"); -- Set Port C (1)
WriteReg(ChangeBit, x"05"); -- Set Port C (2)
WriteReg(ChangeBit, x"07"); -- Set Port C (3)
WriteReg(ChangeBit, x"00"); -- Reset Port C (0)
WriteReg(ChangeBit, x"02"); -- Reset Port C (1)
WriteReg(ChangeBit, x"04"); -- Reset Port C (2)
WriteReg(ChangeBit, x"06"); -- Reset Port C (3)
ASSERT false REPORT "START MODE 1 TEST" SEVERITY NOTE;
LoopBackMode <= Mode1_AToB;
InitInputsAndReset;
-- Set Mode 1, Port A out, B in and check Port C Status
WriteReg(ControlReg, x"A6");
ReadReg(PortC, x"80"); -- Read Port C Status (only OBFA is set)
WriteReg(PortA, x"11");
-- Read all ports
ReadReg(PortB, x"11");
-- Do same test with interrupt enables on
WriteReg(ChangeBit, x"0D"); -- Set Port A Int Enable (Port C (6))
WriteReg(ChangeBit, x"05"); -- Set Port B Int Enable (Port C (2))
ReadReg(PortC, x"C4"); -- Read Port C Status (OBFA, INTEA, and INTEB are set)
WriteReg(PortA, x"88");
ReadReg(PortC, x"C7"); -- Read Port C Status (everything but INTA is set)
ReadReg(PortB, x"88");
ReadReg(PortC, x"CC"); -- Read Port C Status
-- Load Port output registers to bring down INTA
WriteReg(PortA, x"00");
-- REVERSE LOOPBACK DIRECTION
LoopBackMode <= Mode1_BToA;
InitInputsAndReset;
WriteReg(ControlReg, x"B4");
ReadReg(PortC, x"02"); -- Read Port C Status (only OBFB is set)
WriteReg(PortB, x"33");
-- Read all ports
ReadReg(PortA, x"33");
WriteReg(ChangeBit, x"09"); -- Set Port A Int Enable (Port C (4))
ReadReg(PortC, x"16"); -- Read Port C Status (OBFA, INTEA, and INTEB are set)
WriteReg(PortB, x"44");
ReadReg(PortC, x"3E"); -- Read Port C Status (everything but INTB is set)
ReadReg(PortA, x"44");
ReadReg(PortC, x"17"); -- Read Port C Status (INTB and OBFB set)
-- Load Port output registers to bring down INTB
WriteReg(PortB, x"FF");
ASSERT false REPORT "START MODE 2 TEST" SEVERITY NOTE;
LoopBackMode <= Mode2_AToB;
InitInputsAndReset;
-- Set Port A to Mode 2, B in and check Port C Status
WriteReg(ControlReg, x"C6");
WriteReg(ChangeBit, x"0F"); -- Set Port C (7) --OBFA
WriteReg(ChangeBit, x"0C"); -- Reset Port C (6) --INTE1
WriteReg(ChangeBit, x"0A"); -- Reset Port C (5) --IBFA
WriteReg(ChangeBit, x"08"); -- Reset Port C (4) --INTE2
WriteReg(ChangeBit, x"06"); -- Reset Port C (3) --INTRA
WriteReg(ChangeBit, x"04"); -- Reset Port C (2) --INTEB
WriteReg(ChangeBit, x"02"); -- Reset Port C (1) --IBFB
WriteReg(ChangeBit, x"00"); -- Reset Port C (0) --INTRB
-- Read all ports
LoopBackMode <= Mode2_BToA;
InitInputsAndReset;
-- Set Port A to Mode 2, B out and check Port C Status
WriteReg(ControlReg, x"C4");
WriteReg(ChangeBit, x"03"); -- Set Port C (1) --OBFB
ReadReg(PortC, x"82"); -- Read Port C Status (OBFA, OBFB is set)
WriteReg(PortB, x"66");
-- Read all ports
ReadReg(PortA, x"66");
ReadReg(PortC, x"82"); -- Read Port C Status (only OBFA is set)
ReadReg(PortC, x"96"); -- Read Port C Status (OBFA, INTEA2, and INTEB are set)
WriteReg(PortB, x"88");
ReadReg(PortC, x"BE"); -- Read Port C Status (everything but INTRB is set)
ReadReg(PortA, x"88");
ReadReg(PortC, x"97"); -- Read Port C Status
WriteReg(PortB, x"00");
ASSERT false REPORT "END OF TEST" SEVERITY NOTE;
WAIT;
END PROCESS GeneralStimulus;
-- Process to loop PA to PB, and PC upper to PC lower
OutputBufferPrc : Process (PAEN_Resp, PBEN_Resp, PCEN_Resp, PAOUT_Resp, PBOUT_Resp, PCOUT_Resp)
BEGIN
IF (PAEN_Resp = '1') THEN
PA <= PAOUT_Resp AFTER LoopDelay;
ELSE
PA <= "ZZZZZZZZ" AFTER LoopDelay;
END IF;
IF (PBEN_Resp = '1') THEN
PB <= PBOUT_Resp AFTER LoopDelay;
ELSE
PB <= "ZZZZZZZZ" AFTER LoopDelay;
END IF;
FOR I IN 0 TO 7 LOOP
IF (PCEN_Resp(I) = '1') THEN
PC(I) <= PCOUT_Resp(I) AFTER LoopDelay;
ELSE
PC(I) <= 'Z' AFTER LoopDelay;
END IF;
END LOOP;
END PROCESS OutputBufferPrc;
-- -- Output buffer assignments
PAIN_Stim <= PA;
PBIN_Stim <= PB;
PCIN_Stim <= PC;
-- Loop back assignments
LoopBackPrc : Process (LoopBackMode, PA, PB, PC)
BEGIN
PAIN_Stim <= PB ;
PBIN_Stim <= PA ;
IF (LoopBackMode = Mode0) THEN
PCIN_Stim (7 DOWNTO 4) <= PC (3 DOWNTO 0) ;
PCIN_Stim (3 DOWNTO 0) <= PC (7 DOWNTO 4) ;
ELSIF (LoopBackMode = Mode1_BToA) THEN
PCIN_Stim (7) <= PC (7) ;
PCIN_Stim (6) <= PC (6) ;
PCIN_Stim (5) <= PC (5) ;
PCIN_Stim (4) <= PC (1) ; -- OBFB to STBA
PCIN_Stim (3) <= PC (3) ;
PCIN_Stim (2) <= NOT PC (5) ; -- IBFA to ACKB
PCIN_Stim (1) <= PC (1) ;
PCIN_Stim (0) <= PC (0) ;
ELSIF (LoopBackMode = Mode2_BToA) THEN
PCIN_Stim (6) <= '1';
ELSIF (LoopBackMode = Mode1_AToB) THEN
PCIN_Stim (2) <= PC (7) ; -- OBFA to STBB
PCIN_Stim (4) <= PC (4) ;
PCIN_Stim (6) <= NOT PC (1) ; -- IBFB to ACKA
ELSIF (LoopBackMode = Mode2_AToB) THEN
PCIN_Stim (4) <= '1';
END IF;
END PROCESS LoopBackPrc;
END MainTest; |
