3657|2
84
在keill中模拟时有时候计算数值哪里出错,纠结很久了,求助 [复制链接]
code unsigned  int adc[]={228,221,213,204,194,183,172,160,147,135,122,110,99,88,78,69,61,54,48,42,38,33,29,26,23,20,18,16,14,13,11 };
code unsigned int tem[]={0,5,10,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100,105,110,115,120,125,130,135,140,145,150};
code  unsigned int xielv[]={71,63,56,50,45,45,42,38,42,38,42,45,45,50,56,63,71,83,83,125,100,125,167,167,167,250,250,250,500,250 };
void temp_tr()
  unsigned char i;
  for(i=0;i<30;i++)
if((b>adc[i+1])&&(b<=adc))
  Temp0=adc-b;
  Temp1=(xielv)*(Temp0);//这里有时候会出现乱码
  if(Temp1==0)
  T=tem;
  else
  T=Temp1/100+tem;
if(b<11)
  T=0;
P2_0=0;
     P1_0=1;
if(b>228||b==228)
    T=0;
b是ad值,0~228之间
此帖出自51单片机论坛
Temp1=(xielv)*(Temp0);//这里有时候会出现乱码 这里已经超范围  详情 回复 发表于 2011-8-27 16:19
莫非,是超数的范围了
这里已经超范围
此帖出自51单片机论坛
84
不对啊,temp0=abc-b;这里计算出来的数是不超过十的
此帖出自51单片机论坛
