3366|0
46
12864显示图片出现一个警告 [复制链接]
Building configuration: fefe - Debug
Updating build tree...
main.c
Linking
Error[e16]: Segment CSTACK (size: 0x50 align: 0x1) is too long for segment definition. At least 0x50 more bytes needed. The problem occurred while processing the
segment placement command "-Z(DATA)CSTACK+_STACK_SIZE#", where at the moment of placement the available memory ranges were "-none-"
   Reserved ranges relevant to this placement:
   200-9ff              DATA16_I
Error while running Linker
Total number of errors: 1
Total number of warnings: 0
12864显示两张图片出现一个错误,显示一张的时候没有错误,是不是存储空间的问题。但是个人觉得msp430F149的存储空间比51的大很多,51显示的时候没有任何的问题。这个是问什么呢??
