9580|29
49
MSP430F2274中uart通信,程序没有问题,但是用串口精灵测试就是没有数据 [复制链接]
//   MSP430F22x4 Demo - USCI_A0, Ultra-Low Pwr UART 9600 String, 32kHz ACLK
//   Description: This program demonstrates a full-duplex 9600-baud UART using
//   USCI_A0 and a 32kHz crystal.  The program will wait in LPM3, and will
//   respond to a received 'u' character using 8N1 protocol. The response will
//   be the string 'Hello World'.
//   ACLK = BRCLK = LFXT1 = 32768Hz, MCLK = SMCLK = DCO ~1.2MHz
//   Baud rate divider with 32768Hz XTAL @9600 = 32768Hz/9600 = 3.41
//   //* An external watch crystal is required on XIN XOUT for ACLK *//
//                MSP430F22x4
//         /|\|              XIN|-
//          | |                 | 32kHz
//          --|RST          XOUT|-
//            |     P3.4/UCA0TXD|------------>
//            |                 | 9600 - 8N1
//            |     P3.5/UCA0RXD|<------------
//   A. Dannenberg
//   Texas Instruments Inc.
//   October 2006
//   Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.41A
#include  "msp430x22x4.h"
const char string1[] = { "Hello World\r\n" };
unsigned int i;
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P1DIR = 0xFF;                             // All P1.x outputs
  P1OUT = 0;                                // All P1.x reset
  P2DIR = 0xFF;                             // All P2.x outputs
  P2OUT = 0;                                // All P2.x reset
  P3SEL = 0x30;                             // P3.4,5 = USCI_A0 TXD/RXD
  P3DIR = 0xFF;                             // All P3.x outputs
  P3OUT = 0;                                // All P3.x reset
  P4DIR = 0xFF;                             // All P4.x outputs
  P4OUT = 0;                                // All P4.x reset
  UCA0CTL1 |= UCSSEL_1;                     // CLK = ACLK
  UCA0BR0 = 0x03;                           // 32kHz/9600 = 3.41
  UCA0BR1 = 0x00;                           //
  UCA0MCTL = UCBRS1 + UCBRS0;               // Modulation UCBRSx = 3
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  IE2 |= UCA0RXIE;                          // Enable USCI_A0 RX interrupt
  __bis_SR_register(LPM3_bits + GIE);       // Enter LPM3 w/ int until Byte RXed
#pragma vector=USCIAB0TX_VECTOR
__interrupt void USCI0TX_ISR(void)
  UCA0TXBUF = string1[i++];                 // TX next character
  if (i == sizeof string1 - 1)              // TX over?
    IE2 &= ~UCA0TXIE;                       // Disable USCI_A0 TX interrupt
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
  if (UCA0RXBUF == 'u')                     // 'u' received?
    i = 0;
    IE2 |= UCA0TXIE;                        // Enable USCI_A0 TX interrupt
请问楼主程序正确,但是串口调试助手没有数据的问题解决了没有?  详情 回复 发表于 2016-5-5 11:12
uart总线的问题,这个比较复杂的
个人签名工业烤箱,烘箱www.wjtdhx.com
49
回复 沙发 DZZ 的帖子
这个是TI的例程,应该不是程序的问题,电脑我也换过N台试过也是不好,波特率的设置也是没问题的,就是不知道是哪出问题了。。唉
不知道你用的是不是学习板,可以看看用的晶振,还有助手的显示开了没有,还有数据线有没有问题,如果是学习板,上面会有LED灯,可以看是否有数据,,等等,头疼死了,我的也没调出来,我的是数太多了,1次2024个。。。崩溃。
49
回复 4楼 aahellaa 的帖子
wo我用的是EZ430—RF2500的无线模块。。。。。唉,头疼
49
回复 5楼 w363782100 的帖子
各位大虾,帮帮忙吧
49
回复 6楼 w363782100 的帖子
坚决不能沉了。。。。
49
回复 7楼 w363782100 的帖子
lai ren a
49
回复 8楼 w363782100 的帖子
自己把帖子顶起来
49
回复 9楼 w363782100 的帖子
遇到帖子顶三顶
49
回复 10楼 w363782100 的帖子
为了上首页,只能坚决的顶起
49
回复 11楼 w363782100 的帖子
不顶起肿么行
49
回复 12楼 w363782100 的帖子
楼主已经疯掉,只希望来人解决一下啊
49
回复 13楼 w363782100 的帖子
不停地一顶再顶
49
回复 14楼 w363782100 的帖子
在这个被人遗忘的角落里
49
回复 15楼 w363782100 的帖子
好吧,今天先顶到这把
49
回复 16楼 w363782100 的帖子
今天再一次
26
敢问楼主,接线肯定没问题吗??
用串口工具测试,必须先送一个字符‘u’给单片机才能收到字符串的
26
小弟木有板子,只是用proteus简单仿真了一下
可以收到数据,只不过是乱码,再调调
755
会不会是串口线交叉的问题?
