41
谢谢了
谢谢了 我的是739158755qq@.com
此帖出自stm32/stm8论坛
42
13555773577@163.com   谢谢啦 多交流
此帖出自stm32/stm8论坛
43
回复 楼主 jiaxinhui2011 的帖子
我正在学STM32,不知如何入门,准备做个板子,给我发些资料吧。谢谢!116532976@qq.com
此帖出自stm32/stm8论坛
406
44
实验(四)  RTC寄存器的读写
void KeyInit(void)
        GPIO_InitTypeDef GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);//使能外设时钟
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);//使能外设时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 ;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_15 ;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
unsigned char GetKey(void)
        if(Bit_RESET == GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_8))
                DelayNmS(10);//去抖动
                        while(Bit_RESET == GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_8))//等待按键释放
                        return 3;//返回按键值
        if(Bit_RESET == GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_1))
                DelayNmS(10);//去抖动
                        while(Bit_RESET == GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_1))//等待按键释放
                        return 1;//返回按键值
        if(Bit_RESET == GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_15))
                DelayNmS(10);//去抖动
                        while(Bit_RESET == GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_15))//等待按键释放
                        return 2;//返回按键值
        return NO_KEY;
void KeyTest(void)
        unsigned char i = 0;
        while(1)
                       i = GetKey();//按键扫描
                                        switch(i)
                                                { case 1:  LedOutput(0,1);break;  //按键1按下,LED1亮
                                                  case 2:  LedOutput(1,1);break;  //按键2按下,LED2亮
                                                  case 3:  LedOutput(2,1); break; //按键3按下,LED3亮
                                                 default:  break;
此帖出自stm32/stm8论坛
个人签名STM32 开发板  带CAN  RS485 接口
http://shop66177872.taobao.com
45
406
46
注意:上面的实验(四)是按键查询程序。
实验(五)  SysTick
void SysTInit(void)
        SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_Div8);//2M
        SysTick_SetReload(200000);//100ms
        SysTick_ITConfig(ENABLE);
        NVIC_SystemHandlerPriorityConfig(SystemHandler_SysTick, 2, 0);
        SysTStop();
void SysTStart(void)
        SysTick_CounterCmd(SysTick_Counter_Enable);
void SysTStop(void)
        SysTick_CounterCmd(SysTick_Counter_Disable);
void SysTTest(void)
        SysTStart();
        while(1);
unsigned char SysTTestFlag = 0;
void SysTickHandler(void)
        if(SysTTestFlag)
                SysTTestFlag = 0;
                LedOutput(0,0);
        else
                SysTTestFlag = 1;
                LedOutput(0,1);
此帖出自stm32/stm8论坛
47
谢谢楼主!kxjie2006@126.com
此帖出自stm32/stm8论坛
406
48
STM32固件库使用手册的中文翻译版.pdf (2.79 MB, 下载次数: 16)
此帖出自stm32/stm8论坛
406
49
实验(五)  CAN环回测试
void GPIO_Configuration(void)
        /* LED1 LED2 LED3 的控制管脚为输出模式*/
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 ;
          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
          GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
          /* Configure CAN pin: RX */
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
          /* Configure CAN pin: TX */
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_PinRemapConfig(GPIO_Remap1_CAN1, ENABLE );           //重影射CAN IO脚到 PB8,PB9
//系统中断管理
void NVIC_Configuration(void)
        NVIC_InitTypeDef NVIC_InitStructure;
          /* Configure the NVIC Preemption Priority Bits */
          NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
        #ifdef  VECT_TAB_RAM
          /* Set the Vector Table base location at 0x20000000 */
          NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
        #else  /* VECT_TAB_FLASH  */
          /* Set the Vector Table base location at 0x08000000 */
          NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
        #endif
        /* enabling interrupt */
          NVIC_InitStructure.NVIC_IRQChannel=USB_LP_CAN1_RX0_IRQn;;
          NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
          NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
          NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
          NVIC_Init(&NVIC_InitStructure);
//配置系统时钟,使能各外设时钟
void RCC_Configuration(void)
        ErrorStatus HSEStartUpStatus;
        // RCC system reset(for debug purpose)
        RCC_DeInit();
        // Enable HSE
        RCC_HSEConfig(RCC_HSE_ON);
        // Wait till HSE is ready
        HSEStartUpStatus = RCC_WaitForHSEStartUp();
        if(HSEStartUpStatus == SUCCESS)
                // HCLK = SYSCLK
                RCC_HCLKConfig(RCC_SYSCLK_Div1);
                // PCLK2 = HCLK
                RCC_PCLK2Config(RCC_HCLK_Div1);
                // PCLK1 = HCLK/2
                RCC_PCLK1Config(RCC_HCLK_Div2);
                // Flash 2 wait state
                //FLASH_SetLatency(FLASH_Latency_2);
                FLASH_SetLatency(FLASH_Latency_0);
                //FLASH_SetLatency(FLASH_Latency_1);
                // Enable Prefetch Buffer
                FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
                // PLLCLK = 8MHz /2*2 = 8 MHz
                RCC_PLLConfig(RCC_PLLSource_HSE_Div2, RCC_PLLMul_2);
                // Enable PLL
                RCC_PLLCmd(ENABLE);
                // Wait till PLL is ready
                while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
                // Select PLL as system clock source
                RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
                // Wait till PLL is used as system clock source
                while(RCC_GetSYSCLKSource() != 0x08)
        // Enable peripheral clocks --------------------------------------------------
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA
                           |RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
                           |RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE
                                                   |RCC_APB2Periph_ADC1  | RCC_APB2Periph_AFIO
                           |RCC_APB2Periph_SPI1, ENABLE );
  //RCC_APB2PeriphClockCmd(RCC_APB2Periph_ALL ,ENABLE );
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4
                           |RCC_APB1Periph_USART3|RCC_APB1Periph_TIM2
                           , ENABLE );
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
        /* CAN Periph clock enable */
          RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
//配置所有外设
void Init_All_Periph(void)
        RCC_Configuration();
        GPIO_Configuration();
        NVIC_Configuration();
int main(void)
        Init_All_Periph();
        GPIO_SetBits(GPIOB, GPIO_Pin_14);
        GPIO_SetBits(GPIOB, GPIO_Pin_12);
        GPIO_SetBits(GPIOB, GPIO_Pin_13);
        /* CAN transmit at 100Kb/s and receive by polling in loopback mode*/
          TestRx = CAN_Polling();
          if (TestRx == FAILED) //失败LED2亮
            /* Turn on led connected to PD.04 pin (LD3) */
            GPIO_ResetBits(GPIOB, GPIO_Pin_12);
          else //成功LED1亮
            /* Turn on led connected to PD.02 pin (LD1) */
            GPIO_ResetBits(GPIOB, GPIO_Pin_14);
          /* CAN transmit at 500Kb/s and receive by interrupt in loopback mode*/
          TestRx = CAN_Interrupt();
                    /* Turn on led connected to PD.07 pin (LD4) */
          else   //成功LED3亮
            /* Turn on led connected to PD.03 pin (LD2) */
            GPIO_ResetBits(GPIOB, GPIO_Pin_13);
        while(1)
* Function Name  : CAN_Polling
* Description    : Configures the CAN and transmit and receive by polling
* Input          : None
* Output         : None
* Return         : PASSED if the reception is well done, FAILED in other case
TestStatus CAN_Polling(void)
  CAN_InitTypeDef        CAN_InitStructure;
  CAN_FilterInitTypeDef  CAN_FilterInitStructure;
  CanTxMsg TxMessage;
  CanRxMsg RxMessage;
  u32 i = 0;
  u8 TransmitMailbox;
  /* CAN register init */
  CAN_DeInit(CAN1);
  CAN_StructInit(&CAN_InitStructure);
  /* CAN cell init */
  CAN_InitStructure.CAN_TTCM=DISABLE;
  CAN_InitStructure.CAN_ABOM=DISABLE;
  CAN_InitStructure.CAN_AWUM=DISABLE;
  CAN_InitStructure.CAN_NART=DISABLE;
  CAN_InitStructure.CAN_RFLM=DISABLE;
  CAN_InitStructure.CAN_TXFP=DISABLE;
  CAN_InitStructure.CAN_Mode=CAN_Mode_LoopBack; //工作在环回模式
  CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
  CAN_InitStructure.CAN_BS1=CAN_BS1_8tq;
  CAN_InitStructure.CAN_BS2=CAN_BS2_7tq;
  CAN_InitStructure.CAN_Prescaler=5;           //  8M/5/(1+8+7)=100k
  CAN_Init(CAN1,&CAN_InitStructure);
  /* CAN filter init */
  CAN_FilterInitStructure.CAN_FilterNumber=0;
  CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment=0;
  CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
  /* transmit */
  TxMessage.StdId=0x11;
  TxMessage.RTR=CAN_RTR_DATA;
  TxMessage.IDE=CAN_ID_STD;
  TxMessage.DLC=2;
  TxMessage.Data[0]=0xCA;
  TxMessage.Data[1]=0xFE;
  TransmitMailbox=CAN_Transmit(CAN1,&TxMessage);
  i = 0;
  while((CAN_TransmitStatus(CAN1,TransmitMailbox) != CANTXOK) && (i != 0xFF))
    i++;
  i = 0;
  while((CAN_MessagePending(CAN1,CAN_FIFO0) < 1) && (i != 0xFF))
    i++;
  /* receive */
  RxMessage.StdId=0x00;
  RxMessage.IDE=CAN_ID_STD;
  RxMessage.DLC=0;
  RxMessage.Data[0]=0x00;
  RxMessage.Data[1]=0x00;
  CAN_Receive(CAN1,CAN_FIFO0, &RxMessage);
  if (RxMessage.StdId!=0x11) return FAILED;
  if (RxMessage.IDE!=CAN_ID_STD) return FAILED;
  if (RxMessage.DLC!=2) return FAILED;
  if ((RxMessage.Data[0]<<8|RxMessage.Data[1])!=0xCAFE) return FAILED;
  return PASSED; /* Test Passed */
* Function Name  : CAN_Interrupt
* Description    : Configures the CAN and transmit and receive by interruption
* Input          : None
* Output         : None
TestStatus CAN_Interrupt(void)
  CanTxMsg TxMessage;
  u32 i = 0;
  CAN_DeInit(CAN1);
  /* CAN cell init */
  CAN_InitStructure.CAN_Mode=CAN_Mode_LoopBack;//工作在环回模式
  CAN_InitStructure.CAN_Prescaler=1;  //  8M/1/(1+8+7)=500k
  CAN_FilterInitStructure.CAN_FilterNumber=1;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_FIFO0;
  /* CAN FIFO0 message pending interrupt enable */
  CAN_ITConfig(CAN1,CAN_IT_FMP0, ENABLE);
  /* transmit 1 message */
  TxMessage.StdId=0x00;
  TxMessage.ExtId=0x1234;
  TxMessage.IDE=CAN_ID_EXT;
  TxMessage.DLC=2;
  TxMessage.Data[0]=0xDE;
  TxMessage.Data[1]=0xCA;
  /* initialize the value that will be returned */
  ret = 0xFF;
  /* receive message with interrupt handling */
  i=0;
  while((ret == 0xFF) && (i < 0xFFF))
    i++;
  if (i == 0xFFF)
    ret=0;
  /* disable interrupt handling */
  CAN_ITConfig(CAN1,CAN_IT_FMP0, DISABLE);
  return (TestStatus)ret;
* Function Name  : USB_LP_CAN_RX0_IRQHandler
* Description    : This function handles USB Low Priority or CAN RX0 interrupts
*                  requests.
* Input          : None
* Output         : None
* Return         : None
void USB_LP_CAN1_RX0_IRQHandler(void)
  CanRxMsg RxMessage;
  RxMessage.ExtId=0x00;
  RxMessage.IDE=0;
  RxMessage.DLC=0;
  RxMessage.FMI=0;
  if((RxMessage.ExtId==0x1234) && (RxMessage.IDE==CAN_ID_EXT)
     && (RxMessage.DLC==2) && ((RxMessage.Data[1]|RxMessage.Data[0]<<8)==0xDECA))
    ret = 1;
  else
    ret = 0;
此帖出自stm32/stm8论坛
准备学习这个芯片,谢谢lz分享。
losophy@126.com
此帖出自stm32/stm8论坛
406
51
实验内容:通过STM32的USB端口在PC上虚拟一个COM口,当虚拟成功后,可通过串口调试软件
发送控制命令,去点亮板子上相应的LED灯,同时输出调试信息。
代码 虚拟串口.zip (25.64 KB, 下载次数: 5)
在PC机的设备管理器中可看到虚拟出的COM口
串口调试软件的输出状态
此帖出自stm32/stm8论坛
4138
52
很漂亮欧哈哈哈
此帖出自stm32/stm8论坛
53
需要原理图等资料      1014266925@qq.com    谢谢 楼主      我加了群
谢谢
谢谢
此帖出自stm32/stm8论坛
54
guoweimincscs1@163.com,需要一份自己做参考,谢了!
此帖出自stm32/stm8论坛
406
55
纳闷,板子这么便宜怎么没有人要
此帖出自stm32/stm8论坛
56
我也要,谢谢楼主 272068887@qq.com
此帖出自stm32/stm8论坛
406
57
好消息,有10块 液晶屏PCB板 免费赠送   有需要请联系我
此帖出自stm32/stm8论坛
28
58
求资料
405690775@qq.com
谢谢哈,做的真好,帮我发套资料吧!
此帖出自stm32/stm8论坛
21
59
楼主很无私,支持!
此帖出自stm32/stm8论坛
太利害了给我发个吧!beyondzhi@126.com 谢谢
此帖出自stm32/stm8论坛
