回复 6楼 daicheng 的帖子
在u-boot-1.3.4里面的 board/atmel/at91rm9200dk/flash.c 我看着u-boot-0.4.0里面的 flash.c 来改的。
两片flash在 include/configs/at91rm9200dk.h 中起始地址定义:
#define PHYS_FLASH_1 0x10000000
#define PHYS_FLASH_2 0x80000000
flash.c 添加SST39VF3201的支持,文件内容如下,麻烦斑竹帮忙看看:
#include
ulong myflush(void);
/* Flash Organization Structure */
typedef struct OrgDef
unsigned int sector_number;
unsigned int sector_size;
} OrgDef;
/* Flash Organizations */
OrgDef OrgAT49BV16x4[] =
{ 8, 8*1024 }, /* 8 * 8 kBytes sectors */
{ 2, 32*1024 }, /* 2 * 32 kBytes sectors */
{ 30, 64*1024 }, /* 30 * 64 kBytes sectors */
OrgDef OrgAT49BV16x4A[] =
{ 31, 64*1024 }, /* 31 * 64 kBytes sectors */
OrgDef OrgAT49BV6416[] =
{ 127, 64*1024 }, /* 127 * 64 kBytes sectors */
OrgDef OrgSST39VF3201[] =
{ 1024, 4*1024 } /* 1024 * 4kBytes sectors */
#define FLASH_BANK_SIZE 0x400000 /* 4 MB */
//#define MAIN_SECT_SIZE 0x10000 /* 64 KB */
flash_info_t flash_info[CFG_MAX_FLASH_BANKS];
/* SST39VF3201 Codes */
#define FLASH_CODE1 0xAA
#define FLASH_CODE2 0x55
#define ID_IN_CODE 0x90
#define ID_OUT_CODE 0xF0
#define CMD_READ_ARRAY 0x00F0
#define CMD_UNLOCK1 0x00AA
#define CMD_UNLOCK2 0x0055
#define CMD_ERASE_SETUP 0x0080
#define CMD_ERASE_CONFIRM 0x0030
#define CMD_PROGRAM 0x00A0
#define CMD_UNLOCK_BYPASS 0x0020
//#define CMD_SECTOR_UNLOCK 0x0070
#define MEM_FLASH_ADDR1 (*(volatile u16 *)(flash_base + (0x00005555<<1)))
#define MEM_FLASH_ADDR2 (*(volatile u16 *)(flash_base + (0x00002AAA<<1)))
#define IDENT_FLASH_ADDR1 (*(volatile u16 *)(flash_base + (0x00005555<<1)))
#define IDENT_FLASH_ADDR2 (*(volatile u16 *)(flash_base + (0x00002AAA<<1)))
#define BIT_ERASE_DONE 0x0080
#define BIT_RDY_MASK 0x0080
#define BIT_PROGRAM_ERROR 0x0020
#define BIT_TIMEOUT 0x80000000 /* our flag */
#define READY 1
#define ERR 2
#define TMO 4
void flash_identification (ulong flash_base, flash_info_t * info)
volatile u16 manuf_code, device_code, add_device_code;
IDENT_FLASH_ADDR1 = FLASH_CODE1;
IDENT_FLASH_ADDR2 = FLASH_CODE2;
IDENT_FLASH_ADDR1 = ID_IN_CODE;
manuf_code = *(volatile u16 *) flash_base;
device_code = *(volatile u16 *) (flash_base + 2);
//add_device_code = *(volatile u16 *) (CFG_FLASH_BASE + (3 << 1));
IDENT_FLASH_ADDR1 = ID_OUT_CODE;
/* Vendor type */
info->flash_id = SST_MANUFACT & FLASH_VENDMASK;
printf ("SST: ");
if ((device_code & FLASH_TYPEMASK) == (SST_ID_xF3201 & FLASH_TYPEMASK)) {
info->flash_id |= SST_ID_xF3201 & FLASH_TYPEMASK;
printf ("SST39VF3201 (32Mbit)\n");
} else {
printf ("Unkown Flash: 0x%x, 0x%x\n", manuf_code, device_code); }
ulong flash_init (void)
int i, j, k;
unsigned int flash_nb_blocks, sector;
unsigned int start_address;
ulong flash_base;
OrgDef *pOrgDef;
ulong size = 0;
for (i = 0; i < CFG_MAX_FLASH_BANKS; i++) {
if (i == 0)
flash_base = PHYS_FLASH_1;
else if (i == 1)
flash_base = PHYS_FLASH_2;
else
panic ("configured to many flash banks!\n");
flash_identification (flash_base, &flash_info);
flash_info.size = FLASH_BANK_SIZE;
if ((flash_info.flash_id & FLASH_TYPEMASK) ==
flash_info.sector_count = CFG_MAX_FLASH_SECT;
memset (flash_info.protect, 0, CFG_MAX_FLASH_SECT);
pOrgDef = OrgSST39VF3201;
flash_nb_blocks = sizeof (OrgSST39VF3201) / sizeof (OrgDef);
} else
panic ("Unknown Flash!\n");
#if 0
(ATM_ID_BV1614 & FLASH_TYPEMASK)) {
pOrgDef = OrgAT49BV16x4;
flash_nb_blocks = sizeof (OrgAT49BV16x4) / sizeof (OrgDef);
} else { /* AT49BV1614A Flash */
flash_info.sector_count = CFG_MAX_FLASH_SECT - 1;
memset (flash_info.protect, 0, CFG_MAX_FLASH_SECT - 1);
pOrgDef = OrgAT49BV16x4A;
flash_nb_blocks = sizeof (OrgAT49BV16x4A) / sizeof (OrgDef);
#endif
// if (i == 0)
// flashbase = PHYS_FLASH_1;
// else
// panic ("configured to many flash banks!\n");
sector = 0;
start_address = flash_base;
/*flash_info.size = 0;*/
for (j = 0; j < flash_nb_blocks; j++) {
for (k = 0; k < pOrgDef[j].sector_number; k++) {
flash_info.start[sector++] = start_address;
start_address += pOrgDef[j].sector_size;
/*flash_info.size += pOrgDef[j].sector_size;*/
size += flash_info.size;
/* Protect binary boot image */
flash_protect (FLAG_PROTECT_SET,
PHYS_FLASH_1,
PHYS_FLASH_1 + CFG_BOOT_SIZE - 1, &flash_info[0]);
/* Protect environment variables */
CFG_ENV_ADDR,
CFG_ENV_ADDR + CFG_ENV_SIZE - 1, &flash_info[0]);
/* Protect U-Boot gzipped image */
CFG_U_BOOT_BASE,
CFG_U_BOOT_BASE + CFG_U_BOOT_SIZE - 1, &flash_info[0]);
return size;
void flash_print_info (flash_info_t * info)
int i;
switch (info->flash_id & FLASH_VENDMASK) {
case (ATM_MANUFACT & FLASH_VENDMASK):
printf ("Atmel: ");
break;
case (SST_MANUFACT & FLASH_VENDMASK):
printf ("SST: ");
break;
default:
printf ("Unknown Vendor ");
break;
switch (info->flash_id & FLASH_TYPEMASK) {
case (ATM_ID_BV1614 & FLASH_TYPEMASK):
printf ("AT49BV1614 (16Mbit)\n");
break;
case (ATM_ID_BV1614A & FLASH_TYPEMASK):
printf ("AT49BV1614A (16Mbit)\n");
break;
case (ATM_ID_BV6416 & FLASH_TYPEMASK):
printf ("AT49BV6416 (64Mbit)\n");
break;
case (SST_ID_xF3201 & FLASH_TYPEMASK):
break;
default:
printf ("Unknown Chip Type\n");
goto Done;
break;
printf (" Size: %ld MB in %d Sectors\n",
info->size >> 20, info->sector_count);
printf (" Sector Start Addresses:");
for (i = 0; i < info->sector_count; i++) {
if ((i % 5) == 0) {
printf ("\n ");
printf (" %08lX%s", info->start,
info->protect ? " (RO)" : " ");
printf ("\n");
Done:
return 0;
int flash_erase (flash_info_t * info, int s_first, int s_last)
ulong result;
int iflag, cflag, prot, sect;
int rc = ERR_OK;
int chip1;
ulong flash_base;
/* first look for protection bits */
if (info->flash_id == FLASH_UNKNOWN)
return ERR_UNKNOWN_FLASH_TYPE;
if ((s_first < 0) || (s_first > s_last)) {
return ERR_INVAL;
if ((info->flash_id & FLASH_VENDMASK) !=
(SST_MANUFACT & FLASH_VENDMASK)) {
return ERR_UNKNOWN_FLASH_VENDOR;
prot = 0;
for (sect = s_first; sect <= s_last; ++sect) {
if (info->protect[sect]) {
prot++;
if (prot)
return ERR_PROTECTED;
* Disable interrupts which might cause a timeout
* here. Remember that our exception vectors are
* at address 0 in the flash, and we don't want a
* (ticker) exception to happen while the flash
* chip is in programming mode.
cflag = icache_status ();
icache_disable ();
iflag = disable_interrupts ();
/* Start erase on unprotected sectors */
for (sect = s_first; sect <= s_last && !ctrlc (); sect++) {
printf ("Erasing sector %2d ... ", sect);
/* arm simple, non interrupt dependent timer */
reset_timer_masked ();
if (info->protect[sect] == 0) { /* not protected */
volatile u16 *addr = (volatile u16 *) (info->start[sect]);
MEM_FLASH_ADDR1 = CMD_UNLOCK1;
MEM_FLASH_ADDR2 = CMD_UNLOCK2;
MEM_FLASH_ADDR1 = CMD_ERASE_SETUP;
*addr = CMD_ERASE_CONFIRM;
/* wait until flash is ready */
chip1 = 0;
do {
result = *addr;
/* check timeout */
if (get_timer_masked () > CFG_FLASH_ERASE_TOUT) {
MEM_FLASH_ADDR1 = CMD_READ_ARRAY;
chip1 = TMO;
break;
if (!chip1 && (result & 0xFFFF) & BIT_ERASE_DONE)
chip1 = READY;
} while (!chip1);
if (chip1 == ERR) {
rc = ERR_PROG_ERROR;
goto outahere;
if (chip1 == TMO) {
rc = ERR_TIMOUT;
goto outahere;
printf ("ok.\n");
} else { /* it was protected */
printf ("protected!\n");
if (ctrlc ())
printf ("User Interrupt!\n");
outahere:
/* allow flash to settle - wait 10 ms */
udelay_masked (10000);
if (iflag)
enable_interrupts ();
if (cflag)
icache_enable ();
return rc;
* Copy memory to flash
volatile static int write_word (flash_info_t * info, ulong dest, ulong data)
volatile u16 *addr = (volatile u16 *) dest;
ulong flash_base;
ulong result;
int rc = ERR_OK;
int cflag, iflag;
int chip1;
* Check if Flash is (sufficiently) erased
result = *addr;
if ((result & data) != data)
return ERR_NOT_ERASED;
icache_disable ();
flash_base = info->start[0];
MEM_FLASH_ADDR1 = CMD_PROGRAM;
*addr = data;
chip1 = 0;
do {
result = *addr;
/* check timeout */
chip1 = ERR | TMO;
break;
if (!chip1 && ((result & 0x80) == (data & 0x80)))
chip1 = READY;
} while (!chip1);
*addr = CMD_READ_ARRAY;
if (chip1 == ERR || *addr != data)
if (iflag)
if (cflag)
icache_enable ();
return rc;
* Copy memory to flash.
int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt)
ulong wp, data;
int rc;
if (addr & 1) {
printf ("unaligned destination not supported\n");
return ERR_ALIGN;
if ((int) src & 1) {
printf ("unaligned source not supported\n");
return ERR_ALIGN;
wp = addr;
while (cnt >= 2) {
data = *((volatile u16 *) src);
if ((rc = write_word (info, wp, data)) != 0) {
return (rc);
src += 2;
wp += 2;
cnt -= 2;
if (cnt == 1) {
data = (*((volatile u8 *) src)) | (*((volatile u8 *) (wp + 1)) <<
8);
return (rc);
src += 1;
wp += 1;
cnt -= 1;
return ERR_OK;
