4637|3
ucosii信号量问题 求高手支招! [复制链接]
以下是我修改的程序,在mytask中添加了一个延时,我认为应该先显示mytask calling fun(),然后过8s之后再显示youtask calling fun(),可是
实际上是,显示mytask calling fun()之后紧接着显示八个youtask calling fun()然后是mytask callingfun()
请问这是为什么呢?
#include "INCLUDES.h"
#define  TASK_STK_SIZE        512
char *s1="MyTask";
char *s2="YouTask";
INT8U err;
INT8U y=0;
OS_EVENT *Fun_Semp;
OS_STK        StartTaskStk[TASK_STK_SIZE];
OS_STK        MyTaskStk[TASK_STK_SIZE];
OS_STK        YouTaskStk[TASK_STK_SIZE];
void  Fun(INT8U x,INT8U y);
void  StartTask(void *data);
void  MyTask(void *data);
void  YouTask(void *data);
*                                                MAIN主函数
void  main (void)
 Fun_Semp=OSSemCreate(1);                               //定义信号量
    OSInit();
    PC_DOSSaveReturn();
    PC_VectSet(uCOS, OSCtxSw);
    OSTaskCreate(StartTask,(void *)0, &StartTaskStk[TASK_STK_SIZE - 1], 0); //创建起始函数
    OSStart();                                             /* 启动多任务管理   */
void  StartTask(void *pdata)
#if OS_CRITICAL_METHOD == 3        /* Allocate storage for CPU status register */
    OS_CPU_SR  cpu_sr;
#endif
    INT16S        key;             /*用于退出的建*/
    pdata = pdata;                                         /* Prevent compiler warning                 */
    OS_ENTER_CRITICAL();
    PC_VectSet(0x08, OSTickISR);
    PC_SetTickRate(OS_TICKS_PER_SEC);
    OS_EXIT_CRITICAL();
    OSStatInit();                                          /* 初始化统计任务   */
    OSTaskCreate(MyTask,(void *)0, &MyTaskStk[TASK_STK_SIZE - 1], 1); //创建任务函数
 OSTaskCreate(YouTask,(void *)0, &YouTaskStk[TASK_STK_SIZE - 1], 2); //创建任务函数
 for (;;)
           if (PC_GetKey(&key) == TRUE)
         {                     /* See if key has been pressed              */
            if (key == 0x1B)
            {                             /* Yes, see if it's the ESCAPE key          */
                PC_DOSReturn();                            /* Return to DOS                            */
        OSTimeDlyHMSM(0,0,3,0);                         /* 等待3S*/
void  MyTask(void *pdata)
    OS_CPU_SR  cpu_sr;
#endif
    for (;;)
  OSSemPend(Fun_Semp,0,&err);        //请求信号量
  PC_DispStr(0,y++,s1,DISP_BGND_BLACK+DISP_FGND_WHITE);
  Fun(7,y);
        OSTimeDlyHMSM(0,0,8,0);                         /* 等待8S*/
  OSSemPost(Fun_Semp);    //发送信号量
  OSTimeDlyHMSM(0,0,1,0);                         /* 等待1S*/
void  YouTask(void *pdata)
#if OS_CRITICAL_METHOD == 3        //Allocate storage for CPU status register
    OS_CPU_SR  cpu_sr;
#endif
 pdata=pdata;
 for (;;)
  PC_DispStr(0,y++,s2,DISP_BGND_BLACK+DISP_FGND_WHITE);
  Fun(7,y);
        OSTimeDlyHMSM(0,0,1,0);    //等待10个时钟节拍
 PC_DispStr(x,y-1,"  Calling FUN()",DISP_BGND_BLACK+DISP_FGND_WHITE);
是的,信号量没有成功用起,任务1中OSTimeDlyHMSM()使得任务调度了。  详情 回复 发表于 2011-7-7 09:48
79
Fun_Semp=OSSemCreate(1); 放错地方了吧
放在开始,事件都没初始化呢,这句话无效。
你再换成下面地方试试。
void  main (void)
//Fun_Semp=OSSemCreate(1);                               //定义信号量
    OSInit();
    PC_DOSSaveReturn();
849
回复 沙发 lalahu 的帖子
楼上说得有一定道理,要用系统函数,那么系统要先初始化,也就是OSInit();
个人签名只有想不到,没有做不到。
