4000|8
430高手可否帮我看一下这个程序哪里错了 [复制链接]
想利用430—2274的I2C来读一个芯片的数据,不知道为什么老是读出全是0xFF。
#include "msp430x22x4.h"
# define uchar unsigned char
# define uint unsigned int
#define SDA_IN P3DIR &=~BIT1 // P3.1 IN
#define SDA_OUT P3DIR |=BIT1 // P3.1 OUT
#define SDA_LOW P3OUT &=~BIT1 // sda=0
#define SDA_HIGH P3OUT |=BIT1 // sda=1
#define SCL_IN P3DIR &=~BIT2 // P3.2 IN
#define SCL_OUT P3DIR |=BIT2 // P3.2 OUT
#define SCL_LOW P3OUT &=~BIT2
#define SCL_HIGH P3OUT |=BIT2
uchar Temp[8]={0,1,2,3,4,5,6,7};
void mDelay(uint t) //延时子程序
{ int i;
for(;t>0;t--)
{ for(i=0;i<124;i++)
void delay (unsigned int TT)
for (;TT!=0;TT--);
void IIC_START (void) //I2C_START
{ SDA_OUT;
SDA_HIGH;
SCL_HIGH;
delay (50);
SDA_LOW;
delay (50);
SCL_LOW;
delay (50);
void IIC_STOP (void) //I2C_STOP
{ SDA_OUT;
SDA_LOW;
delay (50);
SCL_HIGH;
delay (50);
SDA_HIGH;
delay (50);
SCL_LOW;
void IIC_ACK (void) //IIC_ACK
{ SDA_OUT;
SDA_LOW;
delay (50);
SCL_HIGH;
delay (50);
SCL_LOW;
delay (50);
SDA_HIGH;
void IIC_TX_DATA (unsigned char DATA)
{unsigned char Rn=8,RR=0x80;
SDA_OUT;
delay (50);
for (;Rn!=0;Rn--)
if ((DATA&RR)!=0)
SDA_HIGH;
else
SDA_LOW;
delay (50);
SCL_HIGH;
delay (50);
SCL_LOW;
delay (50);
RR>>=1;
SDA_HIGH; // ACK
delay (50);
SCL_HIGH;
delay (50);
SCL_LOW;
delay (50);
unsigned char IIC_RX_DATA (void)
unsigned int Rn=8,DATA=0,RR=0x80;
SDA_IN; // 端口为输入
delay (50);
for (;Rn!=0;Rn--)
SCL_HIGH;
delay (50);
if ((P3IN&BIT2)!=0)
DATA|=RR;
else
DATA&=~RR;
RR>>=1;
SCL_LOW;
delay (50);
return DATA;
void IIC_Ena××e(void)
//*****************开始启动并唤醒 MEMS********
IIC_START();
mDelay(75);
IIC_TX_DATA(0x20); //写入[0010xxx0] 写操作
IIC_TX_DATA(0x00);//写入地址[00000000]
IIC_TX_DATA(0x00);//写入CALL UP命令 [xxxxxxx0]
IIC_STOP();
void main (void)
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
DCOCTL = 0X73;
BCSCTL1= 0X87; // 设置时钟频率4.00MHz
// SimpliciTI will change port pin settings as well
P3DIR = 0x06;//SDA,SCL
P3OUT |=0X06;
P3SEL |=0x06; //3.1和3.2引脚当做外围功能, Assign I2C pins to USCI_B0
UCB0CTL0 = UCMST + UCMODE_0 + UCSYNC; // I2C Master, synchronous mode
UCB0CTL1 = UCSSEL_0; //// Use SMCLK
UCB0BR0 = 12; // fSCL = SMCLK/12 = ~100kHz
UCB0BR1 = 0;
UCB0I2CSA = 0x00; // Set sl××e address
IE2 |= UCB0RXIE; // Ena××e RX interrupt
TACTL = TASSEL_2 + MC_2; // SMCLK, contmode
SDA_HIGH;
SCL_HIGH;
IIC_Ena××e();
//可以直接 读的地址先指名 开始地址
IIC_START();
mDelay(75);
delay(50);
IIC_TX_DATA(0x00); //现在是从[00000000]开始的
delay(50);
IIC_TX_DATA(0x00); //call up
IIC_STOP();
mDelay(75); //等待75MS
//***************开始读取MEMS信息
IIC_START();
IIC_TX_DATA(0x21); //写入[0010xxx1] 读操作命令
delay(50);
IIC_TX_DATA(0x00);
delay(50);
IIC_TX_DATA(0x02);
delay(50);
mDelay(250);
while(1)
uint i =0;
for(i=0;i<8;i++)
Temp[i] = IIC_RX_DATA();
IIC_ACK();
delay(50);
我也刚做完IIC还好成功了,是向eeprom中读写数据折腾了我一周。具体步骤就按照msp430的pdf文件就好,另外在传输数据时加些延时。我就是因为少了个延时在读数据时老是把地址也写进rom中,我在写数据结束后加些延时就解决问题了  详情 回复 发表于 2009-7-26 15:23
82
你到底是模拟的 还是硬件的?
子函数貌似模拟的 主函数里又有硬件i2c模块的配置程序 咋搞的?
62
要读的芯片是美芯公司的MXC6202xG/H/M/N
66
请高手帮我指出哪里错了,我想用的是模拟的
送你一个模拟的i2c主机程序
代码:
#include <msp430x44x.h>
#define   SET_SCL     D4DIR &= ~BIT6
#define   SET_SDA     D4DIR &= ~BIT7
#define   CLR_SCL     P4DIR |=  BIT6
#define   CLR_SDA     P4DIR |=  BIT7
unsigned char ACK_flag;
void init_I2C(void)
  P4OUT = 0;
  P4DIR = 0;     //全部为输入状态,即位高电平
void START(void)//SCL为高的时候,SDA一个下降沿
SET_SDA;
SET_SCL;
Delay(5);
CLR_SDA;
Delay(5);
CLR_SCL;
void STOP(void)//SCL为高的时候,SDA一个上升沿
CLR_SCL;
CLR_SDA;
SET_SCL;
Delay(5);
SET_SDA;
Delay(5);
CLR_SCL;
  函数(模块)名称:
  功能:	应答信号
  输入参数: 无
  输出参数: 无
  函数返回值说明:无
  使用的资源:
  它说明: 从机发ACK告诉主机一个字节的读/写操作完成
void ACK(void)//SCL为高的时候,SDA为低
CLR_SDA;
SET_SCL;
Delay(5);
CLR_SCL;
Delay(5);
SET_SDA;
  函数(模块)名称:
  功能:	非应答信号
  输入参数: 无
  输出参数: 无
  函数返回值说明:无
  使用的资源:
  它说明: 主机发NO_ACK告诉从机读操作完成
void NO_ACK(void)//SCL为高的时候,SDA也为高
SET_SDA;
SET_SCL;
Delay(5);
CLR_SCL;
Delay(5);
CLR_SDA;
  函数(模块)名称:
  功能:	等待应答信号
  输入参数: 无
  输出参数: 无
  函数返回值说明:无
  使用的资源:
  它说明: 从机有应答则ACK_flag=0,否则为1
void Wait_ACK(void)//主机释放总线,等待回应信号
SET_SDA;
SET_SCL;
ACK_flag=0;
Delay(5);
if(P4IN & BIT7)
  ACK_flag=1;  //无回应信号,ACK_flag=1
Delay(5);
CLR_SCL;
  函数(模块)名称:
  功能:	完成一个字节的写操作
  输入参数: 要写的数据
  输出参数: 无
  函数返回值说明:
  使用的资源
  它说明:
void Write8bit(unsigned char date)
char bits=8;
while(bits-- != 0)
  if(date & 0x80)
     SET_SDA;
  else
     CLR_SDA;
  SET_SCL;
  Delay(10);
  date <<= 1;
  CLR_SCL;
  函数(模块)名称:
  功能:	完成一个字节的读操作
  输入参数: 无
  输出参数: 所读数据
  函数返回值说明:
  使用的资源
  其它说明:
unsigned char Read8bit(void)
 char bits=8;
unsigned char temp=0;
while(bits-- != 0)
  SET_SDA;
  SET_SCL;              //接收方,在SCL为高的时候读SDA
  temp<<=1;
  Delay(5);
  if(P4IN & BIT7)
  temp=temp|0x01;
  Delay(5);
  CLR_SCL;
return(temp);
  函数(模块)名称:
  功能:	完成24LC01的字节写
  输入参数: 被写数据地址,数据写入地址,写数据的字节数
  输出参数: 0或者1
  函数返回值说明: 页写成功返回0,否则返回1
  使用的资源
  其它说明:
unsigned char ByteWrite24LC01(unsigned char *p_date,unsigned char adr,
                         unsigned char nbyte)
while(nbyte-- != 0)
  START();
  Write8bit(W_DEVICE_ADR);   //发送设备地址
  Wait_ACK();
  if( ACK_flag==1 )         //无应答(写一个字节要等待从设备返回一个应答)
  return 1;
  Write8bit(adr);            //24LC01中被写的首地址
  Wait_ACK();
  return 1;
  Write8bit(*p_date);        //发送数据
  Wait_ACK();
  return 1;
  p_date++;
  adr++;
  STOP();
   return 0;
  函数(模块)名称:
  功能:	完成24LC01的页写
  输出参数: 0或者1
  使用的资源
  其它说明:一页是8个字节,页写时注意页地址,否则出错
unsigned char PageWrite24LC01(unsigned char *p_date,unsigned char adr,
  unsigned int x,y;
  unsigned char z;
  START();
  x=8-adr%8;
  y=adr+x;
  z=nbyte-x;
  Wait_ACK();
  return 1;
  Wait_ACK();
  return 1;
  while(x-- != 0)
  Wait_ACK();
  return 1;
  p_date++;
  STOP();
  Delay5Ms_OPEN();
  LPM3;
  START();
   Wait_ACK();
  return 1;
  Write8bit(y);            //24LC01中被写的首地址
  Wait_ACK();
  return 1;
  while(z-- != 0)
  Wait_ACK();
  return 1;
  p_date++;
  STOP();
 Delay5Ms_OPEN();
 LPM3;
  return 0;
  函数(模块)名称:
  功能:	完成24LC01的随机读
  输入参数: 读出数据存入地址,被读数据地址
  输出参数: 0或者1
  函数返回值说明: 随机读成功返回0,否则返回1
  使用的资源
  其它说明:
unsigned char RandomRead(unsigned char *p_date,unsigned char adr)
START();
Wait_ACK();
if(  ACK_flag==1 )
  return 1;
Write8bit(adr);
Wait_ACK();
if(  ACK_flag==1 )
  return 1;
START();
Write8bit(R_DEVICE_ADR);
Wait_ACK();
if(  ACK_flag==1 )
  return 1;
*p_date=Read8bit();        //读数据
NO_ACK();                  //发送无应答信号
STOP();
return 0;
  函数(模块)名称:
  功能:	完成24LC01的连续读
  输入参数: 读出数据存入地址,被读数据地址,读数据的字节数
  输出参数: 0或者1
  函数返回值说明: 连续读成功返回0,否则返回1
  使用的资源
  其它说明:
unsigned char Read24LC01(unsigned char *p_date,unsigned char adr,
START();
Wait_ACK();
if(  ACK_flag==1 )
  return 1;
Write8bit(adr);
Wait_ACK();
if(  ACK_flag==1 )
  return 1;
START();
Wait_ACK();
if(  ACK_flag==1 )
  return 1;
while(nbyte-- != 1)          //读(nbyte-1)个字节
   ACK();                    //读完一个字节发送一个应答信号
   p_date++;
*p_date=Read8bit();          //读最后一个数据字节
NO_ACK();                    //发送无应答信号
STOP();
return 0;
void Delay(unsigned int m)
 while(m-- != 0);
55
使用模拟就不要设置IO的特殊功能
67
谢谢楼上两位高手的支持
53
IIC  我喜欢
62
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 13
