11059|12
79
大家帮我看一下,AD采样值抖动严重,用什么办法解决? [复制链接]
现在出现的情况是AD的显示结果后两位老是闪烁,我试过隆低系统频,加大AD采样定时器的分频,但问题依旧,这种方法对吗?还有别的好方法吗?
程序如下:
#include <msp430x13x.h>
#define vref 3300
void clock_init(void)
DCOCTL = 0x00;
//XT2晶振开启,高频模式,ALCK分频系数为8分频,选择内部电阻频率为最高.
BCSCTL1 =XT2OFF+XTS+DIVA_0+DIVA_1+DIVA_2+DIVA_0+RSEL2+RSEL1+RSEL0;
//MCLK的时钟为低速晶振
BCSCTL2=SELM_1+SELM_0+DIVM_1+DIVM_0+SELS+DIVS_3+DIVS_2+DIVS_1+DIVS_0;
/*ADC初始华*/
void adc_init(void)
ADC12CTL0=ADC12ON+MSC;
ADC12CTL1 =SHP+CONSEQ_1;
ADC12MCTL0 = INCH_0;
ADC12MCTL1 = INCH_1;
ADC12MCTL2 = INCH_2;
ADC12MCTL3 = INCH_3;
ADC12MCTL4 = INCH_4;
ADC12MCTL5 = INCH_5;
ADC12MCTL6 = INCH_6;
ADC12MCTL7 = INCH_7+EOS;
ADC12IFG=0xff;
ADC12IE = 0x80;
ADC12CTL0 |= ENC;
ADC12CTL0 |= ADC12SC;
#pragma vector=ADC_VECTOR
__interrupt void ADC_ISR (void)
adc_rel0 = ADC12MEM0;
adc_rel1 = ADC12MEM1;
adc_rel2 = ADC12MEM2;
adc_rel3 = ADC12MEM3;
adc_rel4 = ADC12MEM4;
adc_rel5 = ADC12MEM5;
adc_rel6 = ADC12MEM6;
adc_rel7 = ADC12MEM7;
adc_rel0 = (unsigned int)(((unsigned long)((unsigned long)adc_rel0*vref))/0xfff);
adc_rel1 = (unsigned int)(((unsigned long)((unsigned long)adc_rel1*vref))/0xfff);
adc_rel2 = (unsigned int)(((unsigned long)((unsigned long)adc_rel2*vref))/0xfff);
adc_rel3 = (unsigned int)(((unsigned long)((unsigned long)adc_rel3*vref))/0xfff);
adc_rel4 = (unsigned int)(((unsigned long)((unsigned long)adc_rel4*vref))/0xfff);
adc_rel5 = (unsigned int)(((unsigned long)((unsigned long)adc_rel5*vref))/0xfff);
adc_rel6 = (unsigned int)(((unsigned long)((unsigned long)adc_rel6*vref))/0xfff);
adc_rel7 = (unsigned int)(((unsigned long)((unsigned long)adc_rel7*vref))/0xfff);
电源的纹波一定要小才行。  详情 回复 发表于 2009-4-27 15:13
【讨论】
试试用平均值的方法
83
hfglq 兄,能说详细一点吗?
unint mov_××(unint * p_a)
unchar i;
unint k;
for (i=0;i<5;i++)
*p_a=ADC10MEM;
*(p_a+1)=*p_a;
p_a++;
k=*p_a; //Middle varia××e k;
for(i=0;i<5;i++)
p_a--;
k=k+*p_a;
k=(unint)k/6; //result=××arage value ;
return(k);
返回的k就是经过处理ok的值。供参考。
【讨论】
取10个值,去掉max/min然后取平均值
78
采样之前的噪声怎么样?滤波没?
66
lonely88请问一下,k=(unint)k/6;这条语句是什么意思,谢谢!!!
64
//result=××arage value ;后面不是注解了么?
"后两位闪烁",精度要求多高?
引用:
"后两位闪烁",精度要求多高?
0.001v ~ 0.002v
ADC12配置不正确。SHP=1为使用内部采样定时器,还需要配置SHT0和SHT1来配合输入信号源的阻抗。
例如:
// 输入通道0-7采样时间设置为1024个ADC12时钟
ADC12CTL0 = ADC12ON+SHT0_15+REFON+REF2_5V;
// 使用内部采样定时器
ADC12CTL1 = SHP + ADC12SSEL_3 + CONSEQ_0;
//等待10ms,确保基准电压稳定(MCLK=4MHz)
__delay_cycles(40000);
75
我在做MSP430F448 A/D转换实验的时候,AD输入端引入电源电压,即0~5VDC,一开始的时候显示位设计为4位,整数一位,小数后3位。编写程序、烧录程序后,点阵液晶显示屏上显示的数字整数位稳定,小数点后第一位稳定,但最后两位不断变化,无论如何都找不到稳定点。究其原因应该有以下几点:
1、电源电压小幅波动;
2、电源电压有波纹,不纯净;
3、电源内阻太大,引起供电不稳定;
4、线路上存在干扰;
5、最根本的一点就是业余条件下设计的这个AD转换系统压根不适合测量到小数点后四位的精度,应该通过转换量程的方法来解决。v档可以设计到小数后一位;如果需要检测精确到小数点后2位以上,应该增加mv档甚至nv档转换。
79
电源的纹波一定要小才行。
