4207|4
84
在C430里如何访问SR [复制链接]
在C430里如何访问SR
我直接访问:
SR|=BIT5;
编译的结果是SR没有定义
请教 如何访问SR
同楼上  详情 回复 发表于 2009-4-20 16:02
84
_BIC_SR();
_BIS_SR();
81
用IAR的Intrinsic 函数 :
void __bic_SR_register(unsigned short);// Clears bits in the SR register
void __bic_SR_register_on_exit(unsigned short);/ Clears bits in the SR register when an interrupt
// or monitor function returns
void __bis_SR_register(unsigned short);// Sets bits in the SR register
void __bis_SR_register_on_exit(unsigned short);// Sets bits in the SR register when an interrupt or
//monitor function returns
unsigned short __get_SR_register();// Returns the value of the SR register
unsigned short __get_SR_register_on_exit();// Returns the value that the processor status
//register will h××e when the current interrupt or
谢谢
谢谢 兄弟们!!!
77
同楼上
