3972|4
【求助】请各位高手帮忙看一下中断为什么进不去? [复制链接]
端口设置如下:
TACTL=TASSEL_2+TACLR+MC_2+TAIE;
CCTL1=CCIS_0+CM0+CAP+CCIE;
中断设置如下:
#pragma vector=TIMERA1_VECTOR
__interrupt void TimerA()
switch(TAIV)
case 2:
//代码
break;
case 10:
break;
溢出中断可以进去,但case 2:一直进不去,为什么?是不是端口设置的有问题,还是中断引脚使用的不对?我用的石MSP430F149的23脚(P2.3 CA0/TA1).各位大侠请指教小弟一下.
那用下面这个做做测试吧,呵呵。 //*********************************************************************** //  MSP-FET430P140 Demo - Timer_A0, Capture of ACLK/8 using SMCLK // //  Description: Input capture of ACLK/8 on P1.1(TA0) //  Run to breakpoint at the _NOP() instruction to see 16 capture //  values and the differences. //  ACLK = 32768Hz, MCLK = SMCLK = default ~800kHz //  //* An external watch crystal on XIN XOUT is required for ACLK *//        // //                MSP430F149 //             ----------------- //         /|\|              XIN|- //          | |                 | 32kHz //          --|RST          XOUT|- //            |                 | //            |        P2.0/ACLK|---+ //            |                 |   | //            |         P1.1/TA0|<--+ //            |                 | //            |             P1.0|--->LED // //  H. Grewal //  Texas Instruments Inc. //  Feb 2005 //  Built with IAR Embedded Workbench Version: 3.21A //****************************************************************************** #include  <msp430x14x.h> unsigned int new_cap=0; unsigned int old_cap=0; unsigned int cap_diff=0; unsigned int diff_array[16];                // RAM array for differences unsigned int capture_array[16];             // RAM array for captures unsigned char index=0; unsigned char count = 0; void main(void) {   volatile unsigned int i;   WDTCTL = WDTPW + WDTHOLD;                 // Stop watchdog timer   for (i=0; i<20000; i++)                   // Delay for crystal stabilization   {   }   P1DIR = 0x01;                             // Set P1.0 out,1.1 input dir   P1OUT &= ~0x01;                           // LED off   P1SEL = 0x02;                             // Set P1.1 to TA0   P2DIR = 0x01;                             // P2.0-ACLK   P2SEL |= 0x01;   BCSCTL1 |= DIVA_3;                        // ACLK/8   CCTL0 = CM_1 + SCS + CCIS_0 + CAP + CCIE; // Rising edge + CCI0A (P1.1)                                             // + Capture Mode + Interrupt   TACTL = TASSEL_2 + MC_2;                  // SMCLK + Continuous Mode   _BIS_SR(LPM0_bits + GIE);                 // LPM0 + Ena××e global ints } #pragma vector=TIMERA0_VECTOR __interrupt void TimerA0(void) {    new_cap = TACCR0;    cap_diff = new_cap - old_cap;    diff_array[index] = cap_diff;            // record difference to RAM array    capture_array[index++] = new_cap;    if (index == 16)    {      index = 0;      P1OUT ^= 0x01;                         // Toggle P1.0 using exclusive-OR    }    old_cap = new_cap;                       // store this capture value    count ++;    if (count == 32)    {      count = 0;      _NOP();                                // SET BREAKPOINT HERE    } }  详情 回复 发表于 2005-11-25 09:52
59
可能存在问题:
1。总中断未开
2。TA设置问题
75
用这个试试。
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P1DIR |= 0x01; // P1.0 output
CCTL1 = CCIE; // CCR1 interrupt ena××ed
CCR1 = 50000;
TACTL = TASSEL_2 + MC_2; // SMCLK, Contmode
_BIS_SR(LPM0_bits + GIE); // Enter LPM0 w/ interrupt
// Timer_A3 Interrupt Vector (TAIV) handler
__interrupt void Timer_A(void)
switch( TAIV )
case 2: // CCR1
CCR1 += 50000; // Add Offset to CCR1
break;
case 4: break; // CCR2 not used
case 10: break; // overflow not used
引用:
可能存在问题:
1。总中断未开
2。TA设置问题
总中断开了呀,溢出中断和WDT定时器中断都可以进去的...TA就是按照上面的设置的,是不是有不对的地方?
yinpeng兄,多谢!我需要TA1用做捕捉模式,你给的那个程序应该是用做定时器的吧?
我是用TA1捕捉脉冲,检测频率的,是不是在使用上还有要注意的地方?多谢
87
那用下面这个做做测试吧,呵呵。
// MSP430F149
// /|\| XIN|-
// | | | 32kHz
// --|RST XOUT|-
// | P2.0/ACLK|---+
// | P1.1/TA0|<--+
// | P1.0|--->LED
// H. Grewal
// Feb 2005
void main(void)
P2SEL |= 0x01;
new_cap = TACCR0;
if (index == 16)
index = 0;
count ++;
if (count == 32)
count = 0;
