3640|4
请大哥看看我的始终设置的对不对啊?有程序 [复制链接]
小弟想用149系统的高速时钟,PCB上的XT2的两个管脚连接了8M的晶振, 本人的系统要工作在8M的频率下,
串口也打算用8M晶振,请大哥看看我的关于时钟的程序是否正确,多谢大哥!!
void Init_clock(void) //系统时钟的初始化函数
{ BCSCTL1=XTS; //XT2震荡器开启,工作在高频模式
BCSCTL2=(SELM1+SELS); //MCLK时钟源为XT2CLK,没有分频,SMCLK为XT2CLK,没有分频
好用直接拿去用就可以了  详情 回复 发表于 2005-6-9 09:21
57
// MSP-FET430P140 Demo - USART0 UART 9600 Echo ISR, HF XTAL ACLK
// Description; Echo a received character, RX ISR used. Normal mode is LPM0,
// USART0 RX interrupt triggers TX Echo. Though not required, MCLK = LFXT1
// ACLK = MCLK = UCLK0 = LFXT1 = 3.58MHz
// Baud rate divider with 3.58Mhz XTAL @9600 = 3.58MHz/9600 = 372 (0174h)
// //*An external 3.58Mhz XTAL on XIN XOUT is required for ACLK*//
// MSP430F149
// /|\| XIN|-
// | | | 3.58MHz
// --|RST XOUT|-
// | P3.4|------------>
// | | 9600 - 8N1
// | P3.5|<------------
// M. Buccini
// Texas Instruments, Inc
// January 2002
// Built with IAR Embedded Workbench Version: 1.25A
#include <msp430x14x.h>
void main(void)
unsigned int i;
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
BCSCTL1 |= XTS; // ACLK = LFXT1 = HF XTAL
do
IFG1 &= ~OFIFG; // Clear OSCFault flag
for (i = 0xFF; i > 0; i--); // Time for flag to set
while ((IFG1 & OFIFG) == OFIFG); // OSCFault flag still set?
BCSCTL2 |= SELM1+SELM0; // MCLK = LFXT1 (safe)
UCTL0 = CHAR; // 8-bit character
UTCTL0 = SSEL0; // UCLK = ACLK
UBR00 = 0x74; // 3.58Mhz/9600 - 372
UBR10 = 0x01; //
UMCTL0 = 0x00; // no modulation
ME1 |= UTXE0 + URXE0; // Ena××e USART0 TXD/RXD
IE1 |= URXIE0; // Ena××e USART0 RX interrupt
P3SEL |= 0x30; // P3.4,5 = USART0 TXD/RXD
P3DIR |= 0x10; // P3.4 output direction
_EINT(); // Ena××e interrupts
for (;;)
_BIS_SR(CPUOFF); // Enter LPM0
_NOP(); // Required only for C-spy
interrupt[UART0RX_VECTOR] void usart0_rx (void)
while ((IFG1 & UTXIFG0) == 0); // USART0 TX buffer ready?
TXBUF0 = RXBUF0; // RXBUF0 to TXBUF0
61
这句好像没有必要吧,XTS是设置LFXT1的高频模式,跟你的没啥关系!
77
看看我的高频吧!!!!
BCSCTL1 =0;
do
IFG1 &=~ OFIFG;
for(i=0xFF;i>0;i++);
while((IFG1&OFIFG)!=0);
BCSCTL2 |= SELM1+SELS;
58
好用直接拿去用就可以了
【直播时间】5月28日(周三)上午10:00
