4100|0
小菜鸟求助 [复制链接]
代码如下:
CBitmap cbmap;
 cbmap.Attach(hbitmap);
 BYTE* bmpBuffer=(BYTE*)GlobalAlloc(GPTR, bmap.bmWidthBytes*bmap.bmHeight);
 DWORD dwValue=cbmap.GetBitmapBits(bmap.bmWidthBytes*bmap.bmHeight,bmpBuffer);
编译出现以下错误:
_CE_ACTIVEX was not defined because this Windows CE SDK does not have DCOM.
1> _CE_ACTIVEX could be caused to be defined by defining _CE_ALLOW_SINGLE_THREADED_OBJECTS_IN_MTA, but it is recommended that this be done only for single-threaded apps.
1>_ATL_NO_HOSTING was defined because _CE_ACTIVEX was not defined.
1>.\usestatic.cpp(106) : error C2039: 'GetBitmapBits' : is not a member of 'CBitmap'
1>        D:\Visual Studio\VC\ce\atlmfc\include\afxwin.h(408) : see declaration of 'CBitmap'
哪位大牛能指导以下该怎么弄啊?
