3300|2
63
很奇怪的问题,救命啊! [复制链接]
C6416EMIFA的CE0空间接了一片32bit的SDRAM,C6416的高32bit悬空不用,在对SDRAM进行写操作时,对一个地址操作会同时影响与其相邻16byte的地址空间,如对0x8000 0000写数据时,0x8000 0000和0x8000 0010的数据都会改变,同时对0x8000 0010操作也会改变0x8000 0000的数据,请问这是怎么一回事啊??
怀疑是EMIFA的配置问题, EMIFA的配置为: static EMIFA_Config MyEmifaConfig = {         EMIFA_GBLCTL_RMK         (                 EMIFA_GBLCTL_EK2RATE_FULLCLK,                        EMIFA_GBLCTL_EK2HZ_CLK,                                EMIFA_GBLCTL_EK2EN_ENABLE,                        EMIFA_GBLCTL_BRMODE_MRSTATUS,                 EMIFA_GBLCTL_NOHOLD_DISABLE,                 EMIFA_GBLCTL_EK1HZ_CLK,                                EMIFA_GBLCTL_EK1EN_ENABLE,                 EMIFA_GBLCTL_CLK4EN_ENABLE,                        EMIFA_GBLCTL_CLK6EN_ENABLE                ),         0xffffff33,                //32BIT SDRAM         0xffffff13,         0xffffff13,         0xffffff13,         EMIFA_SDCTL_RMK         (                 EMIFA_SDCTL_SDBSZ_4BANKS,                        EMIFA_SDCTL_SDRSZ_12ROW,                        EMIFA_SDCTL_SDCSZ_8COL,                                EMIFA_SDCTL_RFEN_ENABLE,                 EMIFA_SDCTL_INIT_YES,                        //SDRAM 配置完每个CE空间后,初始化                 EMIFA_SDCTL_TRCD_OF(1),                //TRCD = 20ns                 EMIFA_SDCTL_TRP_OF(1),                //TRP = 20ns                 EMIFA_SDCTL_TRC_OF(6),                 EMIFA_SDCTL_SLFRFR_DISABLE        //self refresh mode disable         ),         EMIFA_SDTIM_RMK         (                 EMIFA_SDTIM_XRFR_DEFAULT,        //EXT TIMER default                 EMIFA_SDTIM_PERIOD_OF(1560)        //64ms, 4096 cycle refresh         ),         EMIFA_SDEXT_RMK         (                 EMIFA_SDEXT_WR2RD_OF(0),        //cycles between write to read command = 1 CLK                 EMIFA_SDEXT_WR2DEAC_OF(1),        //cycles between write to precharge                 EMIFA_SDEXT_WR2WR_OF(0),        //cycles between write to write = 1 CLK                 EMIFA_SDEXT_R2WDQM_OF(1),        //cycles between read to bex = 2 CLK                 EMIFA_SDEXT_RD2WR_OF(0),        //cycles between read to write = 1 CLK                 EMIFA_SDEXT_RD2DEAC_OF(1),        //cycles between read to precharge                 EMIFA_SDEXT_RD2RD_OF(0),        //cycles between read to read = 1 CLK                 EMIFA_SDEXT_THZP_OF(0),                //Troh = 2 CLK                 EMIFA_SDEXT_TWR_OF(1),                //Twr >= 1 CLK +7 ns                 EMIFA_SDEXT_TRRD_OF(0),                //Trrd >= 14ns                 EMIFA_SDEXT_TRAS_OF(4),                //Tras >= 42ns                 EMIFA_SDEXT_TCL_OF(0)                //cas latency = 2 CLK         ),         0x00000002,         0x00000002,         0x00000002,         0x00000002 }; SDRAM时钟为100M,使用的是MT48LC4M32b2-7,1M*4BAMK*32bit,自己实在看不出什么问题,麻烦大家帮我看看。   详情 回复 发表于 2009-6-4 09:02
我仔细查了下硬件,数据线、地址线都没有问题,数据类型定义为Unsigned int。而且如果用16bit的SDRAM,数据类型相应的改为Unsigned short时,此时相互影响的为每相隔8Byte的地址,如写数据到0x8000 0000,会使0x8000 0008内数据改变,反之也是。如果用8bit的SDRAM,相互影响的是0x8000 0000和0x8000 0004。这个是否与字节对齐有关?
84
怀疑是EMIFA的配置问题,
EMIFA的配置为:
        EMIFA_GBLCTL_RMK
        0xffffff13,
        0xffffff13,
        0xffffff13,
        EMIFA_SDCTL_RMK
        EMIFA_SDTIM_RMK
        EMIFA_SDEXT_RMK
        0x00000002,
        0x00000002,
        0x00000002,
        0x00000002
