5373|7
2812使用外部ram的问题 [复制链接]
诸位达人:请问在仿真时,如何load程序到外部ram,怎么总是提示
Data verification failed at address 0x80000.
Please verify target memory and memory map.
使用过了gel文件初始化了memory_map,还是提示类似错误
Link的CMD文件分配的地址同GEL或设置的有效地址空间不符 请教一下如何设置有效的地址空间  外部RAM是直接挂在ZONE2区域上的 MEMORY { PAGE 0 :    BEGIN      : origin = 0x80000, length = 0x000002    PRAMH0     : origin = 0x80002, length = 0x007FFE                 PAGE 1 :    /* SARAM                     */         RAMM0      : origin = 0x000000, length = 0x000400    RAMM1      : origin = 0x000400, length = 0x000400           /* SARAM                    */         DRAMH0     : origin = 0x88000, length = 0x008000                 /* Peripheral Frame 0:   */    DEV_EMU    : origin = 0x000880, length = 0x000180    FLASH_REGS : origin = 0x000A80, length = 0x000060    CSM        : origin = 0x000AE0, length = 0x000010    XINTF      : origin = 0x000B20, length = 0x000020    CPU_TIMER0 : origin = 0x000C00, length = 0x000008    CPU_TIMER1 : origin = 0x000C08, length = 0x000008                     CPU_TIMER2 : origin = 0x000C10, length = 0x000008                     PIE_CTRL   : origin = 0x000CE0, length = 0x000020    PIE_VECT   : origin = 0x000D00, length = 0x000100    /* Peripheral Frame 1:   */    ECAN_A     : origin = 0x006000, length = 0x000100    ECAN_AMBOX : origin = 0x006100, length = 0x000100    /* Peripheral Frame 2:   */    SYSTEM     : origin = 0x007010, length = 0x000020    SPI_A      : origin = 0x007040, length = 0x000010    SCI_A      : origin = 0x007050, length = 0x000010    XINTRUPT   : origin = 0x007070, length = 0x000010    GPIOMUX    : origin = 0x0070C0, length = 0x000020    GPIODAT    : origin = 0x0070E0, length = 0x000020    ADC        : origin = 0x007100, length = 0x000020    EV_A       : origin = 0x007400, length = 0x000040    EV_B       : origin = 0x007500, length = 0x000040    SPI_B      : origin = 0x007740, length = 0x000010    SCI_B      : origin = 0x007750, length = 0x000010    MCBSP_A    : origin = 0x007800, length = 0x000040    /* CSM Password Locations */    CSM_PWL    : origin = 0x3F7FF8, length = 0x000008 }    SECTIONS {    /* Allocate program areas: */    codestart        : > BEGIN,       PAGE = 0        .reset           : > PRAMH0,       PAGE = 0   ,TYPE=DSECT        .text            : > PRAMH0,      PAGE = 0    .cinit           : > PRAMH0,      PAGE = 0    .pinit           : > PRAMH0,      PAGE = 0    .switch          : > PRAMH0,      PAGE = 0    /* Allocate data areas: */    .stack           : > RAMM1,       PAGE = 1    .bss             : > DRAMH0,      PAGE = 1    .ebss            : > DRAMH0,      PAGE = 1    .const           : > DRAMH0,      PAGE = 1    .econst          : > DRAMH0,      PAGE = 1          .sysmem          : > DRAMH0,      PAGE = 1    .esysmem         : > DRAMH0,      PAGE = 1    /* Allocate Peripheral Frame 0 Register Structures:   */    DevEmuRegsFile    : > DEV_EMU,    PAGE = 1    FlashRegsFile     : > FLASH_REGS, PAGE = 1    CsmRegsFile       : > CSM,        PAGE = 1    XintfRegsFile     : > XINTF,      PAGE = 1    CpuTimer0RegsFile : > CPU_TIMER0, PAGE = 1          CpuTimer1RegsFile : > CPU_TIMER1, PAGE = 1          CpuTimer2RegsFile : > CPU_TIMER2, PAGE = 1          PieCtrlRegsFile   : > PIE_CTRL,   PAGE = 1          PieVectTable      : > PIE_VECT,   PAGE = 1    /* Allocate Peripheral Frame 2 Register Structures:   */    ECanaRegsFile     : > ECAN_A,      PAGE = 1       ECanaMboxesFile   : > ECAN_AMBOX   PAGE = 1    /* Allocate Peripheral Frame 1 Register Structures:   */    SysCtrlRegsFile   : > SYSTEM,     PAGE = 1    SpiaRegsFile      : > SPI_A,      PAGE = 1    SciaRegsFile      : > SCI_A,      PAGE = 1    XIntruptRegsFile  : > XINTRUPT,   PAGE = 1    GpioMuxRegsFile   : > GPIOMUX,    PAGE = 1    GpioDataRegsFile  : > GPIODAT     PAGE = 1    AdcRegsFile       : > ADC,        PAGE = 1    EvaRegsFile       : > EV_A,       PAGE = 1    EvbRegsFile       : > EV_B,       PAGE = 1    ScibRegsFile      : > SCI_B,      PAGE = 1    McbspaRegsFile    : > MCBSP_A,    PAGE = 1    /* CSM Password Locations */    CsmPwlFile      : > CSM_PWL,     PAGE = 1 } 这个是CMD文件  麻烦帮忙看看好吗 多谢了  详情 回复 发表于 2012-2-21 13:11
不了解2812架构
如过你的2812 0x8000处要是ram的话,而且你的cmd文件没有错误的话,那就是硬件上面的问题, 比如说2407有一个外部存储器始能引脚, 需要上拉! 2812我不是很清楚。
楼主这个问题解决了吗?我是外扩到ZONE6,也是不行.大家有这方面的知识请指教.
有可能是这种原因
还是每次load程序到外部ram时总是提示校验错误 ,但是程序照样可以运行
57
我在程序里定义一个外部RAM的地址,可以给其写值.所以说外部RAM是好的.但还是没找到原因,LOAD PROGRAM的时候总不成功
我也遇到了同样的问题  在2区外接了一个RAM256X16的  使用内部RAM仿真时可以对其正确读写数据  但是修改CMD文件后将程序LOAD进外部RAM  却出现了
  求助各位  这样的问题如何解决
283
“Link的CMD文件分配的地址同GEL或设置的有效地址空间不符。中断向量定位处或其它代码、数据段定位处,没有RAM,无法加载OUT文件。解决方法: 1)调整Link的CMD文件,使得定位段处有RAM。 2)调整存储器设置,使得RAM区有效。 ”
根据实际的模块的原理图,修改下CMD文件,把0x80000修改更大些试试.
MEMORY
PAGE 0 :
PAGE 1 :
   /* SARAM                     */
   /* SARAM                    */
SECTIONS
