4308|2
f2812烧写问题 [复制链接]
各位大侠,小弟现在碰到难题,在写flash时,总是遇到这样的提示:
Code Composer could not locate:
FlashApIInterface.c
Would you like to browse for it?
点“取消”提示烧写成功,而且必须用仿真器才能起动,掉电重起去怎么也不能运行
哪位高手能告诉我是怎么回事?应该怎么解决?
可以不用理会它。 EEWORLD老师,可是帮我分析如下烧写问题是怎么造成的吗?应该如何解决啊? **** Begin Erase/Program/Verify Operation. *** Erase/Program/Verify Operation in progress... Erase operation in progress... Erase operation was successful. Program operation in progress... Program operation was successful. Verify operation in progress... Verify operation successful. Load RAM operation in progress... Load RAM operation was successful. Warning: This program contains initialized RAM data. It may run successfully under Code Composer Studio but not as a standalone system because of this. If your Flash program requires initialized data in RAM, you will need to write Flash code to initialize RAM memory. Erase/Program/Verify Operation succeeded **** End Erase/Program/Verify Operation. ***   详情 回复 发表于 2006-11-25 11:58
59
没关系
可是断电重起后,怎么都不能运行啊
可以不用理会它。
