3772|3
2407板子load的时候出现问题了 [复制链接]
我是光盘里面拷出来的程序GPIO的,编译可以通过但是在load的时候提示
这个是我的cmd文件:
Data verfication failed at address 0x100h,我觉得在程序和数据空间分配上没有什么问题,但是就是Load不了,请工程师帮我解答一下
MEMORY
  PAGE 0:
        VECS            origin = 0000h,         length = 0040h
        FLASH:          origin =0100h,         length = 7F00h
        SARAM_P:        origin = 8100h,         length = 1000h
  PAGE 1:
        B2:             origin = 0060h,         length = 020h
        B0:             origin = 200h,         length = 100h
        B1:             origin = 300h,         length = 100h
        SARAM_D:        origin = 0C00h,         length = 400h
SECTIONS
        vectors:        > VECS          PAGE 0
        .text:          > FLASH         PAGE 0
        .data:          > FLASH         PAGE 0
        .bss:           > B2            PAGE 1
        stack:          > B1            PAGE 1
        buffer:         > SARAM_D       PAGE 1
这个是我的gel文件:
#define SCSR1         0x7018
#define SCSR2         0x7019
#define MP        0x0f
#define MC        0x0b
/* The Startup() function is executed when the GEL file is loaded. */
StartUp()
        F2407_Init();
F2407_Init()
        GEL_Reset();
        GEL_MapReset();
        GEL_MapOn();
        GEL_MapAdd(0x0000,0,0x8000,1,1);        /* Flash/External SRAM */
        GEL_MapAdd(0x8000,0,0x8000,1,1);        /* External SRAM */
        GEL_MapAdd(0x0000,1,0x0060,1,1);        /* MMR */
        GEL_MapAdd(0x0060,1,0x0020,1,1);        /* B2 */
        GEL_MapAdd(0x0200,1,0x0100,1,1);        /* B0 */
        GEL_MapAdd(0x0300,1,0x0100,1,1);        /* B1 */
        GEL_MapAdd(0x0800,1,0x0800,1,1);        /* SRAM */
        GEL_MapAdd(0x1000,1,0xF000,1,1);        /* External SRAM */
menuitem \"F2407 DEBUGGER\";
hotmenu flash_disable()
        *(int *)SCSR2 = MP;
hotmenu flash_enable()
        *(int *)SCSR2 = MC;
这个是我的asm文件:
.global     start
        .global                PHANTOM
        .data
b0        .word        0fffEh                ;turn-on GPIO0
b1        .word        0fffDh                ;turn-on GPIO1
b2        .word        0fffBh                ;turn-on GPIO2
b3        .word        0fff7h                ;turn-on GPIO3
b4        .word        0ffEFh                ;turn-on GPIO0
b5        .word        0ffDFh                ;turn-on GPIO1
b6        .word        0ffBFh                ;turn-on GPIO2
b7        .word        0ff7Fh                ;turn-on GPIO3
GPR0        .word        0
        .include f2407.h
KICK_DOG        .macro
        LDP        #00E0h                ;DP-->7000h-707fh
        SPLK        #05555h,WDKEY
        SPLK        #0aaaah,WDKEY
        LDP        #0h                ;DP-->0000h-007fh
        .endm
        .text
start:
        LDP        #0h
        SETC        INTM
        SETC        CNF
        SPLK        #0000h,IMR
        LACC        IFR
        SACL        IFR
        LDP        #00E0h
        SPLK        #0200h,SCSR1
        SPLK        #006Fh,WDCR
        KICK_DOG
        SPLK        #0h,GPR0
        OUT        GPR0,WSGR
        LDP        #00E1h
        SPLK        #00000h,MCRA
        SPLK        #0FF00h,MCRB
        SPLK        #00000h,MCRC
        SPLK        #0FFFFh,PADATDIR
        SPLK        #0FFFFh,PBDATDIR
        SPLK        #0FFFFh,PCDATDIR
        SPLK        #0FFFFh,PEDATDIR
        SPLK        #0FFFFh,PFDATDIR
MAIN:
        LDP        #0
LOOP:
        LDP        #00E1h
        setc        xf
        CALL        DELAY
        CALL        DELAY
        CALL        DELAY
        CALL        DELAY
        CALL        DELAY
        CALL        DELAY
        CALL        DELAY
        clrc        xf
        CALL        DELAY
        SPLK        #0FF00h,PADATDIR
        CALL        DELAY
        SPLK        #0FF00h,PBDATDIR
        CALL        DELAY
        SPLK        #0FF00h,PCDATDIR
        CALL        DELAY
        SPLK        #0FF00h,PEDATDIR
        CALL        DELAY
        SPLK        #0FF00h,PFDATDIR
        CALL        DELAY
    CALL        DELAY
        B        MAIN
DELAY:
D_LOOP:
        RPT        #0FFh
        NOP
        RET
PHANTOM:
        KICK_DOG
        B        PHANTOM
结果就是load不了,提示数据空间有错,我也照FAQ上面的提示分配了数据和程序存储空间,还是不行,我的这块2407才刚买的,应该没问题的。我是完全照给我的光盘上面的GPIO程序,但就是load不了。仿真器和板子接上以后也有按安装说明的提示reset成功,不知道问题出在哪,请各位大侠帮帮我。
楼主问题解决了吗?LOAD之前选择一下GEL菜单下的disable flash看看  详情 回复 发表于 2007-10-22 09:26
跳线都接对了吗?
你试试将
section
       .data       : { }  > B1_DARAM  PAGE 1
83
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
