7304|13
66
STM32的USB如何能枚举出多个设备? [复制链接]
各位高手:
       我现在在做一个USB的读卡器,因读卡器上有三个插糟,想三个插糟对应在主机上显示出三个设备,请问该如何配置,现在只能显示一个设备,
   0x12,   /* bLength  */
    0x01,   /* bDescriptorType */
    0x01,   /* bcdUSB, version 2.00 */
    0x10,
    0x00,   /* bDeviceClass : each interface define the device class */
    0x00,   /* bDeviceSubClass */
    0x00,   /* bDeviceProtocol */
    0x40,   /* bMaxPacketSize0 0x40 = 64 */
    0x3C,   /* idVendor  */
    0x16,
    0x03,   /* idProduct */
    0x0A,   //W5181  Reader
    0x00,   /* bcdDevice 1.00*/
    0x01,
    1,              /* index of string Manufacturer  */
    2,              /* index of string descriptor of product*/
    3,              /* */
    0x01    /*bNumConfigurations */
    0x09,   /* bLength: Configuation Descriptor size */
    0x02,   /* bDescriptorType: Configuration */
    0x5D,
    0x00,
    0x01,   /* bNumInterfaces: 1 interface */
    0x01,   /* bConfigurationValue: */
    /*      Configuration value */
    0x00,   /* iConfiguration: */
    /*      Index of string descriptor */
    /*      describing the configuration */
    0x80,
    0x46,    // 140=70*2 mA power consumption.
    /******************** Descriptor of Mass Storage interface ********************/
    /* 09 */
    0x09,   /* bLength: Interface Descriptor size */
    0x04,   /* bDescriptorType: */
    /*      Interface descriptor type */
    0x00,   /* bInterfaceNumber: Number of Interface */
    0x00,   /* bAlternateSetting: Alternate setting */
//   0x02,   /* bNumEndpoints*/
    0x03,   //by lmp BUIK_OUT Endpoint,BUIK_IN Endpoint, Interrupt_IN Endpoint
    0x0B,         //by LMP bInterfaceClass: Smart Card Device Class
    0x00,   /* bInterfaceSubClass : without SubClass*/
    0x00,   // bInterfaceProtocol: CCID
    0x00,   // iInterface: Index of string descriptor
    /* 18 */
    //CCID class descriptor
0x36,  // bLength: CCID Descriptor size 54Bytes
0x21,  // bDescriptorType
0x10,0x01, // bcdCCID: CCID Class Spec release number (1.1)
0x02,  // bMaxSlotIndex  Sim_card,Contactless_Card ,Non-contact card
0x06,  // bVoltageSupport: 5v,3v,1.8v only support Contactless_Card
0x03,0x00,0x00,0x00,  // dwProtocols: supports T=0
0xFC,0x0D,0x00,0x00,  // dwDefaultClock: 3.58Mhz
0xF0,0x37,0x00,0x00,  // dwMaximumClock: 14.32Mhz
0x00,    // bNumClockSupported => no manual setting
0x80,0x25,0x00,0x00,  // dwDataRate: 9600 bps (0x00002580)
0x29,0x40,0x29,0x00,  // dwMaxDataRate: 344105 bps (0x00054029)
0x00,    // bNumDataRatesSupported => no manual setting
0xFc,0x00,0x00,0x00,  // dwMaxIFSD: 255 (T=1 ) Information Field Size For The Terminal
0x00,0x00,0x00,0x00,  // dwSynchProtocols
0x00,0x00,0x00,0x00,  // dwMechanical: no special characteristics
0xBA,0x00,0x01,0x00,  // dwFeatures:TPDU Level
0x0F,0x01,0x00,0x00,  // dwMaxCCIDMessageLength 10+261 : header+Maximun block size
0xFF,   // bClassGetResponse
0xFF,   // bClassEnvelope
0x00,0x00,  // wLcdLayout
0x00,   // bPINSupport : no PIN verif and modif
0x03,   // bMaxCCIDBusySlots
    /* 0x49  73 */
    0x07,   /*Endpoint descriptor length = 7*/
    0x05,   /*Endpoint descriptor type */
    0x81,   /*Endpoint address (IN, address 1) */
    0x02,   /*Bulk endpoint type */
    0x40,   /*Maximum packet size (64 bytes) */
    0x00,
    0x00,   /*Polling interval in milliseconds */
   // /* 25 */
    /* 0x50  80*/
    0x07,   /*Endpoint descriptor length = 7 */
    0x02,   /*Endpoint address (OUT, address 2) */
    0x00,
    0x00,     /*Polling interval in milliseconds*/
    0x83,   /*Endpoint address (IN, address 3) */
    0x03,   /*Bulk endpoint type Interrupt */
    0x04,   /*Maximum packet size (4 bytes) */
    0x00,
    0x20,     /*Polling interval in milliseconds*/
    /*32*/
郁闷了好几天了.一直没解决,请高手指点迷津!谢谢啦
此帖出自stm32/stm8论坛
                                 最后结果怎样了?请楼主说明,谢谢!  详情 回复 发表于 2011-3-10 10:27
67
首先,枚举出多个USB设备与枚举出USB读卡器上的多个插槽,完全是2回事。枚举出多个USB设备,是复合设备的概念,而枚举出多个插槽是在大容量存储协议层面上的问题。
其次,请参考USB大容量存储协议中的Get_MAXLUN命令,实现枚举出多个插槽的操作。
此帖出自stm32/stm8论坛
2楼你好,
       我的设备是按照CCID协议配置的,按照协议已经配置成3个插糟的读卡器,采用的是中断方式.向主机发50 03,表示0#插糟有卡插入,主机会向0#插糟发一系列命令, 但是我向主机发 50 C0,表示1#插糟有卡插入,主机便不响应.不知该如何解决,请高手指点.谢谢!
25.3  DI     50 03                                               P.                       1.1.0        2.7sc
  25.2  DO     63 00 00 00  00 00 01 00  00 00                     c.........               2.1.0        1.9ms
  25.1  DI     81 00 00 00  00 00 01 00  00 00                     ..........               3.1.0        1.9ms
  25.2  DO     62 00 00 00  00 00 02 00  00 00                     b.........               4.1.0        1.9ms
  25.1  DI     80 11 00 00  00 00 02 00  00 00 3b 6d  00 00 57 44  ..........;m..WD         5.1.0         16ms
               29 32 86 86  43 0e 9a 01  05 11 24                  )2..C.....$              5.1.16
  25.2  DO     61 05 00 00  00 00 03 00  00 00 11 00  00 0a 00     a..............          6.1.0        969us
  25.1  DI     82 05 00 00  00 00 03 00  00 00 11 00  00 0a 00     ...............          7.1.0        1.9ms
  25.3  DI     50 02                                               P.                       8.1.0        3.9sc
  25.3  DI     50 03                                               P.                       9.1.0        1.4sc
  25.2  DO     63 00 00 00  00 00 04 00  00 00                     c.........              10.1.0        1.9ms
  25.1  DI     81 00 00 00  00 00 04 00  00 00                     ..........              11.1.0        2.0ms
  25.2  DO     62 00 00 00  00 00 05 00  00 00                     b.........              12.1.0        2.0ms
  25.1  DI     80 11 00 00  00 00 05 00  00 00 3b 6d  00 00 57 44  ..........;m..WD        13.1.0         16ms
               29 32 86 86  43 0e 9a 01  05 11 24                  )2..C.....$             13.1.16
  25.2  DO     61 05 00 00  00 00 06 00  00 00 11 00  00 0a 00     a..............         14.1.0        997us
  25.1  DI     82 05 00 00  00 00 06 00  00 00 11 00  00 0a 00     ...............         15.1.0        1.9ms
  25.3  DI     50 c0                                               P.                       1.1.0        2.0sc
  25.3  DI     50 80                                               P.                       2.1.0        1.3sc
  25.3  DI     50 c0                                               P.                       3.1.0        864ms
  25.3  DI     50 80                                               P.                       4.1.0        992ms
  25.3  DI     50 c0                                               P.                       5.1.0        607ms
  25.3  DI     50 80                                               P.                       6.1.0        896ms
此帖出自stm32/stm8论坛
82
顶一下
     我做的是智能卡读写器.
此帖出自stm32/stm8论坛
79
       我的设备是按照CCID协议配置的,按照协议已经配置成3个插糟的读卡器,采用的是中断方式.向主机发50 03,表示0#插糟有卡插入,主机会向0#插糟发一系列命令, 但是我向主机发 50 C0,表示1#插糟有卡插入,主机便不响应.不知该如何解决 ...
这个问题你只能从主机端的软件或驱动方面找原因了,你要找开发主机端软件和驱动的人询问。
此帖出自stm32/stm8论坛
                                 应该是驱动方面的问题。。。
此帖出自stm32/stm8论坛
各位好,
        CCID设备的驱动是Vista自带的驱动,应该是标准驱动.
此帖出自stm32/stm8论坛
                                 你能确定这个所谓的“标准驱动”支持多个插槽的操作吗?有什么证据?
此帖出自stm32/stm8论坛
CCID中规定插糟最多可以达到00-0F(16个),
smart card.JPG (91.91 KB)
此帖出自stm32/stm8论坛
67
我知道CCID的规定,问题是“Vista自带的驱动能否支持多个插槽的操作?有什么证据?”
此帖出自stm32/stm8论坛
84
版主,你好!
       现在还不知道Vista是否支持多个插糟,所以想用枚举多个设备的方法解决这个难题目.我们近来一直用STM32芯片做产品,望能给些建设,谢谢!
此帖出自stm32/stm8论坛
79
                                 我在2楼已经说了“枚举出多个USB设备,是复合设备的概念”,你需要通过定义多个Interface实现一个复合设备。但我们没有做个具有多个相同功能的复合设备,不知道这个方案是否可行,但值得尝试。
此帖出自stm32/stm8论坛
谢谢!
       这按这个方法试一下.
此帖出自stm32/stm8论坛
63
                                 最后结果怎样了?请楼主说明,谢谢!
此帖出自stm32/stm8论坛
