3181|3
65
关于IAPoverIIC的例程 [复制链接]
void Write_Memory_Command(void)
    uint16_t WriteCounter= 0;
    uint16_t Number_Bytes_Transferred = 0;
    uint32_t Add_Flash,DATA_SIZE_IN_PAGE = 0;
    uint16_t Idx = 0;
    /* Wait until receiving Flash address to  write into + number of data to be written
      + the data to be written */
    while (Rx_Idx!= 0);
    /* Read the address  */
    Add_Flash = Read_Add();
    /* Read the number of bytes to be written  */
    Number_Bytes_Transferred = Read_Byte_Page_Number();
    if (Number_Bytes_Transferred <= PAGE_SIZE)
        DATA_SIZE_IN_PAGE = 1;
    else
        if ((Number_Bytes_Transferred%PAGE_SIZE)==0)
            DATA_SIZE_IN_PAGE= Number_Bytes_Transferred/PAGE_SIZE;
        else
            DATA_SIZE_IN_PAGE=(uint32_t) (Number_Bytes_Transferred/PAGE_SIZE)+1;
    for (Idx=4; Idx<(Number_Bytes_Transferred+8)/2; Idx++)
        I2C1_Buffer_Rx[2*Idx+1]=I2C1_Buffer_Rx[2*Idx+1]<<8;
        I2C1_Buffer_Rx[2*Idx]=I2C1_Buffer_Rx[2*Idx]|I2C1_Buffer_Rx[2*Idx+1];
#if defined USE_STM3210B_EVAL  || USE_STM32100B_EVAL
  Erase_Page(Add_Flash,DATA_SIZE_IN_PAGE);
#elif defined USE_STM3210E_EVAL ||  USE_STM3210C_EVAL
  if (((Add_Flash/(PAGE_SIZE/(PAGE_SIZE/Number_Bytes_Transferred)))&1)==0)
#endif
    for (WriteCounter = 0; (WriteCounter < (Number_Bytes_Transferred)/2 ); WriteCounter++)
        FLASH_ProgramHalfWord((Add_Flash+2*WriteCounter), I2C1_Buffer_Rx[2*(WriteCounter+4)]);
    opcode=0;
请问其中下面这句为什么Number_Bytes_Transferred要+8呢
此帖出自stm32/stm8论坛
                                   版主,还有我生成了bin文件,IAP的话是把整个bin文件写到flash里面去吗?  详情 回复 发表于 2011-1-13 17:28
55
你断章取义地不知道从哪里抄来一段程序,谁知道是什么意思?
提问题,请首先说明背景和出处。
此帖出自stm32/stm8论坛
不好意思版主,没说清楚,是官网上的AN3078(in-application programming over IIC)里面的command.c的,我不明白为什么在把收到的字节转成半字的时候,
这个Number_Bytes_Transferred要+8
此帖出自stm32/stm8论坛
66
此帖出自stm32/stm8论坛
直播时间:4月22日(周二)10:00
直播奖励:京东卡、蓝牙温湿度计、定制水杯
