3993|5
77
用过AT24C02的高手请指教! [复制链接]
#include <STM8S105C_S.h>
#define uchar unsigned char
#define uint unsigned int
#define data_out PB_DDR|=0X04;
#define data_in PB_DDR&=~0X04;
#define scl_H PB_ODR|=0X02;
#define scl_L PB_ODR&=~0X02;
#define sda_H PB_ODR|=0X04;
#define sda_L PB_ODR&=~0X04;
uchar low1,low2,high1,high2;
void wait(uint t)
uint x=0,y=0;
for(x=t;x>0;x--)
  for(y=2000;y>0;y--)
   _asm("NOP");
void delay1(uchar x)
uchar a=0,b=0;
for(a=x;a>0;a--)
  for(b=100;b>0;b--);
void delay(void)
_asm("NOP");
_asm("NOP");
_asm("NOP");
_asm("NOP");
_asm("NOP");
_asm("NOP");
_asm("NOP");
_asm("NOP");
_asm("NOP");
_asm("NOP");
_asm("NOP");
_asm("NOP");
_asm("NOP");
void gpio_init(void)
PB_DDR|=0X02;//PE1(scl)为输出,PE2(data)输入输出状态不确定
PB_CR1=0Xff;
PB_CR2=0X00;
void start(void)
data_out;
sda_H;
delay();
scl_H;
delay();
sda_L;
delay();
void stop(void)
data_out;
sda_L;
delay();
scl_H;
delay();
sda_H;
delay();
void respons(void)
uchar i=0;
sda_H;
delay();
scl_H;
delay();
data_in;
delay();
while(PB_IDR&0X04);
  // i++;
scl_L;
delay();
data_out;
void mnack(void)
    sda_H;
    delay();
    scl_H;
    delay();
    scl_L;
    delay();
    sda_L;
    delay();
void init(void)
data_out;
sda_H;
delay();
scl_H;
delay();
void write_byte(uchar data)
uchar i=0;
data_out;
for(i=0;i<8;i++)
  //scl_L;
  //delay();
  if(data&0x80)
    sda_H;
    delay();
    scl_H;
    delay();
    scl_L;
    delay();
  else
   sda_L;
    delay();
    scl_H;
    delay();
    scl_L;
    delay();
  data=data<<1;
sda_H;
delay();
uchar read_byte(void)
uchar i=0,data=0;
/*scl_L;
delay();
data_in;
delay();*/
for(i=0;i<8;i++)
// data=data<<1;
  sda_H;
  delay();
  scl_H;
  data_in;
  delay();
  if(PB_IDR&0x04)
   data=(data<<1)+1;
  else
   data=data<<1;
  data_out;
  scl_L;
  delay();
return data;
void write_add(uchar address,uchar date)
start();
write_byte(0xa0);
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
uchar read_add(uchar address)
uchar date=0;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
date=read_byte();
mnack();
stop();
return date;
void main()
uchar i=0;
gpio_init();
init();
write_add(23,0xaa);
//wait(10);
delay1(50);
high1=read_add(23);
while(1);
编译的时候,应答无效,不知道为什么?
此帖出自stm32/stm8论坛
                                 楼上怎么解决的?谢谢!  详情 回复 发表于 2010-12-18 20:53
78
84
                                 但我并没有用到stm8的I2C模块,只是用软件模拟I2C时序而已。另外,程序在51单片机上是能运行的!
此帖出自stm32/stm8论坛
                                 不甘心啊,弄了几天都没有弄出来!
此帖出自stm32/stm8论坛
56
                                 已经解决!
此帖出自stm32/stm8论坛
61
                                 楼上怎么解决的?谢谢!
此帖出自stm32/stm8论坛
